keil erase softdevice hex when doing a clean build
For some reason when i do "project -> clean target" Keil deletes the softdevice Hex file in addition to the project compiled files.
Is that the normal behavior?
If so, is there a way to flash the SD from Keil (keep it in the project) but avoid the hex deletion?
thanks in advance,
Danny
  • Hi Aryan,
    I don't understand why wouldn't it delete as it is a hex file as part of the project.
    I use MDK version 5.25 which is newer and i don't think i should downgrade.
    I reached out to Keil support however they think like me that it is not a Keil bug. Their response was: "I'm not sure what do you mean by "soft device". If your hex file is stored in MDK project folder, it will be deleted by choosing "project -> clean targets""
    I know i am new to Keil and maybe i don't explain myself so can you please assist me regarding what i should tell Keil support that will convince them that it is a Keil issue and why shouldn't the softdevice HEX file get deleted when i call "clean targets"?
  • Found a workaround so i thought i should share.
    I changed the HEX file to "read only" in the file properties and it isn't being deleted anymore.
    Thanks anyway Slight smile
    Danny
