Nordic controller is not receveing the ble disconnect event from the ble android application som times if i kill the app?reproducability 1 out of 20.
I am using nrf52832 peripheral and ble central with some android application .if an app opens it we get ble disconnect event and if we kill the app ble_disconect will come to the nordic board.it is working normally in most cases.if we forcefully kill the application when app was getting opened for n number of times the nordic controller  some times not receiving the ble disconnect event and controller board is still in connected state.Now if i kill the app since nordic is in  connected state and the peripheral is not visible to the android application. The nordic is coming out of connection state only after bluetooth was turn off.(android is throwing ble disconnect event when disconnect but which is blocking its reach to nordic board or it is problem with nordic internal code)
  • First step would be to setup an app_timer that repeatedly toggle an GPIO, to verify you have implemented app_timer correctly, does this work?
    Next step would be to start the app_timer on BLE_GAP_EVT_CONNECTED event, and then if there is no PM_EVT_CONN_SEC_SUCCEEDED in pm_evt_handler() within lets say 5seconds, then the app_timer timeout handler can execute sd_ble_gap_disconnect() to force a disconnect.
    You can stop the app_timer on PM_EVT_CONN_SEC_SUCCEEDED and BLE_GAP_EVT_DISCONNECTED events, to make sure the timeout handler does not execute a disconnect if the link is securely encrypted or if the link is already disconnected.
