High Current Consumption with nRF52840 DK
Dear Madam/Sir,
I'm measuring the nRF52840 DK current consumption with my custom ble_peripheral app and other example ble_peripheral apps, namely ble_app_proximity, ble_app_pwr_profiling, and I'm registering in my ampere meter some continuous 0.800mA while advertising/in connection in both example apps (with the default parameters) and 0.200mA in my app. I'm powering the DK with a power supply set at 3.0V. My app is running in DC/DC with the advertise interval set to 2.25s and the connection interval set to 1s, and TX Power set to +9dBm. I also checked my app running on a oscilloscope and the connection/advertise TX peaks measure 14-15mA instead of the supposed 13.6mA.
The nRF Power Source switch is set to VDD, and I attempted both options on the nRF Only / Default switch. When setting the VEXT->nRF ON the consumption even increases.
In all three apps I commented all LOGGING related calls and all LEDs are turned off. I also tried running the DK on all three apps with the CR2032 battery but the current consumption is kept nearly the same. Do I need to also disable the NRF_LOG_ENABLED define in sdk_config.h to make sure it is turned off?
Is there a way to guarantee, through Firmware and/or Hardware, that no pinouts are enabled and causing the high consumption? Is there anything else that may justify such high consumption and that I should take special attention?
Thank you for your help,
João
  • Hi Stian,
    We tried to consider the LP mode saadc and it seems to indeed decrease the power consumption to normal levels.
    Yet, we also tried in Normal ADC mode to initialize the adc before requesting a nrf_drv_saadc_sample and unintialized it after the saadc_event_handler is called and the power consumption also stays at normal levels. Both "always-on LP ADC" mode or "turn_on-read-turn_off Normal ADC" mode seem to retrieve the same voltage measurements.
    Are both methods OK to use or would one be more precise than the other?
    Thank you,
    João
