Receive string message from node in ble mesh.
I have extend the light switch example to send message to the other node. I have refer This example to send message. But how to configure another node to receive the message and relay the same message to server using WiFi. Will you please provide some sample example code to receive the message and relay that message. It also gives the error "Undefined reference to address_set." in following code
uint32_t status=0;
uint8_t buffer[30];
uint8_t length;
uint16_t address;
access_message_tx_t msg;
length= SEGGER_RTT_Read(0,buffer, sizeof(buffer));
           if (length)
              msg.opcode.opcode =simple_message_OPCODE_SEND;
              msg.opcode.company_id = 0x0059; // Nordic's company ID
              msg.p_buffer = (const uint8_t *) &buffer[0];
              msg.length =length;
              address = 0xCAFE;
              address_set(address);
              SEGGER_RTT_printf(0,"Sending to group address 0x%04x\n", address);
              status= access_model_publish(m_clients[0].model_handle, &msg);
              if (status == NRF_ERROR_INVALID_STATE ||
              status == NRF_ERROR_BUSY||status == NRF_ERROR_NO_MEM)
                 __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy.\n");
                  hal_led_blink_ms(LEDS_MASK, 50, 4);
                     ERROR_CHECK(status);
  • The TTL value (time-to-live) is defined as the number of hops between nodes the message will be broadcasted until the message should not be relayed further. If TTL = 1, then the message will only be sent to the nearest neighboring nodes & not to nodes that are one hop further away. How you set this value depends on how big your mesh network is & how far away nodes are. It could be a good idea to test your mesh network & vary the TTL value to see what is optimal so that all nodes receive the message, but the message is not broadcasted too many times.
    The way I understand it is you can have a TTL value that is quite high & get away with it due to the network message cache. This cache stores messages that have already been relayed further, so that if a message that has already been relayed is received by the same node, that message will not be relayed further. This is to make sure messages do not go in an infinite loop & keep on getting relayed further (see Bluetooth Mesh Profile Specification PDF for more info).
    Could you explain what you mean by "how we send the string using advertising packet"?
  • Thanks for your response.
    Currently i am sending string message using method "access_model_publish"  so whether that message goes through packet?. I am asking about packet because the only packet contains the ttl value. Whether the ttl value is different for every node in network? How we manage it?. will you please provide some sample example(ttl example)?.
    And how many(in size) data we send from one node to other. is there any size limit.? Which publish method is better "access_model_publish" or "access_model_reliable_publish"?
  • How we can do relay functionality?. I have forward the message as soon as i received it at relay node using access_model_publish method, is that correct?  But how we know that relay node decrement the ttl count?
  • The message goes through the packet. access_model_publish() calls packet_tx(). From the handle, the function is able to find the ttl from the m_model_pool array. The ttl value is set up to a default value equal to the server count (see ACCESS_DEFAULT_TTL in nrf_mesh_config_app.h). This makes sense because in the worst case, it will take you SERVER_COUNT number of hops to get from the first node to the last node (e.g. if the mesh network is a line of nodes). You can change the ttl value by using the access_model_publish_ttl_set() function.
    Regarding the max packet size, see packet.h header file:
    #define BLE_ADV_PACKET_BUFFER_MAX_LENGTH \
    (BLE_ADV_PACKET_HEADER_BUFFER_LENGTH + BLE_ADV_PACKET_OVERHEAD + \
    BLE_ADV_PACKET_PAYLOAD_MAX_LENGTH) /**< Longest possible BLE advertisement packet */.
    access_model_reliable_publish() calls access_model_publish(), but has a few more checks compared to access_model_publish(). Which one is better depends on the usecase(i.e. whether you need all of the checks that access_model_reliable_publish has). See this link for more info.
