UART and Timer conflict
I am using SDK12 with nrf52832.  UART working fine (with FIFO)  and Timer1 also works.
I wanted to set a 1 minute timeout around the UART dialog to handle disconnection etc.
However, if I enable Timer1 when waiting for a response from the UART the timer responds as expected but the responses from the UART no longer occur.  Specifically, the UART's event handler is no longer called.
This looks like some kind of a conflict but I'm not sure where and why?
Thx.
    Glad you found a solution that worked for you. You can alternatively try to set a prescaler != 0, which will slow the timer down, if you want to use the timer directly.
    Edvin
  • hi, edvin i am also having some issues while merging the uart ,twi and timer , please help me . i am using nrf52382 segger 15version . see my code
    bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        advertising_start();
    twi_init();
      LM75B_set_mode();
    uint32_t time_ms = 50000; //Time(in miliseconds) between consecutive compare events.
        uint32_t time_ticks;
        uint32_t err_code = NRF_SUCCESS;
        //Configure all leds on board.
        //Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
       err_code = nrf_drv_timer_init(&TIMER_SENSOR, &timer_cfg, timer_sensor_event_handler);
          nrf_drv_timer_extended_compare(
             &TIMER_SENSOR, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
        time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_SENSOR, time_ms);
         NRF_LOG_INFO("SUCCESS1");
        // Start execution.
        while (true)
            nrf_delay_ms(6000);
           while (m_xfer_done == false);
             m_xfer_done = false;
    		uint8_t reg[2] = {0x00U};
            err_code = nrf_drv_twi_tx(&m_twi,LM75B_ADDR, reg, sizeof(reg), true);
    		nrf_delay_ms(5);
    		ret_code_t err_code1 = nrf_drv_twi_rx(&m_twi,LM75B_ADDR, &m_sample, sizeof(m_sample));
    		APP_ERROR_CHECK(err_code1);
                    NRF_LOG_INFO("%d", m_sample);
    I would need a better description. I suggest you create a separate ticket describing your issue, if you haven't done this already.
