Get X,Y,Z values from LIS3DH using nrf52 development board
Hi!
I am trying to interface LIS3DH module (https://www.adafruit.com/product/2809) with nRF52 DK, SDK 11, via i2c/spi. I tested on Arduino UNO & it gave x,y,z values. So, I decided to write nrf driver for LIS3DH using Adafruit LIS3DH driver(https://github.com/adafruit/Adafruit_LIS3DH/) but I am getting errors like i2c begin & how/what to write to control registers to read data again.
Please suggest me how to write driver or if general LIS3DH driver is available then reply ASAP.
LIS3DH.h
#include <LIS3DH.h>
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
/** Sensor types */
typedef enum
  SENSOR_TYPE_ACCELEROMETER         = (1),   /**< Gravity + linear acceleration */
  SENSOR_TYPE_MAGNETIC_FIELD        = (2),
  SENSOR_TYPE_ORIENTATION           = (3),
  SENSOR_TYPE_GYROSCOPE             = (4),
  SENSOR_TYPE_LIGHT                 = (5),
  SENSOR_TYPE_PRESSURE              = (6),
  SENSOR_TYPE_PROXIMITY             = (8),
  SENSOR_TYPE_GRAVITY               = (9),
  SENSOR_TYPE_LINEAR_ACCELERATION   = (10),  /**< Acceleration not including gravity */
  SENSOR_TYPE_ROTATION_VECTOR       = (11),
  SENSOR_TYPE_RELATIVE_HUMIDITY     = (12),
  SENSOR_TYPE_AMBIENT_TEMPERATURE   = (13),
  SENSOR_TYPE_VOLTAGE               = (15),
  SENSOR_TYPE_CURRENT               = (16),
  SENSOR_TYPE_COLOR                 = (17)
} sensors_type_t;
/** struct sensors_vec_s is used to return a vector in a common format. */
typedef struct {
        float v[3];
        struct {
            float x;
            float y;
            float z;
            float roll;    /**< Rotation around the longitudinal axis (the plane body, 'X axis'). Roll is positive and increasing when moving downward. -90�<=roll<=90� */
            float pitch;   /**< Rotation around the lateral axis (the wing span, 'Y axis'). Pitch is positive and increasing when moving upwards. -180�<=pitch<=180�) */
            float heading; /**< Angle between the longitudinal axis (the plane body) and magnetic north, measured clockwise when viewing from the top of the device. 0-359� */
					int8_t status;
    uint8_t reserved[3];
} sensors_vec_t;
/** struct sensors_color_s is used to return color data in a common format. */
typedef struct {
        float c[3];
        /* RGB color space */
            float r;       /**< Red component */
            float g;       /**< Green component */
            float b;       /**< Blue component */
    uint32_t rgba;         /**< 24-bit RGBA value */
} sensors_color_t;
/* Sensor event (36 bytes) */
/** struct sensor_event_s is used to provide a single sensor event in a common format. */
typedef struct
    int32_t version;                          /**< must be sizeof(struct sensors_event_t) */
    int32_t sensor_id;                        /**< unique sensor identifier */
    int32_t type;                             /**< sensor type */
    int32_t reserved0;                        /**< reserved */
    int32_t timestamp;                        /**< time is in milliseconds */
        float           data[4];
        float           temperature;          /**< temperature is in degrees centigrade (Celsius) */
        float           distance;             /**< distance in centimeters */
        float           light;                /**< light in SI lux units */
        float           pressure;             /**< pressure in hectopascal (hPa) */
        float           relative_humidity;    /**< relative humidity in percent */
        float           current;              /**< current in milliamps (mA) */
        float           voltage;              /**< voltage in volts (V) */
} sensors_event_t;
/* Sensor details (40 bytes) */
/** struct sensor_s is used to describe basic information about a specific sensor. */
typedef struct
    char     name[12];                        /**< sensor name */
    int32_t  version;                         /**< version of the hardware + driver */
    int32_t  type;                            /**< this sensor's type (ex. SENSOR_TYPE_LIGHT) */
    float    max_value;                       /**< maximum value of this sensor's value in SI units */
    float    min_value;                       /**< minimum value of this sensor's value in SI units */
    float    resolution;                      /**< smallest difference between two values reported by this sensor */
    int32_t  min_delay;                       /**< min delay in microseconds between events. zero = not a constant rate */
} sensor_t;
typedef enum
  LIS3DH_RANGE_16_G         = 3,   // +/- 16g
  LIS3DH_RANGE_8_G           = 2,   // +/- 8g
  LIS3DH_RANGE_4_G           = 1,   // +/- 4g
  LIS3DH_RANGE_2_G           = 0    // +/- 2g (default value)
} lis3dh_range_t;
typedef enum
  LIS3DH_AXIS_X         = 0x0,
  LIS3DH_AXIS_Y         = 0x1,
  LIS3DH_AXIS_Z         = 0x2,
} lis3dh_axis_t;
  // These must be defined by the subclass
  void enableAutoRange(bool enabled) {};
  int16_t readADC(uint8_t a);
  void setRange(lis3dh_range_t range);
  lis3dh_range_t getRange(void);
  void setDataRate(lis3dh_dataRate_t dataRate);
  lis3dh_dataRate_t getDataRate(void);
  bool getEvent(sensors_event_t *event);
  void getSensor(sensor_t *sensor);
  uint8_t getOrientation(void);
  void setClick(uint8_t c, uint8_t clickthresh, uint8_t timelimit = 10, uint8_t timelatency = 20, uint8_t timewindow = 255);
  uint8_t getClick(void);
  int16_t x, y, z;
  float x_g, y_g, z_g;
  uint8_t readRegister8(uint8_t reg);
  void writeRegister8(uint8_t reg, uint8_t value);
  uint8_t spixfer(uint8_t x = 0xFF);
  int32_t _sensorID;
  int8_t  _i2caddr;
  // SPI
  int8_t _cs, _mosi, _miso, _sck;
    @brief  Setups the HW (reads coefficients values, etc.)
