Device match
uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8 };
i want to triger a interrupt via PPI when received package from pipe 2 ( 0xC3 0xC2, 0xC2, 0xC2, 0xC2). so how can I config DAB , DAP and DACNF registers ?
my PPI init like below, if it is correct ?
nrf_drv_gpiote_init();
nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
nrf_drv_gpiote_out_init(LED_4, &config);
uint32_t gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(LED_4);
NRF_RADIO->DAB[?] = ?
NRF_RADIO->DAP[?] = ?
NRF_RADIO->DACNF |= ?
NRF_PPI->CH[NRF_ESB_PPI_POS_SYNC].EEP = (uint32_t)&NRF_RADIO->EVENTS_DEVMATCH;
NRF_PPI->CH[NRF_ESB_PPI_POS_SYNC].TEP = (uint32_t)gpiote_task_addr;
NRF_PPI->CHENSET = (1 << NRF_ESB_PPI_POS_SYNC) ;
nrf_drv_gpiote_out_task_enable(LED_4);
    I have not gotten to the bottom of why it didn’t work with payload larger than 32, and TxAdd bit set to 0.
    But the workaround seem to be to set the TxAddBit to 1 instead, and use
    NRF_RADIO->DACNF |= (1U << (pipe + RADIO_DACNF_TXADD0_Pos));
    In radio_whitelist_add()
    This will also require some minor changes in nrf_esb.c, where we instead of setting S0 byte to 0x00, we set it to e.g 0xFF instead, so that the TxAddbit (bit number 6 in S0) is 1. Below is the modified nrf_esb.c based on SDK 14.2, where we set S0 byte to 0xFF instead.
     * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_error.h"
    #include "nrf_esb.h"
    #include "nrf_esb_error_codes.h"
    #include "nrf_gpio.h"
    #include <string.h>
    #include <stddef.h>
    #include "sdk_common.h"
    #include "sdk_macros.h"
    #include "app_util.h"
    #include "nrf_log.h"
    #include "nrf_delay.h"
    #define BIT_MASK_UINT_8(x) (0xFF >> (8 - (x)))
    #define NRF_ESB_PIPE_COUNT 8
    #define S0BYTE 0xFF
    // Constant parameters
    #define RX_WAIT_FOR_ACK_TIMEOUT_US_2MBPS        (48)        /**< 2 Mb RX wait for acknowledgment time-out value. Smallest reliable value - 43. */
    #define RX_WAIT_FOR_ACK_TIMEOUT_US_1MBPS        (64)        /**< 1 Mb RX wait for acknowledgment time-out value. Smallest reliable value - 59. */
    #define RX_WAIT_FOR_ACK_TIMEOUT_US_250KBPS      (250)       /**< 250 Kb RX wait for acknowledgment time-out value. */
    #define RX_WAIT_FOR_ACK_TIMEOUT_US_1MBPS_BLE    (73)        /**< 1 Mb RX wait for acknowledgment time-out (combined with BLE). Smallest reliable value - 68.*/
    // Interrupt flags
    #define     NRF_ESB_INT_TX_SUCCESS_MSK          0x01        /**< Interrupt mask value for TX success. */
    #define     NRF_ESB_INT_TX_FAILED_MSK           0x02        /**< Interrupt mask value for TX failure. */
    #define     NRF_ESB_INT_RX_DATA_RECEIVED_MSK    0x04        /**< Interrupt mask value for RX_DR. */
    #define     NRF_ESB_PID_RESET_VALUE             0xFF        /**< Invalid PID value which is guaranteed to not collide with any valid PID value. */
    #define     NRF_ESB_PID_MAX                     3           /**< Maximum value for PID. */
    #define     NRF_ESB_CRC_RESET_VALUE             0xFFFF      /**< CRC reset value. */
    // Internal Enhanced ShockBurst module state.
    typedef enum {
        NRF_ESB_STATE_IDLE,                                     /**< Module idle. */
        NRF_ESB_STATE_PTX_TX,                                   /**< Module transmitting without acknowledgment. */
        NRF_ESB_STATE_PTX_TX_ACK,                               /**< Module transmitting with acknowledgment. */
        NRF_ESB_STATE_PTX_RX_ACK,                               /**< Module transmitting with acknowledgment and reception of payload with the acknowledgment response. */
        NRF_ESB_STATE_PRX,                                      /**< Module receiving packets without acknowledgment. */
        NRF_ESB_STATE_PRX_SEND_ACK,                             /**< Module transmitting acknowledgment in RX mode. */
    } nrf_esb_mainstate_t;
    #define DISABLE_RF_IRQ()      NVIC_DisableIRQ(RADIO_IRQn)
    #define ENABLE_RF_IRQ()       NVIC_EnableIRQ(RADIO_IRQn)
    #define _RADIO_SHORTS_COMMON ( RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_DISABLE_Msk | \
                RADIO_SHORTS_ADDRESS_RSSISTART_Msk | RADIO_SHORTS_DISABLED_RSSISTOP_Msk )
    #define VERIFY_PAYLOAD_LENGTH(p)                            \
    do                                                          \
        if (p->length == 0 ||                                    \
           p->length > NRF_ESB_MAX_PAYLOAD_LENGTH ||            \
           (m_config_local.protocol == NRF_ESB_PROTOCOL_ESB &&  \
            p->length > m_config_local.payload_length))         \
            return NRF_ERROR_INVALID_LENGTH;                    \
    }while (0)
    /* @brief Structure holding pipe info PID and CRC and acknowledgment payload. */
    typedef struct
        uint16_t    crc;                                      /**< CRC value of the last received packet (Used to detect retransmits). */
        uint8_t     pid;                                      /**< Packet ID of the last received packet (Used to detect retransmits). */
        bool        ack_payload;                              /**< Flag indicating the state of the transmission of acknowledgment payloads. */
    	uint8_t     s0;
    } pipe_info_t;
    /* @brief  First-in, first-out queue of payloads to be transmitted. */
    typedef struct
        nrf_esb_payload_t * p_payload[NRF_ESB_TX_FIFO_SIZE];  /**< Pointer to the actual queue. */
        uint32_t            entry_point;                      /**< Current start of queue. */
        uint32_t            exit_point;                       /**< Current end of queue. */
        uint32_t            count;                            /**< Current number of elements in the queue. */
    } nrf_esb_payload_tx_fifo_t;
    /* @brief First-in, first-out queue of received payloads. */
    typedef struct
        nrf_esb_payload_t * p_payload[NRF_ESB_RX_FIFO_SIZE];  /**< Pointer to the actual queue. */
    } nrf_esb_payload_rx_fifo_t;
    /**@brief Enhanced ShockBurst address.
