RTT freeze after writing to UICR
I have a test suite connecting to a nRF52832dk using RTT. This one test writes random data to the UICR config area, resets the chip, then reads back the config.
When running this test only, all is fine. So is running the test several times in a row.
However, when I run any other of my tests before the config test, it freezes. I could narrow it down to MultiAPI.rtt_write() in pynrfjprog returning 0, RTT seems not accessible.
In the working situation (testing only UICR config), the command passed through RTT sends the first 15 bytes, then 2 extra. This is as expected, given the default size of the RTT buffer.
However, when the config test fails, the first 15 bytes are passed (15 is returned by the function rtt_write()), but the 2 following bytes are not (0 is returned by the function rtt_write()). No further bytes can be sent, even after reflashing the firmware. Hard reset is required.
To summarize, the RTT seems to have troubles running after a config set, until hard reset. This only happens after running other tests first, but I cannot find out why. My question is: what could possibly make the RTT stop flushing its buffer, or fail to write?
  • [NRFJPROG DLL LOG]: FUNCTION: open_dll.
    [NRFJPROG DLL LOG]: FUNCTION: connect_to_emu_with_snr.
    [NRFJPROG DLL LOG]: FUNCTION: connect_to_emu_without_snr.
    [NRFJPROG DLL LOG]: FUNCTION: enum_emu_snr.
    [NRFJPROG DLL LOG]: Device "NRF52832_XXAA" selected.
    [NRFJPROG DLL LOG]: FUNCTION: erase_uicr.
    [NRFJPROG DLL LOG]: Found SWD-DP with ID 0x2BA01477
    [NRFJPROG DLL LOG]: AP-IDR: 0x24770011, Type: AHB-AP
    [NRFJPROG DLL LOG]: Found Cortex-M4 r0p1, Little endian.
    [NRFJPROG DLL LOG]: FPUnit: 6 code (BP) slots and 2 literal slots
    [NRFJPROG DLL LOG]: CoreSight components:
    [NRFJPROG DLL LOG]: ROMTbl 0 @ E00FF000
    [NRFJPROG DLL LOG]: ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
    [NRFJPROG DLL LOG]: ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
    [NRFJPROG DLL LOG]: ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
    [NRFJPROG DLL LOG]: ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
    [NRFJPROG DLL LOG]: ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
    [NRFJPROG DLL LOG]: ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
    [NRFJPROG DLL LOG]: FUNCTION: sys_reset.
    [NRFJPROG DLL LOG]: FUNCTION: go.
    [NRFJPROG DLL LOG]: FUNCTION: rtt_start.
    [NRFJPROG DLL LOG]: FUNCTION: rtt_is_control_block_found.
    [NRFJPROG DLL LOG]: FUNCTION: rtt_read.
    [NRFJPROG DLL LOG]: FUNCTION: rtt_write.
    [NRFJPROG DLL LOG]: FUNCTION: rtt_stop.
    [NRFJPROG DLL LOG]: FUNCTION: disconnect_from_emu.
    [NRFJPROG DLL LOG]: FUNCTION: close_dll.
    Right, this is what I got.
    The reason why the writes and reads are duplicated is because the commands are sent 15 bytes at a time, and they are longer than that. I'm a bit surprised by the duplicated "go", "sys_reset", ...
    Things go well until the second sys_reset, line 70/71.
    rtt_start seems fine, the control block is found at least.
    Subsequent rtt_write return 0 (number of bytes sent), until max number of retries (100) is reached.
    To be honest, I'm not so sure this is related to UICR anymore.
  • Can you test with debug_reset instead of sys_reset? We have seen some issues with re-init of rtt-buffers sometimes after sys_reset.
  • Thank you for that. Unfortunately it doesn't seem to make a difference.
  • Can you provide version numbers of nrfjprog and Segger-DLL?
  • JLinkExe version is V6.32c (was V6.10i, I just upgraded to match the version on a workstation where the issue doesn't show up (anymore)).
    pynrfjprog is 9.6.0.
    nrf-hil:/tmp$ nrfjprog -v
    nrfjprog version: 9.4.0
    JLinkARM.dll version: 6.32c
    nrfjprog says 9.4.0 here, but we're dealing with pynrfjprog with venv.
    Edit: upgraded nrfjprog to 9.6.0, we saw that pynrfjprog seemed to have a dependency to it. It did not help though.
    Now my workstation and this test computer have the same versions of nrfjprog, pynrfjprog, and JLink. I don't know where to look further.
