I am working with HX711 and I am trying to interface with nrf52832. Should I proceed with SAADC example or UART or Twi Sensor
Good afternoon. I am totally new to programming with controllers ARM Cortex M-4 and I need to do to operate the ADC HX711 in a Nrf52DK without the use of Ble. I have searched to the best of examples for the forums and I have not solved my needs. I can only find examples of Main c. for use with Ble. Someone could help me to build the file Main c. to be able to read the HX711 through NRF_LOG_INFO? I appreciate deeply the help.
What optimizations have to be turned on?
I have a separate solution to this problem that's preferable in a few ways:
The main realization behind it is that the hx711 will shut down if the clock line is held high for too long. When a high priority interrupt (from soft device, for example) arrives it can cause a delay which leaves the clock high and causes the hx711 to shut down. What my solution does is to use a timer / PPI to turn the clock on, then off, then calls an interrupt which can read the data and resume the timer. If an interrupt arrives and adds latency, this extra time occurs with the clock low, which is allowed for arbitrary lengths of time.
You can find the code: here
Suggestions for improvements are always welcome!