     * Enhanced ShockBurst addresses consist of a base address and a prefix
     *          that is unique for each pipe. See @ref esb_addressing in the ESB user
     *          guide for more information.
    typedef struct
        uint8_t base_addr_p0[4];        /**< Base address for pipe 0 encoded in big endian. */
        uint8_t base_addr_p1[4];        /**< Base address for pipe 1-7 encoded in big endian. */
        uint8_t pipe_prefixes[8];       /**< Address prefix for pipe 0 to 7. */
        uint8_t num_pipes;              /**< Number of pipes available. */
        uint8_t addr_length;            /**< Length of the address including the prefix. */
        uint8_t rx_pipes_enabled;       /**< Bitfield for enabled pipes. */
        uint8_t rf_channel;             /**< Channel to use (must be between 0 and 100). */
    } nrf_esb_address_t;
    // Module state
    static bool                         m_esb_initialized           = false;
    static nrf_esb_mainstate_t          m_nrf_esb_mainstate         = NRF_ESB_STATE_IDLE;
    static nrf_esb_payload_t          * mp_current_payload;
    static nrf_esb_event_handler_t      m_event_handler;
    // Address parameters
    __ALIGN(4) static nrf_esb_address_t m_esb_addr = NRF_ESB_ADDR_DEFAULT;
    // RF parameters
    static nrf_esb_config_t             m_config_local;
    // TX FIFO
    static nrf_esb_payload_t            m_tx_fifo_payload[NRF_ESB_TX_FIFO_SIZE];
    static nrf_esb_payload_tx_fifo_t    m_tx_fifo;
    // RX FIFO
    static nrf_esb_payload_t            m_rx_fifo_payload[NRF_ESB_RX_FIFO_SIZE];
    static nrf_esb_payload_rx_fifo_t    m_rx_fifo;
    // Payload buffers
    static  uint8_t                     m_tx_payload_buffer[NRF_ESB_MAX_PAYLOAD_LENGTH + 3]; //Added 1 for S0
    static  uint8_t                     m_rx_payload_buffer[NRF_ESB_MAX_PAYLOAD_LENGTH + 3]; //Added 1 for S0
    // Run time variables
    static volatile uint32_t            m_interrupt_flags = 0;
    static uint8_t                      m_pids[NRF_ESB_PIPE_COUNT];
    static pipe_info_t                  m_rx_pipe_info[NRF_ESB_PIPE_COUNT];
    static volatile uint32_t            m_retransmits_remaining;
    static volatile uint32_t            m_last_tx_attempts;
    static volatile uint32_t            m_wait_for_ack_timeout_us;
    // nRF52 address workaround enable
    #ifdef NRF52
    static bool                         m_address_hang_fix_enable = true;
    static uint32_t                     m_radio_shorts_common = _RADIO_SHORTS_COMMON;
    // These function pointers are changed dynamically, depending on protocol configuration and state.
    static void (*on_radio_disabled)(void) = 0;
    static void (*on_radio_end)(void) = 0;
    static void (*update_rf_payload_format)(uint32_t payload_length) = 0;
    // The following functions are assigned to the function pointers above.
    static void on_radio_disabled_tx_noack(void);
    static void on_radio_disabled_tx(void);
    static void on_radio_disabled_tx_wait_for_ack(void);
    static void on_radio_disabled_rx(void);
    static void on_radio_disabled_rx_ack(void);
    #define NRF_ESB_ADDR_UPDATE_MASK_BASE0          (1 << 0)    /*< Mask value to signal updating BASE0 radio address. */
    #define NRF_ESB_ADDR_UPDATE_MASK_BASE1          (1 << 1)    /*< Mask value to signal updating BASE1 radio address. */
    #define NRF_ESB_ADDR_UPDATE_MASK_PREFIX         (1 << 2)    /*< Mask value to signal updating radio prefixes. */
    // Function to do bytewise bit-swap on an unsigned 32-bit value
    static uint32_t bytewise_bit_swap(uint8_t const * p_inp)
        uint32_t inp = (*(uint32_t*)p_inp);
    #if __CORTEX_M == (0x04U)
        return __REV((uint32_t)__RBIT(inp)); //lint -esym(628, __rev) -esym(526, __rev) -esym(628, __rbit) -esym(526, __rbit) */
    #else
        inp = (inp & 0xF0F0F0F0) >> 4 | (inp & 0x0F0F0F0F) << 4;
        inp = (inp & 0xCCCCCCCC) >> 2 | (inp & 0x33333333) << 2;
        inp = (inp & 0xAAAAAAAA) >> 1 | (inp & 0x55555555) << 1;
        return inp;
    // Internal function to convert base addresses from nRF24L type addressing to nRF51 type addressing
    static uint32_t addr_conv(uint8_t const* p_addr)
        return __REV(bytewise_bit_swap(p_addr)); //lint -esym(628, __rev) -esym(526, __rev) */
    static ret_code_t apply_address_workarounds()
    #ifdef NRF52
        //  Set up radio parameters.
        NRF_RADIO->MODECNF0 = (NRF_RADIO->MODECNF0 & ~RADIO_MODECNF0_RU_Msk) | RADIO_MODECNF0_RU_Default << RADIO_MODECNF0_RU_Pos;
        // Workaround for nRF52832 Rev 1 Errata 102 and nRF52832 Rev 1 Errata 106. This will reduce sensitivity by 3dB.
