Hello, how can I increase LOG backend queue size? I was comparing some sdk_config settings with some examples, but did not find difference and the example does not fire this message. I am not logging much more info than the example.
Thank you.
Thank you.
I have tested several combinations and have found out following: the problematic code is probably the NRF_LOG_HEXDUMP_INFO.
When using this NRF_LOG_HEXDUMP_INFO, I can not increase the queue size and I get the "lost logs" error. If I increase the queue size, the program fails somewhere (I can't see the leds blinking which indicates normal operation).
When I commented ou the NRF_LOG_HEXDUMP_INFO, I could increase the queue size without having the program crash and I do not have the "lost logs" error.
I did not need
Any idea why? Could this some bug in the NRF_LOG_HEXDUMP_INFO?
I have fixed it. Unfortunately don't know how and why. I just took the sdk_config.h file from the flash_fstorage example and compiled my project. Now everything seems to work fine.
I tried to compare my sdk_config with the one in the flash_fstorage but I failed. This is something what should be improved somehow - the documentation of sdk_config.
May you please share with us the sdk_config.h file which was causing the problem?
Unfortunately I did not make a backup of the faulty sdk_config at the moment when I found the solution. But I have found something that is causing the same problem, see attached. Hope it helps.
I have the same problem. Is there any known solution which won't affect whole sdk_config.h file?
