Written a custom script to write product model no into UICR Registers. After updating Model No, DFU was getting failed at state 6 i.e after updating init data after moving bootloader mode.
I uploaded my custom script for your reference.
I am using nrfutil tool to generate .zip file that contain manifest.json, .bin and .dat files. I am sending .dat is init packet for DFU.
nrfutil dfu genpkg --application _build/ble_cloudleaf_app_s130_xxac.hex --application-version 2 LM2.zip
here is contents of manifest.json
"manifest": {
"application": {
"bin_file": "ble_cloudleaf_app_s130_xxac.bin",
"dat_file": "ble_cloudleaf_app_s130_xxac.dat",
"init_packet_data": {
"application_version": 4294967295,
"device_revision": 65535,
"device_type": 65535,
"firmware_crc16": 59631,
"softdevice_req": [
65534
"dfu_version": 0.5
Instead of removing the optional pre-validation step. Is there a way to update device_type & device_revision fields in init packet to the same model number used in the shell script to update UICR Registers.
If it works fine with out any code changes, I will go with that.
Yes, it is possible to defined the device revision and type to be the same as the model number. You can use the optional --dev-revision and --dev-type arguments when generating the package:
nrfutil command is not accepting model number POI1-BD3i3B as --dev-type & --dev-revision.
nrfutil dfu genpkg --application _build/ble_cloudleaf_app_s130_xxac.hex --dev-type POI1-BD3i3B --application-version 3 LM3.zip
Usage: nrfutil dfu genpkg [OPTIONS] ZIPFILE
Error: Invalid value for "--dev-type": POI1-BD3i3B is not a valid integer
nrfutil dfu genpkg --application _build/ble_cloudleaf_app_s130_xxac.hex --dev-revision POI1-BD3i3B --dev-type POI1-BD3i3B --application-version 3 LM3.zip
Error: Invalid value for "--dev-revision": POI1-BD3i3B is not a valid integer
