Receiving simple message mesh
I followed this thread (Link) to implement a simple message model on the light switch example from nRF SDK for Mesh v1.0.1. I created a "send_simple_message" function with all the given code that i call in a function called when a button is pushed on the client.
It seems the message is sent since i receive a "0" status after "access_model_publish". From the server, the led still change its state when i push the button; but i don't know how to read the message (and how to receive it).
Do i have to use the "simple_message_init" function and the others functions defined in the model, how to and when ?
Has somebody implemented the simple message model and could help me?
Thanks.
  • what are the implementation that we have to do on server side to receive message can u please mention
    thank you
  • Hi, as in the above mentioned example im receving only opcode but not my message on the other nodes. can you suggest me how to read the message
  • HI,
    i am able to receive simple_message_OPCODE_SEND but not the message .how to read the message in server node
  • Hi, I would not recommend using this mesh sdk anymore, as it is quite outdated & the stack is not bluetooth mesh certified. I would download the newest mesh sdk & really understand the light switch example there. In addition, this documentation could be helpful.
            As nordic has implemented sdk for mesh and i have been using mesh sdk v3.0.0  LIGHT_SWITCH_EXAMPLE  but i am facing some problem regarding pa_lna. Actually wt i have done is i send a data and it has to be relayed to particular device so that among many devices in a group it can reach to speicific device and it was implemented successfully but here while i need to receive the advertising packets from different devices it is showing more RSSI .here i am using nrf52832  developed with separate ble boards with different gpio's .so as mentioned by nordic semi related to pa_lna ,the pins were used as 24 and 25 but we are using different gpio's according to our boards.so here we are facing problems that when ever the data is advertising it is showing more RSSI and when ever command/data has been send from client to specific server then suddenly the RSSI shows less .
    softdevice S132 and mesh sdk v3.0.0
    windows using keil
    so i am expecting that both pa_lna has to switch its role frequently but in my case its not happening,only when sending  any command its showing less RSSI and the remaining advertising time its been more.
    As i couldn't find any other solution related to this . so i hope could anyone help me regarding this problem .it will be so much helpful if i could complete this work with your help.
    Thank You.
