app_timer with scheduler
I want to use nested app_timer instances:  I am gathering data on a repeating app_timer (app_timer_1) which fires say every 10ms.  One of my sensors providing the data requires some time delay between requesting the data and it being ready, so I want to use a second app_timer (app_timer_2) to provide a low-power delay function. The delay can be of the order of 5ms.
Since app_timer_2 is being stated from app_timer_1 it isnt running because they have the same interrupt priority but timer_2 is running in the context of timer_1.  I believe the way to get around this is to use the scheduler.  However despite spending some time searching I cant find any examples of how to do this.  Documentation seems a bit sparse, and in places confusing.
For example, app_timer use in scheduler example here: https://devzone.nordicsemi.com/tutorials/b/software-development-kit/posts/scheduler-tutorial uses deprecated functions: app_timer_appsh no longer exists (I am using SDK 14.2).
Any help much appreciated!
  • Ideally not.  The first I am using to schedule measurements.  Second is to give time for measurement to take place in a particular sensor- in some cases the order of events within each measurement cycle can change, which impacts how much time the sensor has to take the measurement - measurement request from previous cycle could happen late in that cycle, resulting in a need to delay requesting the data.
    Is there any way to do this?  I can come up with something else if not.
  • There are probably better ways to do this. Do you have a datasheet for you sensor, or more information on how you interface with the sensor?
    The reason I ask is that you might not want to use the app_timer, or at least not in a blocking mode, depending on the sensor interface.
  • Thank you.
    I agree there are probably better ways.
    Interface is i2C.  I send a message asking to start measurement.  This takes 4.5ms to complete (depends on resolution) - if I request data before that I just get garbage.  I am running on a 10ms cycle time;  each cycle I read data then request new measurement.  I am doing other stuff within the cycle that could change from cycle to cycle, thus changing the timing of events.  I therefore want to be sure I am waiting the 4.5ms between request of previous cycle and read of current.
    So bottom line, is what I am asking just not possible?  Or not advisable?
  • It is definitely possible. I suggest you use RTC2 with the RTC HAL and driver to start a Two Wire master interface (TWI/TWIM) transfer via the PPI — Programmable peripheral interconnect system. Also see thePPI HAL and driver API documentation.
    The goal is to set up an RTC to trigger the NRF_TWIM_TASK_STARTTX task every 10ms. The TWIM will then transmit whatever is present in its TX buffer. You need to set up the sensor command beforehand with a call to nrf_twim_tx_buffer_set.
    You must also setup up the RTC to trigger the NRF_TWIM_TASK_STARTRX task every 4.5ms.
    When the RTC triggers the start TX event you need to also trigger a NRF_RTC_TASK_CLEAR . This will restart the RTC and create an endless loop of sensor sampling.
    See the RTC, TWIM, and PPI  examples in the SDK for implementation details.
