How to automate compilation by including all necessary files
I wanna automate the processing of compilation, my idea is to point all path-related files (*.c and *.h), I wrote script which is looking for all *.c and *.h files and includes them into makefile
#!/bin/bash
src_file=Sources.mk
header_file=Headers.mk
if [ -f "$src_file" ]
then
	echo "$src_file found."
	echo "# Source files common to all targets" >> $src_file && echo "SRC_FILES += \\" >> $src_file && find . -path ./examples -prune -o -type f -name *.[c] | sed 's/.\//  \$(SDK_ROOT)\//' | sed 's/$/ \\/' >> $src_file
fi
if [ -f "$header_file" ]
then
	echo "$header_file found."
	echo "# Include folders common to all targets" >> $header_file && echo "INC_FOLDERS += \\" >> $header_file && find . -path ./examples -prune -o -type f -name *.[h] -exec dirname {} \; | sed 's/.\//  \$(SDK_ROOT)\//' | sed 's/*.h//g' | sed 's/$/ \\/' >> $header_file
fi
They were included into main Makefile as
include Source.mk
include Headers.mk
But when I try to compile something I get some errors, i.e.
Compiling file: ant_stack_config.c
Compiling file: ant_bpwr_simulator.c
In file included from /nrf51/12.3.0/components/ant/ant_profiles/ant_bpwr/simulator/ant_bpwr_simulator.h:65:0,
                 from /nrf51/12.3.0/components/ant/ant_profiles/ant_bpwr/simulator/ant_bpwr_simulator.c:41:
/nrf51/12.3.0/components/ant/ant_profiles/ant_bpwr/ant_bpwr.h:55:10: fatal error: ant_parameters.h: No such file or directory
 #include "ant_parameters.h"
compilation terminated.
make: *** [_build/nrf51422_xxac_ant_bpwr_simulator.c.o] Error 1
Means that script missed some files, is it possible to automate it or to compile SDK as static library?
  • Hi, thanks for your reply)
    The reason to simplify adding files to the Makefile. Cause sometimes I missed some files when I compile project, the same case when I edit nrf_config.h file
    I thought there was easy way to build static library and include it into my project every time
    I like, for example Xcode, way when I don't care about including libraries files and able to build my project, editing only my files and include some headers
  • The problem is that the SDK is not really setup to be compiled as a full library, so there's a lot of things that you'll need to handle in order to make that happen, in terms of preprocessor defines, compiler settings, architecture (nrf51x22, nrf52832, nrf52810, nrf52840), etc. It's likely easier to manage the sources directly using a project file (makefile or an IDE)
  • I know it is an old thread but I wanted to mention the one of the reasons would be to speed up compilation times which are too often very long. I know GNU make is taking take of it in many cases but it still unnecessarily happens anyways (f.ex: whenever something is changed in the project's makefile).
    Having SDK as a library or being able to configure it to precompile once could save plenty of time.
