nRF52840 QSPI XIP and standby
I have been investigating the possibility of using the QSPI external flash peripheral on our NRF chip. After doing a typical qspi read command, the external flash chip would go back to standby mode which uses about 85uA. After doing a xip_function, which looks like a typical read command with a continuous read commands depending on the function, the external flash chip would not go back to standby. This results in 2.3 mA idle draw. The QSPI XIP is functioning but I am wondering why the flash does not go in standby after the XIP operation. I want to know if there is any way to save power while or between using XIP. Is there a way to modify software to ensure standby mode is done after any qspi operation?
Here is my configuration:
nRF52840, using Macronix MX25L12835F QSPI NOR flash,
Running with SDK14.0, using QSPI library. Dual SPI with mode 0, PP, READ2IO, 32Mhz.
  • Hi, QSPI will not go into standby and also the external Flash will not go into standby since the CSN line is kept low by the peripheral. A timeout that puts the QSPI into standby when there is no XiP operation for a certain time is a good feature request, but not implemented in any product so far.
    The only workaround that we could imagine is to use a timer/RTC as a watchdog. The CPU needs to clear/restart it from time to time. If it timeout it can trigger TASKS_DEACTIVATE on the QSPI. But then there also needs to be code to activate and initialize it again. Not very nice, but maybe worth for long times between XiP accesses.
