I need to configure 2 devices as relay nodes in order to relay messages from the client node to the server node
How can i implement this in the light switch example ?
Yes
Does the addresses of the 2 relay nodes have to be assigned in order by the provisioner so they can correctly relay messages from one server to another or there is no problem having for example relay node with 0x0107 and server node with 0x105?
Hi, I do not believe this will be an issue. I would suggest you to test this out yourself to make sure this works. You may need to lower the output power of the devices to test this properly. You can do this by using the sd_ble_gap_tx_power_set() function or by changing the tx power register directly in the radio_config_config() function: NRF_RADIO->TXPOWER = p_config->tx_power;
hi
where can i find network_init() function to set m_relay_enable true.
Which version of the mesh sdk are you using? This method only works for old mesh sdk versions.
