Error while programming bootloader on nRF52832 QFAB IC using nrfjprog
I have a custom board of nRF52832-QFAB-B0 on which my application works well with SDK15.0.0 & SD132 v6.0.0
To perform DFU,
1. I copied the relevant parts of ble_app_buttonless_dfu example,
2. Increased the vendor specific uuid count to 2 in the sdk_config, now that I have two services - custom service & DFU service.
3. Included the required libraries and headers into my project as prompted by the error messages in SEGGER embedded studio and ran.
4. Got the following error in my log: "missing bootloader"
To program bootloader, I followed the steps in infocenter:
1. Cleared the flash
nrfjprog wipe
2. Programmed the softdevice SD132 v6.0.0
nrfjprog program -d nrf52 -c ../../SDK_15.0.0/components/softdevice/s132/hex/s132_nrf52_6.0.0_softdevice.hex
3. Modified the secure_bootloader with the following settings in memory segments & linker. Memory map changed since my IC variant is nRF52832 QFAB-B0 with 256kB Flash & 32kB RAM
Common Linker -> Section Placement macros:
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x40000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x8000
FLASH_START=0x38000
FLASH_SIZE=0x6000
RAM_START=0x200057b8
RAM_SIZE=0x2848
Common Build->Memory segments:
FLASH RX 0x0 0x40000
RAM RWX 0x20000000 0x8000
uicr_mbr_params_page RX 0x10001018 0x4
mbr_params_page RX 0x0003E000 0x1000
bootloader_settings_page RX 0x0003F000 0x1000
uicr_bootloader_start_address RX 0x10001014 0x4
4. Generated the Bootloader settings hex file with the following command:
nrfutil settings generate --family NRF52QFAB --application pca10040/s132/ses/Output/Debug/Exe/ble_app_template_pca10040_s132.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex
5. Merged bootloader and settings file using mergehex
mergehex -m bootloader.hex settings.hex -o bootloader_settings.hex
6. Now to program the bootloader I use nrfjprog
./nrfjprog --reset --program ../mergehex/glo_bootloader_settings.hex --family NRF52 --sectoranduicrerase
which throws an error:
Parsing hex file.
ERROR: The file specified is not a valid hex file, has data outside valid areas
ERROR: or does not have data in valid areas.
  • Is it necessary to have an application in flash for bootloader to work? Or can we load the first application itself via DFU?
  • I tried the whole sequence from start again. The advertising works on QFAB board now. But when I connect using nrfConnect, it disconnects before service discovery.  Again, works well on DK - meaning I am able to send an application on DK via ble and on restart, the application runs.
    This time I made sure that the bootloader start address is correctly written on flash using a readback.
    ./nrfjprog --memrd 0x10001014
    0x10001014: 00038000
    ./nrfjprog --memrd 0x10001018
    0x10001018: 0003E000
    Could this have anything to do with my application size? It's pretty big (70KB after optimising for size. So 222KB taken for SD+App) and Softdevice+App takes 30.3KB of RAM according to SES compilation results.
  • Hi, I finally figured out.
    Apart from setting the BOOTLOADER_SETTINGS_ADDRESS, NRF_MBR_PARAMS_PAGE_ADDRESS, I had to make another change in sdk_config.h ( I didn't have to change BOOTLOADER_START_ADDR btw in SES project. It was pointing to CODE_START which I didn't have to change)
    There was one more difference between DK and my board apart from QFAA & QFAB. It's that my board did not have a 32KHz crystal.  Silly of me to not think about this.
    So I had to change the clock parameters of the sdk_config.h file.
    #define NRF_SDH_CLOCK_LF_SRC 0
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    #define NRF_SDH_CLOCK_LF_ACCURACY 7 //20_PPM
    Please let me know if these values are good.
  • Specifically I had to change this in the secure_bootloader project for the board to advertise as "DfuTarg". I am able to connect to it and load my application.zip via nrfConnect app.
    This generally seems good.
    The pages from 0x38000 to 0x3D000 are the bootloader.
    The page at 0x3E000 is left empty as it will be used for the MBR settings page.
    The page at 0x3F000 is the bootloader settings page.
    The defines look good at a glance as well.
    I will not dig any deeper into this as your latest message seems to indicate you figured it out.
