How to set sending power of NRF52810 with SDK15.0
I want to set sending power(+4dBm) of NRF52810/NRF52832 with SDK 15.0.
Now,i  find i should use  the order of sd_ble_gap_tx_power_set(uint8_t role, uint16_t handle, int8_t tx_power));
But , i donn't the meaning of second parameter.
List as follows by SDK15.0:
* @param[in]     handle                     The handle parameter is interpreted depending on role:
* - If role is @ref BLE_GAP_TX_POWER_ROLE_CONN, this value is the specific connection handle.
* - If role is @ref BLE_GAP_TX_POWER_ROLE_ADV, the advertising set identified with the advertising handle,
* will use the specified transmit power, and include it in the advertising packet headers if
* @ref ble_gap_adv_properties_t::include_tx_power set.
* - For all other roles handle is ignored.
Now,  i will make a beacon and  i set it as sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,0,4);
It is right?
If the role is BLE_GAP_TX_POWER_ROLE_CONN, how to set the second parameter.
  • Edvin,
    Thanks.  What you described is not quite what I see in my SDK example.  I'm still not seeing how to set the adv_handle correctly in this context.  I've inserted the advertising_init() below.  This comes from the bluetoothds_template.
    Max
        ret_code_t    err_code;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_enabled   = true;
        init.config.ble_adv_fast_interval  = APP_ADV_INTERVAL;
        init.config.ble_adv_fast_timeout   = APP_ADV_DURATION;
    		// Set transmit power to 4 dBm
    		err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,????????,4);
  • hello,
    I used the example of beacon.
    I think it should be like this:
    /** @brief Advertising set handle not set. */
    #define BLE_GAP_ADV_SET_HANDLE_NOT_SET (0xFF)
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    advertising_init();
    uint8_t err_adv=sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_adv_handle,+4); //after advertising_init();
    advertising_start();
    Best  regards,
    liu
  • It is correct, as @liu says. You need to use the advertising handle.
    The advertising_init is set up a little different in the Beacon example, and in the regular ble_peripheral examples.
    You can find the advertising example in the m_advertising struct.
    sd_ble_gap_tx_power_set() must be after ble_advertising_init() I am not 100% sure whether it has to be after ble_advertising_conn_cfg_tag_set(), but you will quickly find out.
    It should look something like this:
    ble_advertising_init(...);
    ble_advertising_conn_cfg_tag_set(...);
        err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 4);
  • Edvin (and Liu)
    Thanks! The m_advertising.adv_handle worked.  And it does appear to increase the transmit power in my module based on just looking at RSSI from a distance.
    Appreciate the help,
    Max
  • hi, can I use this way to change the power even when it was configured by initialization? I need to change the tx power many times during the operation of the device.