        *((volatile uint32_t *)0x40001774) = (*((volatile uint32_t *)0x40001774) & 0xFFFFFFFE) | 0x01000000;
        return NRF_SUCCESS;
    static void update_rf_payload_format_esb_dpl(uint32_t payload_length)
    #if (NRF_ESB_MAX_PAYLOAD_LENGTH <= 32)
        // Using 6 bits for length
        NRF_RADIO->PCNF0 = (1 << RADIO_PCNF0_S0LEN_Pos) |  //Setting 1 for S0 byte
                           (6 << RADIO_PCNF0_LFLEN_Pos) |
                           (3 << RADIO_PCNF0_S1LEN_Pos) ;
    #else
        // Using 8 bits for length
                           (8 << RADIO_PCNF0_LFLEN_Pos) |
        NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled    << RADIO_PCNF1_WHITEEN_Pos) |
                           (RADIO_PCNF1_ENDIAN_Little          << RADIO_PCNF1_ENDIAN_Pos)  |
                           ((m_esb_addr.addr_length - 1)    << RADIO_PCNF1_BALEN_Pos)   |
                           (0                               << RADIO_PCNF1_STATLEN_Pos) |
                           (NRF_ESB_MAX_PAYLOAD_LENGTH      << RADIO_PCNF1_MAXLEN_Pos);
    static void update_rf_payload_format_esb(uint32_t payload_length)
                           (0 << RADIO_PCNF0_LFLEN_Pos) |
                           (1 << RADIO_PCNF0_S1LEN_Pos);
                           (payload_length                  << RADIO_PCNF1_STATLEN_Pos) |
                           (payload_length                  << RADIO_PCNF1_MAXLEN_Pos);
    static void update_radio_addresses(uint8_t update_mask)
        if ((update_mask & NRF_ESB_ADDR_UPDATE_MASK_BASE0) != 0)
            NRF_RADIO->BASE0 = addr_conv(m_esb_addr.base_addr_p0);
        if ((update_mask & NRF_ESB_ADDR_UPDATE_MASK_BASE1) != 0)
            NRF_RADIO->BASE1 = addr_conv(m_esb_addr.base_addr_p1);
        if ((update_mask & NRF_ESB_ADDR_UPDATE_MASK_PREFIX) != 0)
            NRF_RADIO->PREFIX0 = bytewise_bit_swap(&m_esb_addr.pipe_prefixes[0]);
            NRF_RADIO->PREFIX1 = bytewise_bit_swap(&m_esb_addr.pipe_prefixes[4]);
    static void update_radio_tx_power()
        NRF_RADIO->TXPOWER = m_config_local.tx_output_power << RADIO_TXPOWER_TXPOWER_Pos;
    static bool update_radio_bitrate()
        NRF_RADIO->MODE = m_config_local.bitrate << RADIO_MODE_MODE_Pos;
        switch (m_config_local.bitrate)
            case NRF_ESB_BITRATE_2MBPS:
    #ifdef NRF52
            case NRF_ESB_BITRATE_2MBPS_BLE:
                m_wait_for_ack_timeout_us = RX_WAIT_FOR_ACK_TIMEOUT_US_2MBPS;
            case NRF_ESB_BITRATE_1MBPS:
                m_wait_for_ack_timeout_us = RX_WAIT_FOR_ACK_TIMEOUT_US_1MBPS;
    #ifdef NRF51
            case NRF_ESB_BITRATE_250KBPS:
                m_wait_for_ack_timeout_us = RX_WAIT_FOR_ACK_TIMEOUT_US_250KBPS;
            case NRF_ESB_BITRATE_1MBPS_BLE:
                m_wait_for_ack_timeout_us = RX_WAIT_FOR_ACK_TIMEOUT_US_1MBPS_BLE;
                // Should not be reached
                return false;
        return true;
    static bool update_radio_protocol()
        switch (m_config_local.protocol)
            case NRF_ESB_PROTOCOL_ESB_DPL:
                update_rf_payload_format = update_rf_payload_format_esb_dpl;
            case NRF_ESB_PROTOCOL_ESB:
                update_rf_payload_format = update_rf_payload_format_esb;
                return false;
        return true;
    static bool update_radio_crc()
        switch(m_config_local.crc)
            case NRF_ESB_CRC_16BIT:
                NRF_RADIO->CRCINIT = 0xFFFFUL;      // Initial value
                NRF_RADIO->CRCPOLY = 0x11021UL;     // CRC poly: x^16+x^12^x^5+1
            case NRF_ESB_CRC_8BIT:
                NRF_RADIO->CRCINIT = 0xFFUL;        // Initial value
                NRF_RADIO->CRCPOLY = 0x107UL;       // CRC poly: x^8+x^2^x^1+1
            case NRF_ESB_CRC_OFF:
                return false;
        NRF_RADIO->CRCCNF = m_config_local.crc << RADIO_CRCCNF_LEN_Pos;
        return true;
    static bool update_radio_parameters()
        bool params_valid = true;
        update_radio_tx_power();
        params_valid &= update_radio_bitrate();
        params_valid &= update_radio_protocol();
        params_valid &= update_radio_crc();
        update_rf_payload_format(m_config_local.payload_length);
        params_valid &= (m_config_local.retransmit_delay >= NRF_ESB_RETRANSMIT_DELAY_MIN);
        return params_valid;
    static void reset_fifos()
        m_tx_fifo.entry_point = 0;
        m_tx_fifo.exit_point  = 0;
        m_tx_fifo.count       = 0;
        m_rx_fifo.entry_point = 0;
        m_rx_fifo.exit_point  = 0;
        m_rx_fifo.count       = 0;
    static void initialize_fifos()
        reset_fifos();
        for (int i = 0; i < NRF_ESB_TX_FIFO_SIZE; i++)
            m_tx_fifo.p_payload[i] = &m_tx_fifo_payload[i];
        for (int i = 0; i < NRF_ESB_RX_FIFO_SIZE; i++)
            m_rx_fifo.p_payload[i] = &m_rx_fifo_payload[i];
    static void tx_fifo_remove_last()
        if (m_tx_fifo.count > 0)
            DISABLE_RF_IRQ();
            m_tx_fifo.count--;
            if (++m_tx_fifo.exit_point >= NRF_ESB_TX_FIFO_SIZE)
            ENABLE_RF_IRQ();
    /** @brief  Function to push the content of the rx_buffer to the RX FIFO.
     *  The module will point the register NRF_RADIO->PACKETPTR to a buffer for receiving packets.
     *  After receiving a packet the module will call this function to copy the received data to
     *  the RX FIFO.
     *  @param  pipe Pipe number to set for the packet.
     *  @param  pid  Packet ID.
     *  @retval true   Operation successful.
     *  @retval false  Operation failed.
    static bool rx_fifo_push_rfbuf(uint8_t pipe, uint8_t pid)
        if (m_rx_fifo.count < NRF_ESB_RX_FIFO_SIZE)
            if (m_config_local.protocol == NRF_ESB_PROTOCOL_ESB_DPL)
                if (m_rx_payload_buffer[1] > NRF_ESB_MAX_PAYLOAD_LENGTH) //Moved 1 byte. Changed from 0 to 1.
                    return false;
                m_rx_fifo.p_payload[m_rx_fifo.entry_point]->length = m_rx_payload_buffer[1]; //Length is moved 1 byte because of S0. Changed from 0 to 1
            else if (m_config_local.mode == NRF_ESB_MODE_PTX)
                // Received packet is an acknowledgment
                m_rx_fifo.p_payload[m_rx_fifo.entry_point]->length = 0;
                m_rx_fifo.p_payload[m_rx_fifo.entry_point]->length = m_config_local.payload_length;
            memcpy(m_rx_fifo.p_payload[m_rx_fifo.entry_point]->data, &m_rx_payload_buffer[3], //Moved 1 byte. Changed from 2 to 3.
                   m_rx_fifo.p_payload[m_rx_fifo.entry_point]->length);
            m_rx_fifo.p_payload[m_rx_fifo.entry_point]->pipe  = pipe;
            m_rx_fifo.p_payload[m_rx_fifo.entry_point]->rssi  = NRF_RADIO->RSSISAMPLE;
            m_rx_fifo.p_payload[m_rx_fifo.entry_point]->pid   = pid;
            m_rx_fifo.p_payload[m_rx_fifo.entry_point]->noack = !(m_rx_payload_buffer[2] & 0x01);  //moved 1 byte. Changed from 1 to 2.
            if (++m_rx_fifo.entry_point >= NRF_ESB_RX_FIFO_SIZE)
            m_rx_fifo.count++;
            return true;
        return false;
    static void sys_timer_init()
        // Configure the system timer with a 1 MHz base frequency
        NRF_ESB_SYS_TIMER->PRESCALER = 4;
        NRF_ESB_SYS_TIMER->BITMODE   = TIMER_BITMODE_BITMODE_16Bit;
        NRF_ESB_SYS_TIMER->SHORTS    = TIMER_SHORTS_COMPARE1_CLEAR_Msk | TIMER_SHORTS_COMPARE1_STOP_Msk;
    static void ppi_init()
        NRF_PPI->CH[NRF_ESB_PPI_TIMER_START].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;
        NRF_PPI->CH[NRF_ESB_PPI_TIMER_START].TEP = (uint32_t)&NRF_ESB_SYS_TIMER->TASKS_START;
        NRF_PPI->CH[NRF_ESB_PPI_TIMER_STOP].EEP  = (uint32_t)&NRF_RADIO->EVENTS_ADDRESS;
        NRF_PPI->CH[NRF_ESB_PPI_TIMER_STOP].TEP  = (uint32_t)&NRF_ESB_SYS_TIMER->TASKS_STOP;
        NRF_PPI->CH[NRF_ESB_PPI_RX_TIMEOUT].EEP  = (uint32_t)&NRF_ESB_SYS_TIMER->EVENTS_COMPARE[0];
        NRF_PPI->CH[NRF_ESB_PPI_RX_TIMEOUT].TEP  = (uint32_t)&NRF_RADIO->TASKS_DISABLE;
        NRF_PPI->CH[NRF_ESB_PPI_TX_START].EEP    = (uint32_t)&NRF_ESB_SYS_TIMER->EVENTS_COMPARE[1];
        NRF_PPI->CH[NRF_ESB_PPI_TX_START].TEP    = (uint32_t)&NRF_RADIO->TASKS_TXEN;
    static void start_tx_transaction()
        bool ack;
        m_last_tx_attempts = 1;
        // Prepare the payload
        mp_current_payload = m_tx_fifo.p_payload[m_tx_fifo.exit_point];
            case NRF_ESB_PROTOCOL_ESB: //We are using ESB_DPL. No changes done here.
                update_rf_payload_format(mp_current_payload->length);
                m_tx_payload_buffer[0] = mp_current_payload->pid;
                m_tx_payload_buffer[1] = 0;
                memcpy(&m_tx_payload_buffer[2], mp_current_payload->data, mp_current_payload->length);
                NRF_RADIO->SHORTS   = m_radio_shorts_common | RADIO_SHORTS_DISABLED_RXEN_Msk;
                NRF_RADIO->INTENSET = RADIO_INTENSET_DISABLED_Msk | RADIO_INTENSET_READY_Msk;
                // Configure the retransmit counter
                m_retransmits_remaining = m_config_local.retransmit_count;
                on_radio_disabled = on_radio_disabled_tx;
                m_nrf_esb_mainstate = NRF_ESB_STATE_PTX_TX_ACK;
                ack = !mp_current_payload->noack || !m_config_local.selective_auto_ack;
    	    m_tx_payload_buffer[0] = S0BYTE; //setting s0 as first byte in packet.
                m_tx_payload_buffer[1] = mp_current_payload->length; //Length has been moved 1 byte. Changed from 0 to 1.
                m_tx_payload_buffer[2] = mp_current_payload->pid << 1;  //Moved 1 byte. Changed from 1 to 2.
                m_tx_payload_buffer[2] |= mp_current_payload->noack ? 0x00 : 0x01; //Moved 1 byte. Changed from 1 to 2.
                memcpy(&m_tx_payload_buffer[3], mp_current_payload->data, mp_current_payload->length); //Moved 1 byte. Changed from 2 to 3.
