PCA10040 and PCA20020 both use nrf52832 and s132 softdevices but still when I try to run the code for PCA10040 on PCA20020 it does not work?
I would use the thingy mesh demo that you mention instead. The mesh sdk has not been made for the Thingy:52, as the Thingy:52 is more of a prototype demo kit, while the dev kits are full out development kits made for development. If you really want to run the mesh sdk, I would take a look at the difference between the thingy bridge & thingy node setup & compare that with the light switch provisioner, client & server examples from the mesh sdk.
Have you tried debugging the Thingy code to see why the server does not get provisioned? Are you using mesh sdk v1 or v2? Take a look at the mesh documentation for more info on building a mesh network.
I am using the latest mesh sdk i.e 2.0.1.
I just found out while debugging nrf52 dk (which is used as provisioner) that I can provision the thingy's but the only thing was in light switch example it initially provisions the client and then the servers. I saw in the log that all thingy got provisioned which was verified in nrf Connect app as well. But yeah I cannot control the leds through the thingy's button. So as you have suggested I probably have to tweak thingy bridge and thingy node code to make it work for light switch example.
