Updating advertising data (manuf. spec. data) in SDK15
Hello guys! And girls Slight smile
My project is working as expected in SDK14.2.
I'm updating adv data (manuf. spec. data) without any problem with this function
static void advertising_data_update(uint8_t adv_manuf_byte)
		ret_code_t err_code;
		ble_advertising_init_t 		init;
		ble_advdata_manuf_data_t 	adv_manuf_data;
		uint8_array_t            	adv_manuf_data_array;
		uint8_t                  	adv_manuf_data_data[1];
		adv_manuf_data_data[0] 		= adv_manuf_byte;
		init.advdata.name_type          		 = BLE_ADVDATA_FULL_NAME;
		init.advdata.include_appearance 		 = false;
		init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
		init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
		init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
		adv_manuf_data_array.p_data 							 = adv_manuf_data_data;
		adv_manuf_data_array.size 								 = sizeof(adv_manuf_data_data);
		adv_manuf_data.company_identifier 				 = APP_COMPANY_IDENTIFIER;
		adv_manuf_data.data 											 = adv_manuf_data_array;
		init.advdata.p_manuf_specific_data 				 = &adv_manuf_data;
		init.config.ble_adv_whitelist_enabled      = true;
		init.config.ble_adv_directed_enabled       = true;
		init.config.ble_adv_directed_slow_enabled  = false;
		init.config.ble_adv_directed_slow_interval = 0;
		init.config.ble_adv_directed_slow_timeout  = 0;
		init.config.ble_adv_fast_enabled  				 = true;
		init.config.ble_adv_fast_interval 				 = APP_ADV_INTERVAL;
		init.config.ble_adv_fast_timeout  				 = APP_ADV_TIMEOUT_IN_SECONDS;
		err_code = ble_advdata_set(&init.advdata, NULL);
But in SDK15 the function ble_advdata_set() has been deprecated.
The migration guide is says to use ble_advdata_encode() and sd_ble_gap_adv_set_configure() instead.
So I changed it to something like this
    init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
		init.config.ble_adv_directed_high_duty_enabled 	= true;
    init.config.ble_adv_directed_enabled       			= false;
    init.config.ble_adv_fast_timeout  				 			= APP_ADV_FAST_DURATION;
		//err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
		//APP_ERROR_CHECK(err_code);
		err_code = ble_advdata_encode(&init.advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
		err_code = sd_ble_gap_adv_set_configure(&m_advertising.adv_handle, &m_adv_data, NULL);
		//err_code = sd_ble_gap_adv_start(m_advertising.adv_handle, APP_BLE_CONN_CFG_TAG);
And of course... it's not working. :)
I'm getting a very strange error at sd_ble_gap_adv_set_configure() --> app: ERROR 12801 [Unknown error code]
Any idea why?
What I'm doing wrong?
What I have to change to get this working like in the SDK14.2?
  • I had same issue with SDK 15. Read thru several forums including this one with no real answer. I too was using the Advertising Module with
    BLE_ADVERTISING_DEF(advertiseModule);
    I found the answer to my problem by digging into what SDK's ble_advertising_init was using when it calls ble_advdata_encode. It uses the encoded buffer inside advertiseModule. I was mistakenly creating my own buffer and passing it to ble_advdata_encode.
    Once I used the following functions, everything worked fine. Even without restarting advertising.
    static void advertiseInit(void) {
        // Only call once at start of program.
        servicesToAdvertise[0] = someServiceUUID;
        static ble_advdata_manuf_data_t advertMfgData;
        memset(&advertMfgData, 0, sizeof(advertMfgData));
        advertMfgData.data.p_data = (uint8_t*)&mfgData;
        advertMfgData.data.size = sizeof(mfgData);
        init.advdata.uuids_complete.uuid_cnt = NUM_SERVICES_TO_ADVERTISE;
        init.advdata.uuids_complete.p_uuids = servicesToAdvertise;
        init.advdata.p_manuf_specific_data = &advertMfgData;
        init.config.ble_adv_fast_timeout = BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;
        init.config.ble_adv_on_disconnect_disabled = true; // true = Let our code handle the restart
        init.evt_handler = advertiseEventHandler;
        init.error_handler = advertiseErrorHandler;
        ret_code_t err_code = ble_advertising_init(&advertiseModule, &init);
        ble_advertising_conn_cfg_tag_set(&advertiseModule, APP_BLE_CONN_CFG_TAG);
        err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, advertiseModule.adv_handle, TX_POWER_LEVEL);
    void advertisingUpdateMfgData(void) {
      mfgData.inventoryCount = userData.count;
      ret_code_t err_code = ble_advdata_encode(&init.advdata, advertiseModule.enc_advdata, &advertiseModule.adv_data.adv_data.len);
    Notes:
      1) that advertiseModule.enc_advdata is not my buffer. It was created by SDK when using BLE_ADVERTISING_DEF(advertiseModule) and  ble_advertising_init.
  • I'm struggling with the same problem and i'm pretty sure it is the pointer to the encoded data (p_encoded_data) since the error is thrown in the next encode function (name_encode in my case) if no UUID's are provided.
    So my question is if anybody has found the answer yet
    EDIT:
    Found out that the  new_advdata.adv_data.p_data pointer is NULL which is why the NRF_ERROR_INVALID_ADDR is returned. In ble_advertising_init this pointer is set to  m_advertising.enc_advdata which cannot be done in the update function since then a NRF_ERROR_INVALID_STATE error is returned.
  • In the new sdk15.2, you need to stop the adv before updating, otherwise you get that error.
  • I'd like to see Nordic weigh in on this.  I had nothing but trouble in trying to stop and restart advertising when changing advertising data in SDK 15.2.  I implemented a function to update manufacturer's advertising data using the 2-buffer approach and pass it to ble_advertising_advdata_update() in ble_advertising.c from SDK 15.2.  The advertisements update reliably without stopping/re-starting advertising.