                // Handling ack if noack is set to false or if selective auto ack is turned off
                if (ack)
                    NRF_RADIO->SHORTS   = m_radio_shorts_common;
                    NRF_RADIO->INTENSET = RADIO_INTENSET_DISABLED_Msk;
                    on_radio_disabled   = on_radio_disabled_tx_noack;
                    m_nrf_esb_mainstate = NRF_ESB_STATE_PTX_TX;
        NRF_RADIO->TXADDRESS    = mp_current_payload->pipe;
        NRF_RADIO->RXADDRESSES  = 1 << mp_current_payload->pipe;
        NRF_RADIO->FREQUENCY    = m_esb_addr.rf_channel;
        NRF_RADIO->PACKETPTR    = (uint32_t)m_tx_payload_buffer;
        NVIC_ClearPendingIRQ(RADIO_IRQn);
        NVIC_EnableIRQ(RADIO_IRQn);
        NRF_RADIO->EVENTS_ADDRESS = 0;
        NRF_RADIO->EVENTS_PAYLOAD = 0;
        NRF_RADIO->EVENTS_DISABLED = 0;
        DEBUG_PIN_SET(DEBUGPIN4);
        NRF_RADIO->TASKS_TXEN  = 1;
    static void on_radio_disabled_tx_noack()
        m_interrupt_flags |= NRF_ESB_INT_TX_SUCCESS_MSK;
        tx_fifo_remove_last();
        if (m_tx_fifo.count == 0)
            NVIC_SetPendingIRQ(ESB_EVT_IRQ);
            start_tx_transaction();
    static void on_radio_disabled_tx()
        // Remove the DISABLED -> RXEN shortcut, to make sure the radio stays
        // disabled after the RX window
        // Make sure the timer is started the next time the radio is ready,
        // and that it will disable the radio automatically if no packet is
        // received by the time defined in m_wait_for_ack_timeout_us
        NRF_ESB_SYS_TIMER->CC[0]    = m_wait_for_ack_timeout_us;
        NRF_ESB_SYS_TIMER->CC[1]    = m_config_local.retransmit_delay - 130;
        NRF_ESB_SYS_TIMER->TASKS_CLEAR = 1;
        NRF_ESB_SYS_TIMER->EVENTS_COMPARE[0] = 0;
        NRF_ESB_SYS_TIMER->EVENTS_COMPARE[1] = 0;
        NRF_PPI->CHENSET            = (1 << NRF_ESB_PPI_TIMER_START) |
                                      (1 << NRF_ESB_PPI_RX_TIMEOUT) |
                                      (1 << NRF_ESB_PPI_TIMER_STOP);
        NRF_PPI->CHENCLR            = (1 << NRF_ESB_PPI_TX_START);
        NRF_RADIO->EVENTS_END       = 0;
        if (m_config_local.protocol == NRF_ESB_PROTOCOL_ESB)
            update_rf_payload_format(0);
        NRF_RADIO->PACKETPTR        = (uint32_t)m_rx_payload_buffer;
        on_radio_disabled           = on_radio_disabled_tx_wait_for_ack;
        m_nrf_esb_mainstate         = NRF_ESB_STATE_PTX_RX_ACK;
    static void on_radio_disabled_tx_wait_for_ack()
        // This marks the completion of a TX_RX sequence (TX with ACK)
        // Make sure the timer will not deactivate the radio if a packet is received
        NRF_PPI->CHENCLR = (1 << NRF_ESB_PPI_TIMER_START) |
        // If the radio has received a packet and the CRC status is OK
        if (NRF_RADIO->EVENTS_END && NRF_RADIO->CRCSTATUS != 0)
            NRF_ESB_SYS_TIMER->TASKS_STOP = 1;
            m_last_tx_attempts = m_config_local.retransmit_count - m_retransmits_remaining + 1;
            if (m_config_local.protocol != NRF_ESB_PROTOCOL_ESB && m_rx_payload_buffer[0] > 0)
                if (rx_fifo_push_rfbuf((uint8_t)NRF_RADIO->TXADDRESS, m_rx_payload_buffer[1] >> 1))
                    m_interrupt_flags |= NRF_ESB_INT_RX_DATA_RECEIVED_MSK;
            if ((m_tx_fifo.count == 0) || (m_config_local.tx_mode == NRF_ESB_TXMODE_MANUAL))
            if (m_retransmits_remaining-- == 0)
                // All retransmits are expended, and the TX operation is suspended
                m_last_tx_attempts = m_config_local.retransmit_count + 1;
                m_interrupt_flags |= NRF_ESB_INT_TX_FAILED_MSK;
                // There are still more retransmits left, TX mode should be
                // entered again as soon as the system timer reaches CC[1].
                NRF_ESB_SYS_TIMER->TASKS_START = 1;
                NRF_PPI->CHENSET = (1 << NRF_ESB_PPI_TX_START);
                if (NRF_ESB_SYS_TIMER->EVENTS_COMPARE[1])
    static void clear_events_restart_rx(void)
        NRF_RADIO->TASKS_DISABLE = 1;
        while (NRF_RADIO->EVENTS_DISABLED == 0);
        NRF_RADIO->SHORTS = m_radio_shorts_common | RADIO_SHORTS_DISABLED_TXEN_Msk;
        NRF_RADIO->TASKS_RXEN = 1;
        bool            ack                = false;
        bool            retransmit_payload = false;
        bool            send_rx_event      = true;
        pipe_info_t *   p_pipe_info;
        if (NRF_RADIO->CRCSTATUS == 0)
            clear_events_restart_rx();
            return;
        if (m_rx_fifo.count >= NRF_ESB_RX_FIFO_SIZE)
            return;
        p_pipe_info = &m_rx_pipe_info[NRF_RADIO->RXMATCH];
        if (NRF_RADIO->RXCRC             == p_pipe_info->crc &&
            (m_rx_payload_buffer[2] >> 1) == p_pipe_info->pid   //Moved 1 byte. Changed from 1 to 2.
            retransmit_payload = true;
            send_rx_event = false;
        p_pipe_info->pid = m_rx_payload_buffer[2] >> 1;  //Moved 1 byte. Changed from 1 to 2.
        p_pipe_info->crc = NRF_RADIO->RXCRC;
        if ((m_config_local.selective_auto_ack == false) || ((m_rx_payload_buffer[2] & 0x01) == 1)) //Moved 1 byte. Changed from 1 to 2.
            ack = true;
        if (ack)
                        if (m_tx_fifo.count > 0 &&
                            (m_tx_fifo.p_payload[m_tx_fifo.exit_point]->pipe == NRF_RADIO->RXMATCH)
                            // Pipe stays in ACK with payload until TX FIFO is empty
                            // Do not report TX success on first ack payload or retransmit
                            if (p_pipe_info->ack_payload == true && !retransmit_payload)
                                m_tx_fifo.count--;
                                // ACK payloads also require TX_DS
                                // (page 40 of the 'nRF24LE1_Product_Specification_rev1_6.pdf').
                            p_pipe_info->ack_payload = true;
    						m_tx_payload_buffer[0] = S0BYTE; // Setting to S0BYTE
                            m_tx_payload_buffer[1] = mp_current_payload->length;   //Moved 1 byte. Changed from 0 to 1.
                            memcpy(&m_tx_payload_buffer[3],   //Moved 1 byte. Changed from 2 to 3.
                            p_pipe_info->ack_payload = false;
                            m_tx_payload_buffer[1] = 0; //Moved 1 byte. Changed from 0 to 1.
                        m_tx_payload_buffer[2] = m_rx_payload_buffer[2]; //Moved 1 byte. Changed from 1 to 2.
                case NRF_ESB_PROTOCOL_ESB: //Using DPL. No changes
                        m_tx_payload_buffer[0] = m_rx_payload_buffer[0];
            m_nrf_esb_mainstate = NRF_ESB_STATE_PRX_SEND_ACK;
            NRF_RADIO->TXADDRESS = NRF_RADIO->RXMATCH;
            on_radio_disabled = on_radio_disabled_rx_ack;
        if (send_rx_event)
            // Push the new packet to the RX buffer and trigger a received event if the operation was
            // successful.
            if (rx_fifo_push_rfbuf(NRF_RADIO->RXMATCH, p_pipe_info->pid))
        on_radio_disabled = on_radio_disabled_rx;
        m_nrf_esb_mainstate = NRF_ESB_STATE_PRX;
    /**@brief Function for clearing pending interrupts.