bool begin() {
  /* Check connection */
  uint8_t deviceid = readRegister8(LIS3DH_REG_WHOAMI);
  if (deviceid != 0x33)
    /* No LIS3DH detected ... return false */
    //Serial.println(deviceid, HEX);
    return false;
  // enable all axes, normal mode
  writeRegister8(LIS3DH_REG_CTRL1, 0x07);
  // 400Hz rate
  setDataRate(LIS3DH_DATARATE_400_HZ);
  // High res & BDU enabled
  writeRegister8(LIS3DH_REG_CTRL4, 0x88);
  // DRDY on INT1
  writeRegister8(LIS3DH_REG_CTRL3, 0x10);
  // Turn on orientation config
  //writeRegister8(LIS3DH_REG_PL_CFG, 0x40);
  // enable adcs
  writeRegister8(LIS3DH_REG_TEMPCFG, 0x80);
  for (uint8_t i=0; i<0x30; i++) {
    Serial.print("$");
    Serial.print(i, HEX); Serial.print(" = 0x");
    Serial.println(readRegister8(i), HEX);
  return true;
void read(void) {
  // read x y z at once
  if (_cs == -1) {
    // i2c
	nrf_drv_twi_tx(&p_twi_instance,LIS3DH_DEFAULT_ADDRESS,LIS3DH_REG_OUT_X_L,sizeof(LIS3DH_REG_OUT_X_L), true);// PEDO_WRITE(data,6);
	nrf_delay_ms(5);
	do{
	nrf_drv_twi_rx(&p_twi_instance,LIS3DH_DEFAULT_ADDRESS,LIS3DH_REG_OUT_X_L, sizeof(LIS3DH_REG_OUT_X_L), false);
	}while(LIS3DH_REG_OUT_X_L[1]!=0x80);
    I2Cinterface->requestFrom(_i2caddr, 6);
    x = I2Cinterface->read(); x |= ((uint16_t)I2Cinterface->read()) << 8;
    y = I2Cinterface->read(); y |= ((uint16_t)I2Cinterface->read()) << 8;
    z = I2Cinterface->read(); z |= ((uint16_t)I2Cinterface->read()) << 8;
  #ifndef __AVR_ATtiny85__
  else {
    if (_sck == -1)
      SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
    digitalWrite(_cs, LOW);
    spixfer(LIS3DH_REG_OUT_X_L | 0x80 | 0x40); // read multiple, bit 7&6 high
    x = spixfer(); x |= ((uint16_t)spixfer()) << 8;
    y = spixfer(); y |= ((uint16_t)spixfer()) << 8;
    z = spixfer(); z |= ((uint16_t)spixfer()) << 8;
    digitalWrite(_cs, HIGH);
    if (_sck == -1)
      SPI.endTransaction();              // release the SPI bus
  uint8_t range = getRange();
  uint16_t divider = 1;
  if (range == LIS3DH_RANGE_16_G) divider = 1365; // different sensitivity at 16g
  if (range == LIS3DH_RANGE_8_G) divider = 4096;
  if (range == LIS3DH_RANGE_4_G) divider = 8190;
  if (range == LIS3DH_RANGE_2_G) divider = 16380;
  x_g = (float)x / divider;
  y_g = (float)y / divider;
  z_g = (float)z / divider;
    @brief  Read the auxilary ADC
int16_t readADC(uint8_t adc) {
  if ((adc < 1) || (adc > 3)) return 0;
  uint16_t value;
  adc--;
  uint8_t reg = LIS3DH_REG_OUTADC1_L + adc*2;
  if (_cs == -1) {
    // i2c
    I2Cinterface->beginTransmission(_i2caddr);
    I2Cinterface->write(reg | 0x80);   // 0x80 for autoincrement
    I2Cinterface->endTransmission();
    I2Cinterface->requestFrom(_i2caddr, 2);
    value = I2Cinterface->read();  value |= ((uint16_t)I2Cinterface->read()) << 8;
  else {
    if (_sck == -1)
    spixfer(reg | 0x80 | 0x40); // read multiple, bit 7&6 high
    value = spixfer(); value |= ((uint16_t)spixfer()) << 8;
    if (_sck == -1)
  return value;
    @brief  Set INT to output for single or double click
void setClick(uint8_t c, uint8_t clickthresh, uint8_t timelimit, uint8_t timelatency, uint8_t timewindow) {
  if (!c) {
    //disable int
    uint8_t r = readRegister8(LIS3DH_REG_CTRL3);
    r &= ~(0x80); // turn off I1_CLICK
    writeRegister8(LIS3DH_REG_CTRL3, r);
    writeRegister8(LIS3DH_REG_CLICKCFG, 0);
    return;
  // else...
