I'm using interactive PyACI on Windows i found an error as in image attached. I didn't understand what can i do with Interactive PyACI and what it will deliver to me. Can anyone explain what i can do with it.
Vijay Rakesh.
Vijay Rakesh.
Yeah, I'm using SES, and I flashed only serial application (Opened Serial SES project file and flashed) Do i need to flash softdevice? If yes, How to flash it?
The softdevice should be included when you flash the application with SES. Can you check if the "Additional Load File" is pointing to the softdevice hex file?(Right click on your Project -> "Edit Options" -> "Loader" -> "Additional Load File")
In Additional Load File [0] "s132_nrf52_6.0.0_softdevice.hex" is already present as shown in below screenshot
Can you try with Python 32bit version?
I have the same problem. I was able to run the library. For the past few days this has given me the same error (photo below)
I'm working with mesh SDK v4. With 2 devkit board.
Echo command is not working too. I have tried on windows and macos.
How is it possible ?
Thank you very much !
