I have some problems changing from the legacy driver to the new nrfx driver structure.
I have done the following:
1) Opened pwm example in SDK 15.0.
2) Renamed the pwm functions to nrfx_pwm from nrf_drv_pwm, likewise with relevant data structures.
3) Since I only want to run the new nrfx driver, and not the old legacy driver interface, I have made a change in the sdk_config.h: NRFX_PWM_ENABLED =1, so left it unchanged. PWM_ENABLED=1 (only for legacy driver??), and have changed it to 0.
4) Compiled the project and then get lots of compile errors, mostly that nrfx_pwm_xx functions and data structures is undeclared.
Is the intention to use both NRFX_PWM_ENABLED=1 and PWM_ENABLED=1, to use the new drivers?
I would have guessed that PWM_ENABLED=0 would disable the legacy driver layer.
If this is not your intention, I solution could be:
A) For here and now, just have PWM_ENABLED=1, even if not using legacy driver.
B) In the file apply_old_config.h, the line '#if defined(PWM_ENABLED)' could be changed to '#if PWM_ENABLED'.
Then, also consider doing this for all other relevant peripherial drivers.