  writeRegister8(LIS3DH_REG_CTRL3, 0x80); // turn on int1 click
  writeRegister8(LIS3DH_REG_CTRL5, 0x08); // latch interrupt on int1
  if (c == 1)
    writeRegister8(LIS3DH_REG_CLICKCFG, 0x15); // turn on all axes & singletap
  if (c == 2)
    writeRegister8(LIS3DH_REG_CLICKCFG, 0x2A); // turn on all axes & doubletap
  writeRegister8(LIS3DH_REG_CLICKTHS, clickthresh); // arbitrary
  writeRegister8(LIS3DH_REG_TIMELIMIT, timelimit); // arbitrary
  writeRegister8(LIS3DH_REG_TIMELATENCY, timelatency); // arbitrary
  writeRegister8(LIS3DH_REG_TIMEWINDOW, timewindow); // arbitrary
uint8_t getClick(void) {
  return readRegister8(LIS3DH_REG_CLICKSRC);
    @brief  Sets the g range for the accelerometer
  uint8_t r = readRegister8(LIS3DH_REG_CTRL4);
  r &= ~(0x30);
  r |= range << 4;
  writeRegister8(LIS3DH_REG_CTRL4, r);
  /* Read the data format register to preserve bits */
  return (lis3dh_range_t)((readRegister8(LIS3DH_REG_CTRL4) >> 4) & 0x03);
    @brief  Sets the data rate for the LIS3DH (controls power consumption)
  uint8_t ctl1 = readRegister8(LIS3DH_REG_CTRL1);
  ctl1 &= ~(0xF0); // mask off bits
  ctl1 |= (dataRate << 4);
  writeRegister8(LIS3DH_REG_CTRL1, ctl1);
  return (lis3dh_dataRate_t)((readRegister8(LIS3DH_REG_CTRL1) >> 4)& 0x0F);
    @brief  Gets the most recent sensor event
bool getEvent(sensors_event_t *event) {
  /* Clear the event */
  memset(event, 0, sizeof(sensors_event_t));
  event->version   = sizeof(sensors_event_t);
  event->sensor_id = _sensorID;
  event->type      = SENSOR_TYPE_ACCELEROMETER;
  event->timestamp = 0;
  read();
  event->acceleration.x = x_g * SENSORS_GRAVITY_STANDARD;
  event->acceleration.y = y_g * SENSORS_GRAVITY_STANDARD;
  event->acceleration.z = z_g * SENSORS_GRAVITY_STANDARD;
    @brief  Gets the sensor_t data
void getSensor(sensor_t *sensor) {
  /* Clear the sensor_t object */
  memset(sensor, 0, sizeof(sensor_t));
  /* Insert the sensor name in the fixed length char array */
  strncpy (sensor->name, "LIS3DH", sizeof(sensor->name) - 1);
  sensor->name[sizeof(sensor->name)- 1] = 0;
  sensor->version     = 1;
  sensor->sensor_id   = _sensorID;
  sensor->type        = SENSOR_TYPE_ACCELEROMETER;
  sensor->min_delay   = 0;
  sensor->max_value   = 0;
  sensor->min_value   = 0;
  sensor->resolution  = 0;
    @brief  Low level SPI
uint8_t spixfer(uint8_t x) {
  if (_sck == -1)
    return SPI.transfer(x);
  // software spi
  //Serial.println("Software SPI");
  uint8_t reply = 0;
  for (int i=7; i>=0; i--) {
    reply <<= 1;
    digitalWrite(_sck, LOW);
    digitalWrite(_mosi, x & (1<<i));
    digitalWrite(_sck, HIGH);
    if (digitalRead(_miso))
      reply |= 1;
  return reply;
    @brief  Writes 8-bits to the specified destination register
void writeRegister8(uint8_t reg, uint8_t value) {
  if (_cs == -1) {
    I2Cinterface->beginTransmission((uint8_t)_i2caddr);
    I2Cinterface->write((uint8_t)reg);
    I2Cinterface->write((uint8_t)value);
  else {
    if (_sck == -1)
    spixfer(reg & ~0x80); // write, bit 7 low
    spixfer(value);
    if (_sck == -1)
    @brief  Reads 8-bits from the specified register
uint8_t readRegister8(uint8_t reg) {
  uint8_t value;
  if (_cs == -1) {
    I2Cinterface->requestFrom(_i2caddr, 1);
  else {
    if (_sck == -1)
    spixfer(reg | 0x80); // read, bit 7 high
    value = spixfer(0);
    if (_sck == -1)
  return value;
  • I see that the projects where the driver is used, it only uses the LIS3DH to wake up the chip from sleep, so maybe the drivers that you initially found would be a better approach.
