Service discovery, attribute not found 0x0001
Dear all,
I am having issues with service discovery of two primary services ( Battery and one propriotary based on NUS) I am currently using SDK 14.2 on NRF52832 chip running as central device application trying to discover these services on off-the shelf peripheral devices (thermal printers to be more specific).
I have tried with different devices (different brands with same UUID) and with some of them the service discovery works and I am able to send data to the printer. It also works when I connect using nRF Connect on my Android device.
I have logged the communication with Wireshark however don't understand why I get the "Attribute Not Found, Handle: 0x0001 (Unknown)
Sorry for being somewhat brief in my description. The thing is that I am not sure I am actually looking at this problem from the right angle. I am not certain the service discovery is wrong. It may be that I missed something in the configuration. If so, how do I find out what?
Thanks for any help getting on track with this.
  • Just for a quick test I used the  multilink central example you suggested. Since it already has the battery service it was perfect for testing this. However, it does not connect here either. I'll uplode a Wireshark log later today.
  • That's weird. Do you also have any logging information from the multilink example that you could upload? Might be helpful in debugging this further.
  • Just a heads up that I have a similar issue in another post. Also getting Attribute Not Found for three of my characteristics on discovery. So I'm interested in the response here.
  • I have had major issues with Wireshark. I can't get it to capture anything else then advertisement packages. Occasionally I get a scan request from some Apple device in the area. therefore my logs are useless at the moment. I have tried to recreate the loggs I made earlier without luck.
    The best I can do for now is the debug output from the debug output.
    <debug> nrf_sdh: State request: 0x00000000
    <debug> nrf_sdh: Notify observer 0x00027D78 => ready
    <debug> nrf_sdh: State change: 0x00000000
    <debug> nrf_sdh: State change: 0x00000001
    <debug> nrf_sdh_ble: RAM starts at 0x20004190
    <info> app: Multilink example started.
    <info> app: Start scanning for device 46 2C 90 17 02 0F
    <debug> nrf_sdh_ble: BLE event: 0x1D.
    <debug> app: Adv report.
    <info> app: Connecting to target 62 CE BB 51 F9 F4
    <info> app: Connecting to target 90 63 86 95 13 15
    <info> app: Connecting to target 46 2C 90 17 02 0F
    <debug> nrf_sdh_ble: BLE event: 0x10.
    <info> app: Connection 0x0 established, starting DB discovery.
    <debug> ble_db_disc: Starting discovery of service with UUID 0x180F on connection handle 0x0.
    <debug> nrf_sdh_ble: BLE event: 0x30.
    <debug> ble_db_disc: Service UUID 0x180F not found.
    <debug> app: call to ble_lbs_on_db_disc_evt for instance 0 and link 0x0!
    <debug> ble_bas_c: Battery Service discovery failure at peer.
    <debug> ble_db_disc: Service UUID 0x0 not found.
    <debug> nrf_sdh_ble: BLE event: 0x11.
    <info> app: LBS central link 0x0 disconnected (reason: 0x8)
    <info> app: Connecting to target 59 E1 D5 4E 74 C0
  • It seems the on_primary_srv_discovery_rsp() function is printing out the "Service UUID 0x0 not found" to the log. The reason for this is that the line "p_ble_gattc_evt->gatt_status" inside the if block of the on_primary_srv_discovery_rsp() function inside ble_db_discovery.c of the multilink example does not return BLE_GATT_STATUS_SUCCESS. Could you set a breakpoint here or print out what the GATT status code is? If you are still using SDK v 14.2 with Softdevice v5.0.0, you can find the different GATT status codes here.
