Hi im trying Keil for the frist time and trying to start the hrs peripheral example from the sdk v12.0 but get an error when trying to build.
thanks.
thanks.
It works on the blinky example the on thats not is a BLE example so i just choose blank insted of s130. But when im trying to run ble_hrs peripheral i get 38 errors.
Are you building the nrf51422_xxac target?
I think so.
Ok thanks, looks like you are building with the correct target. The missing headers should be provided by the "Device" pack, which it does on my side. You can try to add the path manually since it doesn't appear do that with your setup:
I can build error free now thanks. After it builds correctly i press the load button an get this error.
and when i press ok:
