Power Profiler kit disconnects and the NRF52DK
First time posting, Here are the details of my setup, I would greatly appreciate any help from anyone at this point.
I have purchased 2 nrf52 development kits with 2 power profiler kits to go with them. I am trying to measure the current / power consumption of a lithium ion battery CR2477 in a small test circuit.
1 NRF52DK with 1 PPK plugged together / stacked.
1 external circuit / hardware in breadboard.
1 CR2477 coin cell lithium ion battery (3.0 V).
1 Computer with NRF Connect wand power consumption app installed. (V. 2.3.2 for NRF connect, and 2.0 for the power)
The NRF52DK has jumper SB9 cut, and SB12 joined (as SB12 is for external source)
I have 2 jumper cables running from the battery holder, to the PPK External supply.
I also have 2 jumpers running from External DUT to power the breadboarded circuit.
After I've connected the DK to the computer (PC) it asks for a firmware update, I agree and continue. I select the COM port to use and select start.
It seems to work from here, and we'll get to that in a bit. But after pressing start, the system disconnects or drops into an error for no apparent reason. Please see image below:
I'm not sure if the quality is good enough, however the text under the red highlight it says: "Corrupt data detected, please check connection to PPK"
At this point nothing has changed, no cable has moved, and I checked various micro usb cables connected to the DK.
The issue persists.
Another screenshot of the logged info can be found below:
I'm not sure if this is a known issue, but we're in a tight deadline to test our circuits for power consumption / battery life and it's a bit troublesome that it doesn't work as expected.
I would greatly appreciate anyone's help. I have this setup up and ready to run if anyone has any suggestions or need more information from the device / me.
Thank you in advance
