Issue when calling "ble_nus_c_string_send" multiple times to send multiple single bytes
I am using the ble_app_uart_c example for the ble_central of SDK 12.2.0 to send data over UART to a nrf52832 based peripheral. When following the format as suggested in the example everything appears to be working fine (terminate data to be sent with \n). I sucessfully sent commands with 60 bytes and \n terminated spread across 3 BLE packets at 20 bytes payload each.
However, when commenting out the section that tests for \n or size>20 bytes my code stops working (see attached code snippet). I am basically trying to force sending each individual byte,  not only when certain conditions are met. When sending small amounts (less than 5 bytes) it still works ok, but when sending more than 5 bytes the code seems to be stuck at line "while (ble_nus_c_string_send(&m_ble_nus_c, data_array, index) != NRF_SUCCESS)" and I am struggling to find out why. Could someone please point me in the right direction?
    static uint8_t index = 0;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            //if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    // repeat until sent.
                index = 0;
        case APP_UART_FIFO_ERROR:
