Hi, im using nRF24L01+ to constantly transmit data and all working fine, but at some point SPI fails and the only returned values I get are 0x0F - doesnt matter which register I try to read or write. Any idea why is that happening?
Thanks, Sergey
Thanks, Sergey
Håkon,
i did some additional testing. SPI works correctly on the MCU side, so it sends correct data. I have a feeling that indeed when devices are too close by to each other it stops working. Any idea on how to protect it from a high-power signal? 30cm apart is not enough especially if we use the highest power.
Regards, Sergey
Since the nRF24L01+ does not have an RSSI, it is not trivial to implement a detection of this. You could use the RPD bit (detects if signal is > -64 dBm) to adjust the output power, by checking this bit when you receive an ACK.
Best regards Håkon
The problem is that you will then degrade the receiver sensitivity as well, which affects your overall range. I would recommend that you use a lower output power instead of doing this.
You could try a power-output scaling based on the number of re-transmissions that occurs. If you have a low re-transmit count, then you scale the output power down. When it rises, you set higher output power.
Best regards Håkon
The thing is that we dont use re transmits at all to maximize the bandwidth. But what I meant is to use diode on the incoming signal so if signal is over 0dBm diode would cut it down to 0 dBm, here is the diode im talking about: www.infineon.com/.../bat24-02ls.pdf
Thanks!
