Updating advertising data (manuf. spec. data) in SDK15
Hello guys! And girls Slight smile
My project is working as expected in SDK14.2.
I'm updating adv data (manuf. spec. data) without any problem with this function
static void advertising_data_update(uint8_t adv_manuf_byte)
		ret_code_t err_code;
		ble_advertising_init_t 		init;
		ble_advdata_manuf_data_t 	adv_manuf_data;
		uint8_array_t            	adv_manuf_data_array;
		uint8_t                  	adv_manuf_data_data[1];
		adv_manuf_data_data[0] 		= adv_manuf_byte;
		init.advdata.name_type          		 = BLE_ADVDATA_FULL_NAME;
		init.advdata.include_appearance 		 = false;
		init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
		init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
		init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
		adv_manuf_data_array.p_data 							 = adv_manuf_data_data;
		adv_manuf_data_array.size 								 = sizeof(adv_manuf_data_data);
		adv_manuf_data.company_identifier 				 = APP_COMPANY_IDENTIFIER;
		adv_manuf_data.data 											 = adv_manuf_data_array;
		init.advdata.p_manuf_specific_data 				 = &adv_manuf_data;
		init.config.ble_adv_whitelist_enabled      = true;
		init.config.ble_adv_directed_enabled       = true;
		init.config.ble_adv_directed_slow_enabled  = false;
		init.config.ble_adv_directed_slow_interval = 0;
		init.config.ble_adv_directed_slow_timeout  = 0;
		init.config.ble_adv_fast_enabled  				 = true;
		init.config.ble_adv_fast_interval 				 = APP_ADV_INTERVAL;
		init.config.ble_adv_fast_timeout  				 = APP_ADV_TIMEOUT_IN_SECONDS;
		err_code = ble_advdata_set(&init.advdata, NULL);
But in SDK15 the function ble_advdata_set() has been deprecated.
The migration guide is says to use ble_advdata_encode() and sd_ble_gap_adv_set_configure() instead.
So I changed it to something like this
    init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
		init.config.ble_adv_directed_high_duty_enabled 	= true;
    init.config.ble_adv_directed_enabled       			= false;
    init.config.ble_adv_fast_timeout  				 			= APP_ADV_FAST_DURATION;
		//err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
		//APP_ERROR_CHECK(err_code);
		err_code = ble_advdata_encode(&init.advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
		err_code = sd_ble_gap_adv_set_configure(&m_advertising.adv_handle, &m_adv_data, NULL);
		//err_code = sd_ble_gap_adv_start(m_advertising.adv_handle, APP_BLE_CONN_CFG_TAG);
And of course... it's not working. :)
I'm getting a very strange error at sd_ble_gap_adv_set_configure() --> app: ERROR 12801 [Unknown error code]
Any idea why?
What I'm doing wrong?
What I have to change to get this working like in the SDK14.2?
  • Thank you for that,
    It would be possible to get in contact with this your colleague?
    I have some more questions for him.
  • Ok Slight smile
    My initialization function
    	adv_manuf_data_data[0] 		= 0x00;
    	init.config.ble_adv_directed_high_duty_enabled 	= false;
        init.evt_handler 	 = on_adv_evt;
    	init.error_handler = ble_advertising_error_handler;
    and a updating function
    	// Stop advertising
    	if(m_conn_handle == BLE_CONN_HANDLE_INVALID)
    		NRF_LOG_INFO("sd_ble_gap_adv_stop: %d", err_code);
    	// New initialization
    	NRF_LOG_INFO("ble_advertising_init: %d", err_code);
    	// Restart advertising
    		//NRF_LOG_INFO("sd_ble_gap_adv_start: %d", err_code);
    		advertising_start();
    Until now this was an only (working) solution for me.
    So... every single time I stop the advertising module, I reconfigure it and start it again.
    Compared to the solution I don't use ble_gap_adv_data_t
    My main question is... if a initialize the module with ble_advertising_init_t, how can I switch and update only the ble_advdata_manuf_data_t without stop and completly reconfigure the module?
    p.s.
    I'm using a whitelist.
  • Function doesn't work.
    First the typedef "ble_advertising_t" doesn't exist ... Even if I bypass it I got a error 12 [NRF_ERROR_DATA_SIZE]. I don't understand because the size of my datas is exactly the same as in the first init.
  • Try this code:
        ble_advdata_t              advdata;       /**< Advertising data: name, appearance, discovery flags, and more. */
        //ble_advdata_t              srdata;        /**< Scan response data: Supplement to advertising data. */
        memset(&advdata, 0, sizeof(advdata));
        //memset(&srdata, 0, sizeof(srdata));
        update_advertising_data(&m_advertising, &advdata, m_advertising.adv_data.adv_data.len, NULL, 0);
    /* PARAMS
    [IN] p_advertising: Pointer to an advertising instance, usually m_advertising in 'main' context.
    [IN] p_adv_data:    Pointer to an advertisment data instance.
    [IN] adv_data_len:  Length of advertisment data in bytes.
    [IN] p_sr_data:     Pointer to an scan respose data instance, set to NULL if no SR data.
    [IN] sr_data_len:   Length of scan response data in bytes.
    void update_advertising_data(ble_advertising_t *p_advertising, ble_advdata_t *p_adv_data, uint16_t adv_data_len, ble_advdata_t *p_sr_data, uint16_t sr_data_len)
        ASSERT(p_advertising->initialized);
        uint32_t ret = NRF_SUCCESS;
        ble_gap_adv_data_t *new_advdata;
        new_advdata->adv_data.len = adv_data_len;
        ret = ble_advdata_encode(p_adv_data, new_advdata->adv_data.p_data, &new_advdata->adv_data.len);
        APP_ERROR_CHECK(ret);
        if (p_sr_data)
            new_advdata->scan_rsp_data.len = sr_data_len;
            ret = ble_advdata_encode(p_sr_data,
                                   new_advdata->scan_rsp_data.p_data,
                                   &new_advdata->scan_rsp_data.len);
            new_advdata->scan_rsp_data.p_data = NULL;
            new_advdata->scan_rsp_data.len    = 0;
        ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, new_advdata, NULL);
