max30205 + nRF52 DK How to read more than 1 byte?
I have established a connection with max30205, but I get only the first byte of temperature, how to read the second one? to get the tenths of a degree.
Now it works like:
start / address / reading / stop
ret_code_t err_code1 = nrf_drv_twi_rx(&m_twi, max30205_address , &m_sample, sizeof(m_sample));
APP_ERROR_CHECK(err_code1);
while (m_xfer_done == false)
I necessary need :
start / address / reading / reading / stop
What function should be used for this?
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
//#include "nrf_twi_mngr.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          (0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    ret_code_t err_code;
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    reg[0] = LM75B_REG_TEMP;
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lm75b_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    LM75B_set_mode();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
		uint8_t reg[2] = {0x00U};
        err_code = nrf_drv_twi_tx(&m_twi, 0x48U, reg, sizeof(reg), true);
		nrf_delay_ms(5);
		ret_code_t err_code1 = nrf_drv_twi_rx(&m_twi, 0x48U, &m_sample, sizeof(m_sample));
		NRF_LOG_FLUSH();