     * @param[in,out]   p_interrupts        Pointer to the value that holds the current interrupts.
     * @retval  NRF_SUCCESS                     If the interrupts were cleared successfully.
     * @retval  NRF_ERROR_NULL                  If the required parameter was NULL.
     * @retval  NRF_INVALID_STATE               If the module is not initialized.
    static uint32_t nrf_esb_get_clear_interrupts(uint32_t * p_interrupts)
        VERIFY_TRUE(m_esb_initialized, NRF_ERROR_INVALID_STATE);
        VERIFY_PARAM_NOT_NULL(p_interrupts);
        DISABLE_RF_IRQ();
        *p_interrupts = m_interrupt_flags;
        ENABLE_RF_IRQ();
        return NRF_SUCCESS;
    void RADIO_IRQHandler()
        if (NRF_RADIO->EVENTS_READY && (NRF_RADIO->INTENSET & RADIO_INTENSET_READY_Msk))
            NRF_RADIO->EVENTS_READY = 0;
            DEBUG_PIN_SET(DEBUGPIN1);
        if (NRF_RADIO->EVENTS_END && (NRF_RADIO->INTENSET & RADIO_INTENSET_END_Msk))
            DEBUG_PIN_SET(DEBUGPIN2);
            // Call the correct on_radio_end function, depending on the current protocol state
            if (on_radio_end)
                on_radio_end();
        if (NRF_RADIO->EVENTS_DISABLED && (NRF_RADIO->INTENSET & RADIO_INTENSET_DISABLED_Msk))
            DEBUG_PIN_SET(DEBUGPIN3);
            // Call the correct on_radio_disable function, depending on the current protocol state
            if (on_radio_disabled)
                on_radio_disabled();
        DEBUG_PIN_CLR(DEBUGPIN1);
        DEBUG_PIN_CLR(DEBUGPIN2);
        DEBUG_PIN_CLR(DEBUGPIN3);
        DEBUG_PIN_CLR(DEBUGPIN4);
    uint32_t nrf_esb_init(nrf_esb_config_t const * p_config)
        uint32_t err_code;
        VERIFY_PARAM_NOT_NULL(p_config);
        if (m_esb_initialized)
            err_code = nrf_esb_disable();
            if (err_code != NRF_SUCCESS)
                return err_code;
        m_event_handler = p_config->event_handler;
        memcpy(&m_config_local, p_config, sizeof(nrf_esb_config_t));
        memset(m_rx_pipe_info, 0, sizeof(m_rx_pipe_info));
        memset(m_pids, 0, sizeof(m_pids));
        VERIFY_TRUE(update_radio_parameters(), NRF_ERROR_INVALID_PARAM);
        // Configure radio address registers according to ESB default values
        NRF_RADIO->BASE0   = 0xE7E7E7E7;
        NRF_RADIO->BASE1   = 0x43434343;
        NRF_RADIO->PREFIX0 = 0x23C343E7;
        NRF_RADIO->PREFIX1 = 0x13E363A3;
        initialize_fifos();
        sys_timer_init();
        ppi_init();
        NVIC_SetPriority(RADIO_IRQn, m_config_local.radio_irq_priority & ESB_IRQ_PRIORITY_MSK);
        NVIC_SetPriority(ESB_EVT_IRQ, m_config_local.event_irq_priority & ESB_IRQ_PRIORITY_MSK);
        NVIC_EnableIRQ(ESB_EVT_IRQ);
    #ifdef NRF52
        if(m_address_hang_fix_enable)
            // Setup a timeout timer to start on an ADDRESS match, and stop on a BCMATCH event.
            // If the BCMATCH event never occurs the CC[0] event will fire, and the timer interrupt will disable the radio to recover.
            m_radio_shorts_common |= RADIO_SHORTS_ADDRESS_BCSTART_Msk;
            NRF_RADIO->BCC = 2;
            NRF_ESB_BUGFIX_TIMER->BITMODE = TIMER_BITMODE_BITMODE_32Bit << TIMER_BITMODE_BITMODE_Pos;
            NRF_ESB_BUGFIX_TIMER->PRESCALER = 4;
            NRF_ESB_BUGFIX_TIMER->CC[0] = 5;
            NRF_ESB_BUGFIX_TIMER->SHORTS = TIMER_SHORTS_COMPARE0_STOP_Msk | TIMER_SHORTS_COMPARE0_CLEAR_Msk;
            NRF_ESB_BUGFIX_TIMER->MODE = TIMER_MODE_MODE_Timer << TIMER_MODE_MODE_Pos;
            NRF_ESB_BUGFIX_TIMER->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
            NRF_ESB_BUGFIX_TIMER->TASKS_CLEAR = 1;
            NVIC_SetPriority(NRF_ESB_BUGFIX_TIMER_IRQn, 5);
            NVIC_EnableIRQ(NRF_ESB_BUGFIX_TIMER_IRQn);
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX1].EEP = (uint32_t)&NRF_RADIO->EVENTS_ADDRESS;
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX1].TEP = (uint32_t)&NRF_ESB_BUGFIX_TIMER->TASKS_START;
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX2].EEP = (uint32_t)&NRF_RADIO->EVENTS_BCMATCH;
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX2].TEP = (uint32_t)&NRF_ESB_BUGFIX_TIMER->TASKS_STOP;
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX3].EEP = (uint32_t)&NRF_RADIO->EVENTS_BCMATCH;
            NRF_PPI->CH[NRF_ESB_PPI_BUGFIX3].TEP = (uint32_t)&NRF_ESB_BUGFIX_TIMER->TASKS_CLEAR;
