hai, i am using sdk-v-12.3.0 for nrf52832-pca10040,
I connected the SOC to PC using Daplink.Now,i want to just print "hello world " on the /dev/ttyACM0.could any one please assist me.
No luck.Its like hell.waste of time
When you mention that you use daplink, do you mean using the nRF52-DK with this firmware instead of the default segger fw?
Could you try to use segger's firmware instead and see if that works?
Finally myself i did R&D and solved the problem.its all about changing the pin numbers in main.c and some configurations related to UART in sdk_config.h.Below was the change in my main.c file
static void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
.rx_pin_no = 30,
.tx_pin_no = 29,
.rts_pin_no = 2,
.cts_pin_no = 28,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
And just use printf(); in order to print string
printf("\r\nhello world\r\n");
And also make sure that your sdk_config.h file must be like attached file
