Amplifying nRF24L01P signal
Hi guys,
I am trying to use a TM2001 amplifier (Taiwan Microelectronics, google returns the PDF) to amplify the signal from an nRF24L01P.
The TM2001 seems to accept a 50ohm signal. I use the "application example" on the nordic chip on page 66.
I simply connect the TM2001 RADIO input to the 50 ohm line instead of a chip antenna. Then TM2001 has its own output which goes to an antenna.
I have used TM2001 before with no problems. However now it is giving very strange effects.
There is way too much power consumption from it. If I touch the antenna it affects how much power is drawn. No radio output is observed unless I artificially raise the resistance of the battery supply (by adding a 10 ohm resistor). Is it delusional to think that I can just hook up the TM2001 like I described? The only part of this circuit I don't understand is the inductors/capacitors between ANT1 ANT2 and VDD_PA. Are the inductors causing this problem? Should I just connect ANT1 or ANT2 to the TM2001?
thanks
