Improving timing accuracy by only using single advertisement channel?
Hi everyone,
thanks for this discussion - this question addresses almost exactly a potential use case I've been looking into.
I'd like to try and implement something this using just BLE advertising first, without using the timeslot API; the only thing I could not figure out how to do is in MartinBL's reply:
  • Configure it to advertise on a single advertising channel.
  • Have all your other nodes scan continuously on the same channel.
How do I do that? I'm currently using SD130 on nRF51 platform, and I have already tried something along the following lines:
ble_gap_opt_ch_map_t foo;
foo.conn_handle = 0;
foo.ch_map[0] = 0;
foo.ch_map[1] = 0;
foo.ch_map[2] = 0;
foo.ch_map[3] = 0;
foo.ch_map[4] = 0x10;
sd_ble_opt_set(BLE_GAP_OPT_CH_MAP,(const ble_opt_t*)(&foo));
That should disable all channels except 37, but as far as I can tell, it doesn't have any effect.
I've already done a first experiment for measuring the latency (just toggle a pin as soon as an advertisement has been received, and compare across several boards with logic analyzer), but I'm still seeing something around 2-4 ms of difference, so I'm assuming the advertisement channel scan is still happening...
Best regards, Florian
  • Hello Hung, thanks for your answer!
    Regarding the latency you observed with advertising, most likely it's the random delay added into the advertising interval. By spec, each advertising interval requires to have a random delay of <10ms this is to avoid interference of 2 device starting to send advertising packets at the same time with same interval to be collide all the time.
    However, the time difference I was referring to is the time difference between two separate observers, not between individual advertisements. I don't have a problem with timing uncertainty regarding when an advertisement is sent, I only want all receivers to react to the reception of the advertisement with as little individual delay as possible.
    Once again: before I "go down the rabbit hole" of implementing a custom timesync protocol, I want to see if this isn't possible with plain BTLE after all. Think of it as a research question :-)
    Best, Florian
  • Hi Floran,
    Thanks for the explanation. Then it's quite strange that you have the timing difference between to observers. We would need to see how you configure your scanner ? Regarding scan window, scan interval, scan channel.
    Also do you see that all the time or only seldom they didn't toggle at the same time ? Which softdevice did you use to test ?
    If you only plan to sync between observer, using advertising packet could be a solution. However, because of the lack of full control over each adv packet from the advertiser, it's harder to make sure all scanner receives the same adv packet.
    I mean if one scanner receives but one scanner misses the packet, and only receive the one in next advertising interval, you may have a serious drift between 2 scanner.
  • Just wanted to follow up on this: my test implementation had (stupidly) a leftover delay in the main loop. After I removed that, I can now get two scanners to react to one advertisement with less than 20 µs of time difference (just as expected).
    Thanks for your help!
  • P.S. ah, that was maybe a little too soon. Still getting delays between individual nodes that seem to be multiples of 700 µs. Does that correspond to some internal softdevice timer?
  • To illustrate my question in a bit more detail, here's my sampled data. Test setup was as follows:
    • two observers running softdevice S130 v2.0.1 on a single channel (using the parameter hack mentioned above)
    • note: both observers use the RC clock source due to board limitations (no 32 kHz crystal)
    • one nearby advertiser (~ 50 cm) with 450 ms advertising interval
    • one logic analyzer with 100 kHz sampling rate, measuring a pin on both observers that gets toggled immediately when the correct advertisement was received
    The plot shows the time differences between the pin toggles. It's quite apparent that there is a peak at ~ 700 µs and a second one at ~ 1400 µs.
    Can anyone venture an explanation? Maybe , who seems to know a lot about the timing intricacies of the softdevice?
