sd_ble_gap_sec_params_reply() returns NRF_ERROR_INVALID_STATE
I have an nRF51822 application using the Soft Device 110. I want to perform bonding with a central without MITM protection. In my on_ble_evt() event handler, when the event ID is BLE_GAP_EVT_SEC_PARAMS_REQUEST, I reply in the same fashion as one of the example apps, like this:
        err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                               BLE_GAP_SEC_STATUS_SUCCESS,
                                               &m_sec_params);
The error_code is then 8, which is NRF_ERROR_INVALID_STATE.
The m_sec_params have earlier been set to these values:
#define SEC_PARAM_TIMEOUT                 30                                                /**< Timeout for Pairing Request or Security Request (in seconds). */
#define SEC_PARAM_BOND                    1                                                 /**< Perform bonding. */
#define SEC_PARAM_MITM                    0                                                 /**< Man In The Middle protection NOT required. */
#define SEC_PARAM_IO_CAPABILITIES         BLE_GAP_IO_CAPS_NONE                              /**< No I/O capabilities. */
#define SEC_PARAM_OOB                     0                                                 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE            7                                                 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE            16                                                /**< Maximum encryption key size. */
m_conn_handle has been set earlier on, when the BLE_GAP_EVT_CONNECTED event comes into the same handler, like this:
I also know the connection event has happened, from my logs:
sd_app_evt_wait()
sd_app_evt_wait()
DM_EVT_CONNECTION
sd_app_evt_wait()
DM_EVT_SECURITY_SETUP
How can I tell what's invalid about the state I'm in? The central is an Android app and is my code.