            NRF_PPI->CHENSET = (1 << NRF_ESB_PPI_BUGFIX1) | (1 << NRF_ESB_PPI_BUGFIX2) | (1 << NRF_ESB_PPI_BUGFIX3);
        m_esb_initialized = true;
        return NRF_SUCCESS;
    uint32_t nrf_esb_suspend(void)
        VERIFY_TRUE(m_nrf_esb_mainstate == NRF_ESB_STATE_IDLE, NRF_ERROR_BUSY);
        // Clear PPI
                           (1 << NRF_ESB_PPI_TIMER_STOP)  |
        return NRF_SUCCESS;
    uint32_t nrf_esb_disable(void)
        // Clear PPI
        reset_fifos();
        // Disable the radio
        NVIC_DisableIRQ(ESB_EVT_IRQ);
        NRF_RADIO->SHORTS = RADIO_SHORTS_READY_START_Enabled << RADIO_SHORTS_READY_START_Pos |
                            RADIO_SHORTS_END_DISABLE_Enabled << RADIO_SHORTS_END_DISABLE_Pos;
        return NRF_SUCCESS;
    bool nrf_esb_is_idle(void)
        return m_nrf_esb_mainstate == NRF_ESB_STATE_IDLE;
    void ESB_EVT_IRQHandler(void)
        ret_code_t      err_code;
        uint32_t        interrupts;
        nrf_esb_evt_t   event;
        event.tx_attempts = m_last_tx_attempts;
        err_code = nrf_esb_get_clear_interrupts(&interrupts);
        if (err_code == NRF_SUCCESS && m_event_handler != 0)
            if (interrupts & NRF_ESB_INT_TX_SUCCESS_MSK)
                event.evt_id = NRF_ESB_EVENT_TX_SUCCESS;
                m_event_handler(&event);
            if (interrupts & NRF_ESB_INT_TX_FAILED_MSK)
                event.evt_id = NRF_ESB_EVENT_TX_FAILED;
            if (interrupts & NRF_ESB_INT_RX_DATA_RECEIVED_MSK)
                event.evt_id = NRF_ESB_EVENT_RX_RECEIVED;
    uint32_t nrf_esb_write_payload(nrf_esb_payload_t const * p_payload)
        VERIFY_PARAM_NOT_NULL(p_payload);
        VERIFY_PAYLOAD_LENGTH(p_payload);
        VERIFY_FALSE(m_tx_fifo.count >= NRF_ESB_TX_FIFO_SIZE, NRF_ERROR_NO_MEM);
        VERIFY_TRUE(p_payload->pipe < NRF_ESB_PIPE_COUNT, NRF_ERROR_INVALID_PARAM);
        DISABLE_RF_IRQ();
        memcpy(m_tx_fifo.p_payload[m_tx_fifo.entry_point], p_payload, sizeof(nrf_esb_payload_t));
        m_pids[p_payload->pipe] = (m_pids[p_payload->pipe] + 1) % (NRF_ESB_PID_MAX + 1);
        m_tx_fifo.p_payload[m_tx_fifo.entry_point]->pid = m_pids[p_payload->pipe];
        if (++m_tx_fifo.entry_point >= NRF_ESB_TX_FIFO_SIZE)
        m_tx_fifo.count++;
        ENABLE_RF_IRQ();
        if (m_config_local.mode == NRF_ESB_MODE_PTX &&
            m_config_local.tx_mode == NRF_ESB_TXMODE_AUTO &&
            m_nrf_esb_mainstate == NRF_ESB_STATE_IDLE)
        return NRF_SUCCESS;
    uint32_t nrf_esb_read_rx_payload(nrf_esb_payload_t * p_payload)
        if (m_rx_fifo.count == 0)
            return NRF_ERROR_NOT_FOUND;
        DISABLE_RF_IRQ();
        p_payload->length = m_rx_fifo.p_payload[m_rx_fifo.exit_point]->length;
        p_payload->pipe   = m_rx_fifo.p_payload[m_rx_fifo.exit_point]->pipe;
        p_payload->rssi   = m_rx_fifo.p_payload[m_rx_fifo.exit_point]->rssi;
        p_payload->pid    = m_rx_fifo.p_payload[m_rx_fifo.exit_point]->pid;
        p_payload->noack  = m_rx_fifo.p_payload[m_rx_fifo.exit_point]->noack;
        memcpy(p_payload->data, m_rx_fifo.p_payload[m_rx_fifo.exit_point]->data, p_payload->length);
        if (++m_rx_fifo.exit_point >= NRF_ESB_RX_FIFO_SIZE)
        m_rx_fifo.count--;
        ENABLE_RF_IRQ();
        return NRF_SUCCESS;
    uint32_t nrf_esb_start_tx(void)
            return NRF_ERROR_BUFFER_EMPTY;
        return NRF_SUCCESS;
    uint32_t nrf_esb_start_rx(void)
        NRF_RADIO->INTENCLR = 0xFFFFFFFF;
        NRF_RADIO->RXADDRESSES  = m_esb_addr.rx_pipes_enabled;
        return NRF_SUCCESS;
    uint32_t nrf_esb_stop_rx(void)
        if (m_nrf_esb_mainstate == NRF_ESB_STATE_PRX)
            NRF_RADIO->SHORTS = 0;
            on_radio_disabled = NULL;
            return NRF_SUCCESS;
        return NRF_ESB_ERROR_NOT_IN_RX_MODE;
    uint32_t nrf_esb_flush_tx(void)
        DISABLE_RF_IRQ();
        ENABLE_RF_IRQ();
        return NRF_SUCCESS;
    uint32_t nrf_esb_pop_tx(void)
        VERIFY_TRUE(m_tx_fifo.count > 0, NRF_ERROR_BUFFER_EMPTY);
        DISABLE_RF_IRQ();
        m_tx_fifo.count--;
        ENABLE_RF_IRQ();
        return NRF_SUCCESS;
    uint32_t nrf_esb_flush_rx(void)
        DISABLE_RF_IRQ();
        ENABLE_RF_IRQ();
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_address_length(uint8_t length)
        VERIFY_TRUE(length > 2 && length < 6, NRF_ERROR_INVALID_PARAM);
        Workaround for nRF52832 Rev 1 Errata 107
        Check if pipe 0 or pipe 1-7 has a 'zero address'.
