BLE Bootloader Example not Advertising on BLE Nano
i'm using the BLE Nano v2 with the nrf52832 on it and a DAPLink USB-Dongle. IDE is Eclipse with gcc and SDK v14.2. My current aim is to do an OTA DFU so I tried the bootloader_secure_ble example following these steps: devzone.nordicsemi.com/.../getting-started-with-nordics-secure-dfu-bootloader
I've customised the leds_init() & buttons_init() function to match my board, updated the dfu_public_key.c file and flashed it together with the s132 softdevice v4.0, my application and a settings page via drag and drop. My application runs fine and I also get into dfu mode by pressing the button -> LED lights up. But there's no advertising. Also, if in dfu mode, the bootloader doesn't jump back to my application after the time specified in the sdk_config.
I don't know what I'm doing wrong, but I think it must be something essential.. Hope you can give me some help.
Thanks in advance
Markus
    no i haven't a crystal externally, but it is mounted on the ble nano v2. Have a look at the schematic: https://github.com/redbear/nRF5x/blob/master/nRF52832/pcb/schematic/Nano%20V2.0%20SCH%2020161102.pdf
    component Y1
    I didn't change the settings of the clock in the sdk_config file. Here are my settings, they should have all the default value:
    // <h> nRF_Drivers
    // <e> CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver
    #ifndef CLOCK_ENABLED
    #define CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_XTAL_FREQ  - HF XTAL Frequency
    // <0=> Default (64 MHz)
    #ifndef CLOCK_CONFIG_XTAL_FREQ
    #define CLOCK_CONFIG_XTAL_FREQ 0
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 1
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 7
    // </e>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 1
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY  - External crystal clock accuracy used in the LL to compute timing windows.
    // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
    // </h>
    I've anbled logging functionality on the clock module in the sdk_config, here is the new log:
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: In real nrf_dfu_init
    <debug> nrf_dfu_settings: Running nrf_dfu_settings_init(sd_irq_initialized=false).
    <debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=false)...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> app: Initializing the clock.
    <info> clock: Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
    <debug> app: Enter nrf_dfu_continue
    <error> app: Single: Invalid bank
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: Return false in valid app check
    There's one more entry now, which says: drv_clock_init -> success.
    Because of the debugging, I don't know exactly where and when an error happens because no real error messages occur except of the "Single: Invalid bank" log message. Is that message normal, because there was no valid application found?
  • Please double check if you have the 32kHz crystal or not. I worries the schematics you sent is just a reference schematic of what you should have to use the module (for example the 16MHz crystal is not in the schematic).
    It could be very easy to test by just testing with a normal BLE example that use 32kHz crystal in our SDK.
    "Invalid bank" is normal as you don't have valid application before a successful DFU.
  • I tested the ble_app_blinky example and it seems to work fine. It advertises, I can connect to it, read, write, .. no problem. But does it use the 32 kHz crystal?
    Here you can see the bottom side of the ble nano v2. These are all the parts mounted on it. On the top side is only a yellow LED and a resistor connected to P0_11 and of course the nrf52832. But I think the part in the lower right corner is the crystal.
  • I ran the bootloader with softdevice in debug mode and paused the debugger when in dfu mode. Here's the call stack at this time, maybe this information is useful:
  • I solved the issue: I used the nrf connect app on a pixel c tablet with the current version of android. Now I tried an ipad mini with iOS 11.3 and it worked. I saw the davice advertising in bootloader mode and could update the application. I still don't know why the app on android doesn't detect the device in bootloader mode but while running an application...
