Gazell: why i can only fill 4 pipes
I want to init all 8 pipes in the host device (gazell protocoll) with a single init byte. Thats important because i want to send that init byte to the devices with the first ack-signal.
The problem is that i always got an error after the fourth fill, that looks like that:
Pipe:0   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:1   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:2   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:3   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:4   Data:1   Push_ok:0   TX:0   RX:0    Errorcode:8  Enable:FF
Pipe:5   Data:1   Push_ok:0   TX:0   RX:0    Errorcode:8  Enable:FF
Pipe:6   Data:1   Push_ok:0   TX:0   RX:0    Errorcode:8  Enable:FF
Pipe:7   Data:1   Push_ok:0   TX:0   RX:0    Errorcode:8  Enable:FF
When i just init the pipes 4-7 erverything is fine:
Pipe:4   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:5   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:6   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
Pipe:7   Data:1   Push_ok:1   TX:1   RX:0    Errorcode:0  Enable:FF
All pipes are enabled but after the fourth fill i always got the error 8 which means:
NRF_GZLL_ERROR_CODE_INSUFFICIENT_PACKETS_AVAILABLE      =  8,
///< There are insufficient packets in the Gazell memory pool to
///< successfully execute the operation.
So i had a look at this: devzone.nordicsemi.com/.../a00140.html and found this section:
When the Host is handling packets on multiple pipes, care needs to be taken to ensure that ACK payloads in the TX FIFOs on pipes that are no longer in use, are not taking up space in the memory pool and consequently blocking communication on other pipes. To avoid such congestion, the application on the Host can flush the TX FIFOs on the pipes no longer in use.
Isn't ist possible to init all 8 pipes with just a single byte (i thougth the TX FiFo has a 3 Bytes memory).
Thank you for your help.
1 2
