Merging two examples in SDK14
I've been working with SDK11, and now I have to move my project to SDK14 due to some issues with the old SDK.
In SDK11 I could just use Keil's "Manage Run-Time Enviroments" dialog to add whatever libraries I needed, and it worked.
Now I've started moving all my code to SDK14 and things don't work as they did, and now I'm trying to get the same code working.
I've started by taking the ble_app_uart example and adding to it the record_url example. I merged the required code, I went in the project options
under C/C++, ASM and appended the library paths there, but it still does not work, I keep getting:
linking...
.\_build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol nfc_t2t_emulation_start (referred from main.o).
.\_build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol nfc_t2t_payload_set (referred from main.o).
.\_build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol nfc_t2t_setup (referred from main.o).
.\_build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol nfc_uri_msg_encode (referred from main.o).
Not enough information to list image symbols.
I even tried merging the makefiles.
Also where did the nrf_drv_config.h file go?
Where do I now enable peripherals?
    Thanks for the reply.
    In the SDK11 I did the following modifications to the example, and that is all thats required to get it working on my board which does not contain a 32.78kHz crystal and DC-DC converter:
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION, NULL);
    And:
    NRF_POWER->DCDCEN = 0;
    On the SDK14 example I modified the sdk_config.h like this:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 12
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY  - External crystal clock accuracy used in the LL to compute timing windows.
    // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
    And also disabled the UART initialization because I'm not using it.
    After that I would click build and program the board.
    Am I missing a step?
  • You should set NRF_SDH_CLOCK_LF_XTAL_ACCURACY to 0 or 1. This parameter is used for both external XTAL and RC oscillator in s132 v5.0.0 softdevice (which is used in SDK 14.x.0). Setting it to 7 will cause the softdevice to expect accuracy of 20PPM, which the RC oscillator cannot provide. This is from s132 v5.0.0 release notes:
    New functionality
    • SoftDevice
      • The RC oscillator accuracy can now be set to any of the defined NRF_CLOCK_LF_ACCURACY values, and there is no default anymore. In other words, the nrf_clock_lf_cfg_t::accuracy parameter now has the same functionality when used with the RCOSC clock source as with the XTAL clock source (DRGN-8666).
    I've talked to Sigurd about the issue, and he gave me new settings which have NRF_SDH_CLOCK_LF_XTAL_ACCURACY is set to 1 and nothing changes.
    I don't think the issue is with this settings, something else is probably causing it not to work, and I can't figure out what. I could try removing the crystal from the devboard and see if I can get it working then.
  • Did you try debugging as I suggested above? What is the error code (if any) and where is the application stuck?
  • I get nothing at all via rtt, just black screen.
    The identical code works on the devboard, I removed the crystal from the devboard and I got it working once, but I can't get it working anymore.