        Avoid using access addresses in the following pattern (where X is don't care):
        ADDRLEN=5
        BASE0 = 0x0000XXXX, PREFIX0 = 0xXXXXXX00
        BASE1 = 0x0000XXXX, PREFIX0 = 0xXXXX00XX
        BASE1 = 0x0000XXXX, PREFIX0 = 0xXX00XXXX
        BASE1 = 0x0000XXXX, PREFIX0 = 0x00XXXXXX
        BASE1 = 0x0000XXXX, PREFIX1 = 0xXXXXXX00
        BASE1 = 0x0000XXXX, PREFIX1 = 0xXXXX00XX
        BASE1 = 0x0000XXXX, PREFIX1 = 0xXX00XXXX
        BASE1 = 0x0000XXXX, PREFIX1 = 0x00XXXXXX
        ADDRLEN=4
        BASE0 = 0x00XXXXXX, PREFIX0 = 0xXXXXXX00
        BASE1 = 0x00XXXXXX, PREFIX0 = 0xXXXX00XX
        BASE1 = 0x00XXXXXX, PREFIX0 = 0xXX00XXXX
        BASE1 = 0x00XXXXXX, PREFIX0 = 0x00XXXXXX
        BASE1 = 0x00XXXXXX, PREFIX1 = 0xXXXXXX00
        BASE1 = 0x00XXXXXX, PREFIX1 = 0xXXXX00XX
        BASE1 = 0x00XXXXXX, PREFIX1 = 0xXX00XXXX
        BASE1 = 0x00XXXXXX, PREFIX1 = 0x00XXXXXX
        uint32_t base_address_mask = length == 5 ? 0xFFFF0000 : 0xFF000000;
        if((NRF_RADIO->BASE0 & base_address_mask) == 0 && (NRF_RADIO->PREFIX0 & 0x000000FF) == 0)
            return NRF_ERROR_INVALID_PARAM;
        if((NRF_RADIO->BASE1 & base_address_mask) == 0 && ((NRF_RADIO->PREFIX0 & 0x0000FF00) == 0 ||(NRF_RADIO->PREFIX0 & 0x00FF0000) == 0 || (NRF_RADIO->PREFIX0 & 0xFF000000) == 0 ||
           (NRF_RADIO->PREFIX1 & 0xFF000000) == 0 || (NRF_RADIO->PREFIX1 & 0x00FF0000) == 0 ||(NRF_RADIO->PREFIX1 & 0x0000FF00) == 0 || (NRF_RADIO->PREFIX1 & 0x000000FF) == 0))
        m_esb_addr.addr_length = length;
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_base_address_0(uint8_t const * p_addr)
        VERIFY_PARAM_NOT_NULL(p_addr);
        ADDRLEN=5
        ADDRLEN=4
        uint32_t base_address_mask = m_esb_addr.addr_length == 5 ? 0xFFFF0000 : 0xFF000000;
        if((addr_conv(p_addr) & base_address_mask) == 0 && (NRF_RADIO->PREFIX0 & 0x000000FF) == 0)
        memcpy(m_esb_addr.base_addr_p0, p_addr, 4);
        update_radio_addresses(NRF_ESB_ADDR_UPDATE_MASK_BASE0);
        return apply_address_workarounds();
    uint32_t nrf_esb_set_base_address_1(uint8_t const * p_addr)
        ADDRLEN=5
        ADDRLEN=4
        if((addr_conv(p_addr) & base_address_mask) == 0 && ((NRF_RADIO->PREFIX0 & 0x0000FF00) == 0 ||(NRF_RADIO->PREFIX0 & 0x00FF0000) == 0 || (NRF_RADIO->PREFIX0 & 0xFF000000) == 0 ||
        memcpy(m_esb_addr.base_addr_p1, p_addr, 4);
        update_radio_addresses(NRF_ESB_ADDR_UPDATE_MASK_BASE1);
    uint32_t nrf_esb_set_prefixes(uint8_t const * p_prefixes, uint8_t num_pipes)
        VERIFY_PARAM_NOT_NULL(p_prefixes);
        VERIFY_TRUE(num_pipes < 9, NRF_ERROR_INVALID_PARAM);
        ADDRLEN=5
        ADDRLEN=4
        if(num_pipes >= 1 && (NRF_RADIO->BASE0 & base_address_mask) == 0 && p_prefixes[0] == 0)
        if((NRF_RADIO->BASE1 & base_address_mask) == 0)
            for (uint8_t i = 1; i < num_pipes; i++)
                if (p_prefixes[i] == 0)
        memcpy(m_esb_addr.pipe_prefixes, p_prefixes, num_pipes);
        m_esb_addr.num_pipes = num_pipes;
        m_esb_addr.rx_pipes_enabled = BIT_MASK_UINT_8(num_pipes);
        update_radio_addresses(NRF_ESB_ADDR_UPDATE_MASK_PREFIX);
    uint32_t nrf_esb_update_prefix(uint8_t pipe, uint8_t prefix)
        VERIFY_TRUE(pipe < 8, NRF_ERROR_INVALID_PARAM);
        ADDRLEN=5
        ADDRLEN=4
        if (pipe == 0)
            if((NRF_RADIO->BASE0 & base_address_mask) == 0 && prefix == 0)
        else{
            if((NRF_RADIO->BASE1 & base_address_mask) == 0 && prefix == 0)
        m_esb_addr.pipe_prefixes[pipe] = prefix;
    uint32_t nrf_esb_enable_pipes(uint8_t enable_mask)
        m_esb_addr.rx_pipes_enabled = enable_mask;
    uint32_t nrf_esb_set_rf_channel(uint32_t channel)
        VERIFY_TRUE(channel <= 100, NRF_ERROR_INVALID_PARAM);
        m_esb_addr.rf_channel = channel;
        return NRF_SUCCESS;
    uint32_t nrf_esb_get_rf_channel(uint32_t * p_channel)
        VERIFY_PARAM_NOT_NULL(p_channel);
        *p_channel = m_esb_addr.rf_channel;
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_tx_power(nrf_esb_tx_power_t tx_output_power)
        if ( m_config_local.tx_output_power != tx_output_power )
            m_config_local.tx_output_power = tx_output_power;
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_retransmit_delay(uint16_t delay)
        VERIFY_TRUE(delay >= NRF_ESB_RETRANSMIT_DELAY_MIN, NRF_ERROR_INVALID_PARAM);
        m_config_local.retransmit_delay = delay;
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_retransmit_count(uint16_t count)
        m_config_local.retransmit_count = count;
        return NRF_SUCCESS;
    uint32_t nrf_esb_set_bitrate(nrf_esb_bitrate_t bitrate)
        m_config_local.bitrate = bitrate;
        return update_radio_bitrate() ? NRF_SUCCESS : NRF_ERROR_INVALID_PARAM;
    uint32_t nrf_esb_reuse_pid(uint8_t pipe)
        m_pids[pipe] = (m_pids[pipe] + NRF_ESB_PID_MAX) % (NRF_ESB_PID_MAX + 1);
        return NRF_SUCCESS;
    // Handler for
    #ifdef NRF52
    void NRF_ESB_BUGFIX_TIMER_IRQHandler(void)
        if(NRF_ESB_BUGFIX_TIMER->EVENTS_COMPARE[0])
            NRF_ESB_BUGFIX_TIMER->EVENTS_COMPARE[0] = 0;
            // If the timeout timer fires and we are in the PTX receive ACK state, disable the radio
            if(m_nrf_esb_mainstate == NRF_ESB_STATE_PTX_RX_ACK)
