SPI communication failure between nRF52840 Preview DK and Arduino UNO
Hello DevZone,
I am doing a simple test for SPI communication between nRF52840 DK(SPI master) and Arduino UNO(slave).
The Nordic program is based on SDK 14.2.0 spi example, I only change the TEST_STRING from "Nordic" to "N" and PIN number according to Arduino PIN map.
 * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
//#define TEST_STRING "N"
static uint8_t       m_tx_buf[] = {'N'};           /**< TX buffer. */
static uint8_t       m_rx_buf[2];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    bsp_board_leds_init();
    NRF_LOG_INFO("SPI example.");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = 44; //SPI_SS_PIN;
    spi_config.miso_pin = 46; //SPI_MISO_PIN;
    spi_config.mosi_pin = 45; //SPI_MOSI_PIN;
    spi_config.sck_pin  = 47; //SPI_SCK_PIN;
    spi_config.irq_priority = APP_IRQ_PRIORITY_LOW;
    spi_config.orc          = 0xCC;
    spi_config.frequency    = NRF_DRV_SPI_FREQ_500K;
    spi_config.mode         = NRF_DRV_SPI_MODE_0;
    spi_config.bit_order    = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
and a Arduino slave example code:
// what to do with incoming data
volatile byte command = 0;
int select_slave = 0; //1: selected, 2: not selected
void setup (void)
  Serial.begin (9600);
  Serial.println ("This is SPI slave test");
  // have to send on master in, *slave out*
  pinMode(MISO, OUTPUT);
  // turn on SPI in slave mode
  SPCR |= _BV(SPE);
  // turn on interrupts
  SPCR |= _BV(SPIE);
  }  // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
  byte c = SPDR;
  if(command == 0)
    SPDR = 0;
    SPDR = c;
    Serial.print ("Rx is:");
    Serial.println (c, DEC);
    Serial.print ("Tx is:");
  }  // end of interrupt service routine (ISR) SPI_STC_vect
void loop (void)
    // if SPI not active, clear current command
    if (digitalRead (SS) == HIGH)
      command = 0;
      if(select_slave!=2)
      { Serial.println("Slave is not selected");
      select_slave = 2;}
      command = 1;
      if(select_slave!=1)
      { Serial.println("**Slave is selected");
      select_slave = 1;}
  }  // end of loop
As I set SPDR to the value Arduino received, what I expect is Nordic should receive the same value it send to Arduino...
The result is: Sending data from Nordic to Arduino seems OK. However, Nordic receives the strange response...
Is it possible to test my sample code in your side? Very appreciate if you can verify my test sample and find the root cause of the problem.
  • Hi Rubens
    I am sorry for the slow response, it was hard to find some time to dig into this...
    Finally I got my Arduino Uno running, and I am also having some issues getting communication between the two.
    What I just realized is that the voltage between the two boards will not be compatible. The Arduino runs at 5V, while the nRF52840 PDK runs at around 3.0V normally, and this is likely to cause issues when you try to establish communication between the two.
    I would recommend you either put level shifters on your SPI lines to do the voltage conversion, or hack your Arduino to run at 3.3V as described here
    Best regards
    Torbjørn
