when I try to update bootloader on nRF52 from SDK12.3 to SDK14.2 using DFU over BLE I get INSUFFICIENT_RESOURCES error. I think it is caused by different sizes of bootloaders.
Is there any way to safely update bootloader over BLE?
The problem is that I have bootloader SDK v12.3 on several devices and I can't change it without DFU.
Probably i will try with bootloader in SDK v14.2 non debug version.
Yes, you can try that. Be aware that with non debug mode, you need to make sure the new bootloader version is > the current one.
There is a possibility to erase the UICR and write a new UICR to increase the size of the bootloader before swapping the bootloader however it's complex and have a risk to brick the device if the DFU process is interrupted.