    Can you please specify what kind of issues you see when you try to use it? You say: " I am getting errors like i2c begin". What do you mean by that?
    Edvin
  • So, this (drv_acc_lis3dh.c) will only wake-up LIS3DH. I am not getting any error while compiling your files but I can't find any function to read X,Y,Z values defined in drv_acc_lis3dh.h file:
    typedef struct
    int16_t AXIS_X;
    int16_t AXIS_Y;
    int16_t AXIS_Z;
    } AccAxesRaw_t;
    Is driver incomplete? Please suggest me how to read the registers for LIS3DH data like here below:
    static uint8_t mosiBuf [2];
    static uint8_t misoBuf [2];
    void writeLisReg(uint8_t subAddr, uint8_t value)
    uint32_t err_code;
    while(spi_master_get_state(SPI_MASTER_0) != SPI_MASTER_STATE_IDLE);
    mosiBuf[0] = subAddr & ~0xc0;
    mosiBuf[1] = value;
    err_code = spi_master_send_recv(SPI_MASTER_0, mosiBuf, 2, misoBuf,2);
    uint8_t readLisReg(uint8_t subAddr)
    uint32_t err_code;
    mosiBuf[0] = subAddr | 0x80;
    mosiBuf[1] = 0;
    misoBuf[0] = 0x55;
    misoBuf[1] = 0xAA;
    return misoBuf[1];
    void init_lis3dh() {
    writeLisReg(LIS3DH_CTRL_REG1, 0x57); //All axes, normal, 100Hz
    writeLisReg(LIS3DH_CTRL_REG2, 0x00); // No HighPass filter
    writeLisReg(LIS3DH_CTRL_REG3, 0x00); // No interrupts
    writeLisReg(LIS3DH_CTRL_REG4, 0x0); // all defaults
    writeLisReg(LIS3DH_CTRL_REG5, 0x0); // all defaults
    writeLisReg(LIS3DH_CTRL_REG6, 0x0); // all defaults
    void readLisData()
    int16_t x,y,z;
    double dx, dy, dz;
    while(readLisReg(LIS3DH_STATUS_REG) & 0x8 == 0 );
    x = readLisReg(LIS3DH_OUT_X_H) * 256 + readLisReg(LIS3DH_OUT_X_L);
    y = readLisReg(LIS3DH_OUT_Y_H) * 256 + readLisReg(LIS3DH_OUT_Y_L);
    z = readLisReg(LIS3DH_OUT_Z_H) * 256 + readLisReg(LIS3DH_OUT_Z_L);
    dx = x/16384.0;
    dy = y/16384.0;
    dz = z/16384.0;
    printf("X: %f; Y: %f; Z: %f; SUM: %f\n\r", dx , dy, dz, sqrt(dx*dx + dy*dy + dz*dz));
    This is SPI example found here: https://github.com/elmot/nRF51822xxAA-LIS3DH/blob/master/main.c but I need data via i2c communication
  • No. This driver does not have a function called "readXYZ()".
    The example that you found on Github. Have you tested it? It seems like this example receives data from the LIS3DH, like you are looking for. I assume you can use the driver that I sent for the readLisReg() and WriteLisReg(). That is, change them to lis3dh_read_regs() and lis3dh_write_regs().
    BR,
    Edvin
  • status = lis3dh_read_regs(slave_reg, &contents, 1);
    Shall I call like this?
  • What is your slave_reg
    First of all, you need to init the lis3dh, using the same method as in the github example. Then I suggest you check out how the lis3dh_read_regs() sets up the app_twi_transfer_t structure, and make sure that you get the same when you call.
    Like you see in the init function of the github project that you linked to, you need to write to several registers at the lis3dh to initialize it properly.
    I suggest you start with looking into the TWI (same as I2C) example in the SDK\examples\peripheral\spim and get familiar with I2C. Then you can try to write to the sensor, and see what you get in return.
    Edvin
