Updating advertising data (manuf. spec. data) in SDK15
Hello guys! And girls Slight smile
My project is working as expected in SDK14.2.
I'm updating adv data (manuf. spec. data) without any problem with this function
static void advertising_data_update(uint8_t adv_manuf_byte)
		ret_code_t err_code;
		ble_advertising_init_t 		init;
		ble_advdata_manuf_data_t 	adv_manuf_data;
		uint8_array_t            	adv_manuf_data_array;
		uint8_t                  	adv_manuf_data_data[1];
		adv_manuf_data_data[0] 		= adv_manuf_byte;
		init.advdata.name_type          		 = BLE_ADVDATA_FULL_NAME;
		init.advdata.include_appearance 		 = false;
		init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
		init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
		init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
		adv_manuf_data_array.p_data 							 = adv_manuf_data_data;
		adv_manuf_data_array.size 								 = sizeof(adv_manuf_data_data);
		adv_manuf_data.company_identifier 				 = APP_COMPANY_IDENTIFIER;
		adv_manuf_data.data 											 = adv_manuf_data_array;
		init.advdata.p_manuf_specific_data 				 = &adv_manuf_data;
		init.config.ble_adv_whitelist_enabled      = true;
		init.config.ble_adv_directed_enabled       = true;
		init.config.ble_adv_directed_slow_enabled  = false;
		init.config.ble_adv_directed_slow_interval = 0;
		init.config.ble_adv_directed_slow_timeout  = 0;
		init.config.ble_adv_fast_enabled  				 = true;
		init.config.ble_adv_fast_interval 				 = APP_ADV_INTERVAL;
		init.config.ble_adv_fast_timeout  				 = APP_ADV_TIMEOUT_IN_SECONDS;
		err_code = ble_advdata_set(&init.advdata, NULL);
But in SDK15 the function ble_advdata_set() has been deprecated.
The migration guide is says to use ble_advdata_encode() and sd_ble_gap_adv_set_configure() instead.
So I changed it to something like this
    init.advdata.flags              		 = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
		init.config.ble_adv_directed_high_duty_enabled 	= true;
    init.config.ble_adv_directed_enabled       			= false;
    init.config.ble_adv_fast_timeout  				 			= APP_ADV_FAST_DURATION;
		//err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
		//APP_ERROR_CHECK(err_code);
		err_code = ble_advdata_encode(&init.advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
		err_code = sd_ble_gap_adv_set_configure(&m_advertising.adv_handle, &m_adv_data, NULL);
		//err_code = sd_ble_gap_adv_start(m_advertising.adv_handle, APP_BLE_CONN_CFG_TAG);
And of course... it's not working. :)
I'm getting a very strange error at sd_ble_gap_adv_set_configure() --> app: ERROR 12801 [Unknown error code]
Any idea why?
What I'm doing wrong?
What I have to change to get this working like in the SDK14.2?
  • , nope.
    My BLE_GAP_EVT_DISCONNECT is completely empty of any advertising_start() or similar function.
    advertising_start() is called only at the beginning.
    How could I find out what could possibly point to the original advertisement data?
  • Hmm. Send me a PM with your application and I'll take a look at it.
  • Hi Martin
    I have problems too with porting code from an earlier SDK version which was using ble_advdata_set() for updating the advertiser data while adertising.
    I tried out your function: update_advertising() but there is a compiler error: variable "new_advdata" is used before its value is set.
  • Line 681 of ble_advertising.c: // Upon disconnection, whitelist will be activated and direct advertising is started.
    ble_advertising_on_ble_evt is the event handler registered with the macro  BLE_ADVERTISING_DEF(m_advertising); on line 104 of main.c.
    This event handler will call on_disconnected() given the event is BLE_GAP_EVT_DISCONNECTED. You need to update the advertising data of m_advertising in main before you can restart the advertisements if you want the updated advertisement data. You should be able to to this by setting m_advertising.adv_data.adv_data.p_data and .len to the address and length of your previously used buffer,
    new_advdata.adv_data.p_data and new_advdata.adv_data.len.
  •  I really do not understand what do you mean by that and what I have to change :)
    I had a perfecty working solution in SDK14 and now, in SDK15, I'm completely lost Slight smile
    After all you wrote in this debate it seems that the easiest solution is to uninit the module and restart it again with a new adv vaules and without all the mess with above in this conversation (various double buffers etc). Which in my opinion is absolutely unnecessary.
    I still do not understand why after every disconnect, the module starts to advertise with
    and not with a xy times updated adv data in
    Can you please resend to me (by PM) my code and show me what I have to change to get this work?
