I'm looking for an example of how NRFX_UARTE works.
I would like to set up a serial port with EasyDMA to send and receive a thirty bytes.
Thanks in advance for your help.
Hi Häkon,
Thanks for your answer.
I'm sorry but I'm always lost. We have lots of files (app_uart, nrf_uarte,nrfx_uarte, ...)
I need to be closer to the nRF52832 datasheet to manage all I want.
In this example, how to enable or disable events for uart_error_handle ? I don't want to systematically go into the handler at every byte received, otherwise eDMA is useless ...
Many thanks for your help, I'm not sure I'm very clear.
In your case, I recommend that you omit the app_uart libraries, and use nrf_drv_uart.h (which wraps around calls to nrfx_) directly, by using the functions nrf_drv_uart_rx(...) and nrf_drv_uart_tx(...). The nrf_cli and our serializers use this directly (and app_uart as well, just that it sends/receives only 1 byte at the time).
Håkon
I don't understand how to get all the interruption that I wish as an event in the handler.
For example, how to be informed of RXSTARTED for load another buffer as seen in Figure 95 of the nRF52832 datasheet.
If I use another way of doing this, for example :
NRF_UARTE0->ENABLE = (UARTE_ENABLE_ENABLE_Enabled << UARTE_ENABLE_ENABLE_Pos);
NRF_UARTE0->BAUDRATE=NRF_UARTE_BAUDRATE_115200;
NRF_UARTE0->PSEL.RXD=RX_PIN_NUMBER;
NRF_UARTE0->PSEL.TXD=TX_PIN_NUMBER;
NRF_UARTE0->CONFIG=NRF_UARTE_HWFC_DISABLED;
NRF_UARTE0->TXD.PTR = (uint32_t)((uint8_t *)txUarteBuffer);
NRF_UARTE0->TXD.MAXCNT = sizeof(txUarteBuffer);
NRF_UARTE0->TASKS_STARTTX = 0;
NRF_UARTE0->RXD.PTR = (uint32_t)((uint8_t *) rxUarteBuffer);
NRF_UARTE0->RXD.MAXCNT = sizeof(rxUarteBuffer);
NRF_UARTE0->TASKS_STARTRX = 1;
How to create an handler for event ?
if I use :
NRF_UARTE0->INTENCLR = 0xFFFFFFFF;
NRF_UARTE0->INTENSET = NRF_UARTE_INT_ENDRX_MASK;
NVIC_ClearPendingIRQ(UARTE0_UART0_IRQn);
NVIC_SetPriority(UARTE0_UART0_IRQn, NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY);
NVIC_EnableIRQ(UARTE0_UART0_IRQn);
I have :
<error> app: ERROR 3735928559 [Unknown error code] at .......\modules\nrfx\drivers\src\prs\nrfx_prs.c:81
PC at: 0x0002C49F
<error> app: End of error report
Someone can help me ?
Thanks in advance.
It looks like you are mixing bare metal implementation, and using the nrfx_uarte driver. You must disable the nrfx_uarte module in order to use the UARTE peripheral directly.
Håkon
Hi Hakon,
Thanks for your help.
For disabling nrfx, I need to modify sdk_config.h and not included nrfx_uarte.h ?
I need to include just "nrf_uarte.h" ?
How to create UARTE0_UART0_IRQ in my main software ?
Sorry for all these questions, but I feel like going round with all these UART driver ...
