The Saadc of issue of uninit
i init the saadc and uinit saadc ,then init saadc again. my code is below:
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config_se1);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool, 1);
 nrf_drv_saadc_uninit();
from now .the err_code is correct .
But when i use nrf_drv_saadc_sample(), geting a error in SAADC_IRQHandler. And this is my callback:
nrf_drv_saadc_buffer_convert(m_buffer_pool,1);
In SAADC_IRQHandler, the code enter in below:
if (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STOPPED));
m_cb.adc_state = NRF_SAADC_STATE_IDLE;
if i dont use  nrf_drv_saadc_uninit(),there is greater.
what i can do???
  • nrf_drv_saadc_uninit() function code has some bugs as below:
    nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP);
    Wait for ADC being stopped.
    uint32_t timeout = HW_TIMEOUT;
    while (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED) == 0 && timeout > 0)
      --timeout;
      --timeout;
    the code cant check the stop interrput ,as init some bugs in next init code.
  • What do you mean by this: "the code cant check the stop interrput ,as init some bugs in next init code"? Are you actually checking the error codes from your calls to nrf_drv_saadc_*, or are they only assigned? You say you get error 0x08 when calling nrf_drv_saadc_sample, this indicate that the driver is in IDLE state, normally because no buffer have been setup. You should have received an error code when you called one of the nrf_drv_saadc_* functions.
  • I guess the problem is inside the SAADC_IRQHandler. When using the uninit inside the callback there is a NRF_SAADC_EVENT_STOPPED event created. As the handling of the end event in line 117 (nRF5_SDK_12.3.0_d7731ad) is not terminating the IRQ function, the stop event is handled in line 190, setting the state of the driver to NRF_SAADC_STATE_IDLE after the reinit has been performed in the callback. The next call to nrf_drv_saadc_sample is then creating the invalid state error.
    Solution: In SAADC_IRQHandler use else if to handle each kind of event:
    void SAADC_IRQHandler(void)
        if (nrf_saadc_event_check(NRF_SAADC_EVENT_END))
            nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
            NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_END));
            if (!m_cb.low_power_mode || m_cb.conversions_end)
                nrf_drv_saadc_evt_t evt;
                evt.type               = NRF_DRV_SAADC_EVT_DONE;
                evt.data.done.p_buffer = (nrf_saadc_value_t *)m_cb.p_buffer;
                evt.data.done.size     = m_cb.buffer_size;
                if (m_cb.p_secondary_buffer == NULL)
                    m_cb.buffer_size_left   = m_cb.secondary_buffer_size;
                    m_cb.p_buffer           = m_cb.p_secondary_buffer;
                    m_cb.buffer_size        = m_cb.secondary_buffer_size;
                    m_cb.p_secondary_buffer = NULL;
                    if (!m_cb.low_power_mode)
                        nrf_saadc_task_trigger(NRF_SAADC_TASK_START);
                m_cb.event_handler(&evt);
                m_cb.conversions_end = false;
        else if (m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
            nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
            NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STARTED));
            if (m_cb.buffer_size_left > m_cb.active_channels)
                // More samples to convert than for single event.
                m_cb.buffer_size_left -= m_cb.active_channels;
                nrf_saadc_buffer_init((nrf_saadc_value_t *)&m_cb.p_buffer[m_cb.buffer_size -
        m_cb.buffer_size_left],
                                      m_cb.active_channels);
            else if ((m_cb.buffer_size_left == m_cb.active_channels) &&
                     (m_cb.p_secondary_buffer != NULL))
                // Samples to convert for one event, prepare next buffer.
                m_cb.conversions_end  = true;
                m_cb.buffer_size_left = 0;
                nrf_saadc_buffer_init((nrf_saadc_value_t *)m_cb.p_secondary_buffer,
            else if (m_cb.buffer_size_left == m_cb.active_channels)
                // Samples to convert for one event, but no second buffer.
            nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE);
        else if (nrf_saadc_event_check(NRF_SAADC_EVENT_CALIBRATEDONE))
            nrf_saadc_event_clear(NRF_SAADC_EVENT_CALIBRATEDONE);
            NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_CALIBRATEDONE));
            evt.type = NRF_DRV_SAADC_EVT_CALIBRATEDONE;
        else if (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
            NRF_LOG_DEBUG("SAADC IRQ -- Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STOPPED));
            uint32_t          limit_flags = m_cb.limits_enabled_flags;
            uint32_t          flag_idx;
            nrf_saadc_event_t event;
            while (limit_flags)
                flag_idx     = __CLZ(limit_flags);
                limit_flags &= ~((1UL << 31) >> flag_idx);
                event        = FLAG_IDX_TO_EVENT(flag_idx);
                if (nrf_saadc_event_check(event))
                    nrf_saadc_event_clear(event);
                    evt.type                  = NRF_DRV_SAADC_EVT_LIMIT;
                    evt.data.limit.channel    = LIMIT_EVENT_TO_CHANNEL(event);
                    evt.data.limit.limit_type = LIMIT_EVENT_TO_LIMIT_TYPE(event);
                    NRF_LOG_DEBUG("Event limit, channel: %d, limit type: %s.\r\n", evt.data.limit.channel, (uint32_t)EVT_TO_STR(evt.data.limit.limit_type));
  • has this issue resolved in SDK 14 or SDK 15?
    Please reply.
  • I am facing the same issue as discussed above. I tried using else if case as suggested above and it solved the problem but I don't want to change the driver and would rather prefer use latest version of SDK if the problem is solved. I am using currently SDK 12. Kindly let me know if there is a SDK version which solves this issue.
