Crashing during the SPI transfer on NRF52810
The program will crash when spi transfer on NRF52810. The crash occurs in spim_xfer  function, immediately after spim_int_enable function calling,
but if i remove the handler when spi init, it will not crash. I want to know what's going on and how to solve this problem, the spi is very important for me.
And this is my project's sdk_config.h,and the sdk version is nRF5_SDK_15.0.0_a53641a. Did I miss something.
Thanks.
    I replace these code in nrfx_irqs_nrf52810.h, it still lock after the transfer.
    This time it lock at line 288.
    ; Copyright (c) 2009-2018 ARM Limited. All rights reserved.
    ;     SPDX-License-Identifier: Apache-2.0
    ; Licensed under the Apache License, Version 2.0 (the License); you may
    ; not use this file except in compliance with the License.
    ; You may obtain a copy of the License at
    ;     www.apache.org/licenses/LICENSE-2.0
    ; Unless required by applicable law or agreed to in writing, software
    ; distributed under the License is distributed on an AS IS BASIS, WITHOUT
    ; WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
    ; See the License for the specific language governing permissions and
    ; limitations under the License.
    ; NOTICE: This file has been modified by Nordic Semiconductor ASA.
                    IF :DEF: __STARTUP_CONFIG
    #include "startup_config.h"
    #ifndef __STARTUP_CONFIG_STACK_ALIGNEMENT
    #define __STARTUP_CONFIG_STACK_ALIGNEMENT 3
                    ENDIF
    Stack_Size      EQU __STARTUP_CONFIG_STACK_SIZE
                    ELIF :DEF: __STACK_SIZE
    Stack_Size      EQU __STACK_SIZE
                    ELSE
    Stack_Size      EQU     2048
                    ENDIF
    Stack_Align     EQU __STARTUP_CONFIG_STACK_ALIGNEMENT
                    ELSE
    Stack_Align     EQU 3
                    ENDIF
                    AREA    STACK, NOINIT, READWRITE, ALIGN=Stack_Align
    Stack_Mem       SPACE   Stack_Size
    __initial_sp
    Heap_Size       EQU __STARTUP_CONFIG_HEAP_SIZE
                    ELIF :DEF: __HEAP_SIZE
    Heap_Size       EQU __HEAP_SIZE
                    ELSE
    Heap_Size       EQU     2048
                    ENDIF
                    AREA    HEAP, NOINIT, READWRITE, ALIGN=3
    __heap_base
    Heap_Mem        SPACE   Heap_Size
    __heap_limit
                    PRESERVE8
                    THUMB
    ; Vector Table Mapped to Address 0 at Reset
                    AREA    RESET, DATA, READONLY
                    EXPORT  __Vectors
                    EXPORT  __Vectors_End
                    EXPORT  __Vectors_Size
    __Vectors       DCD     __initial_sp              ; Top of Stack
                    DCD     Reset_Handler
                    DCD     NMI_Handler
                    DCD     HardFault_Handler
                    DCD     MemoryManagement_Handler
                    DCD     BusFault_Handler
                    DCD     UsageFault_Handler
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     SVC_Handler
                    DCD     DebugMon_Handler
                    DCD     0                         ; Reserved
                    DCD     PendSV_Handler
                    DCD     SysTick_Handler
                    ; External Interrupts
                    DCD     POWER_CLOCK_IRQHandler
                    DCD     RADIO_IRQHandler
                    DCD     UARTE0_IRQHandler
                    DCD     TWIM0_TWIS0_IRQHandler
                    DCD     SPIM0_SPIS0_IRQHandler
                    DCD     0                         ; Reserved
                    DCD     GPIOTE_IRQHandler
                    DCD     SAADC_IRQHandler
                    DCD     TIMER0_IRQHandler
                    DCD     TIMER1_IRQHandler
                    DCD     TIMER2_IRQHandler
                    DCD     RTC0_IRQHandler
                    DCD     TEMP_IRQHandler
                    DCD     RNG_IRQHandler
                    DCD     ECB_IRQHandler
                    DCD     CCM_AAR_IRQHandler
                    DCD     WDT_IRQHandler
                    DCD     RTC1_IRQHandler
                    DCD     QDEC_IRQHandler
                    DCD     COMP_IRQHandler
                    DCD     SWI0_EGU0_IRQHandler
                    DCD     SWI1_EGU1_IRQHandler
                    DCD     SWI2_IRQHandler
                    DCD     SWI3_IRQHandler
                    DCD     SWI4_IRQHandler
                    DCD     SWI5_IRQHandler
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     PWM0_IRQHandler
                    DCD     PDM_IRQHandler
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
                    DCD     0                         ; Reserved
    __Vectors_End
    __Vectors_Size  EQU     __Vectors_End - __Vectors
                    AREA    |.text|, CODE, READONLY
    ; Reset Handler
    Reset_Handler   PROC
                    EXPORT  Reset_Handler             [WEAK]
                    IMPORT  SystemInit
                    IMPORT  __main
                    LDR     R0, =SystemInit
                    BLX     R0
                    LDR     R0, =__main
                    BX      R0
                    ENDP
    ; Dummy Exception Handlers (infinite loops which can be modified)
    NMI_Handler     PROC
                    EXPORT  NMI_Handler               [WEAK]
                    B       .
                    ENDP
    HardFault_Handler\
                    PROC
                    EXPORT  HardFault_Handler         [WEAK]
                    B       .                        //here
                    ENDP
    MemoryManagement_Handler\
                    PROC
                    EXPORT  MemoryManagement_Handler  [WEAK]
                    B       .
                    ENDP
    BusFault_Handler\
                    PROC
                    EXPORT  BusFault_Handler          [WEAK]
                    B       .
                    ENDP
    UsageFault_Handler\
                    PROC
                    EXPORT  UsageFault_Handler        [WEAK]
                    B       .
                    ENDP
    SVC_Handler     PROC
                    EXPORT  SVC_Handler               [WEAK]
                    B       .
                    ENDP
    DebugMon_Handler\
                    PROC
                    EXPORT  DebugMon_Handler          [WEAK]
                    B       .
                    ENDP
    PendSV_Handler  PROC
                    EXPORT  PendSV_Handler            [WEAK]
                    B       .
                    ENDP
    SysTick_Handler PROC
                    EXPORT  SysTick_Handler           [WEAK]
                    B       .
                    ENDP
    Default_Handler PROC
                    EXPORT   POWER_CLOCK_IRQHandler [WEAK]
                    EXPORT   RADIO_IRQHandler [WEAK]
                    EXPORT   UARTE0_IRQHandler [WEAK]
                    EXPORT   TWIM0_TWIS0_IRQHandler [WEAK]
                    EXPORT   SPIM0_SPIS0_IRQHandler [WEAK]
                    EXPORT   GPIOTE_IRQHandler [WEAK]
                    EXPORT   SAADC_IRQHandler [WEAK]
                    EXPORT   TIMER0_IRQHandler [WEAK]
                    EXPORT   TIMER1_IRQHandler [WEAK]
                    EXPORT   TIMER2_IRQHandler [WEAK]
                    EXPORT   RTC0_IRQHandler [WEAK]
                    EXPORT   TEMP_IRQHandler [WEAK]
                    EXPORT   RNG_IRQHandler [WEAK]
                    EXPORT   ECB_IRQHandler [WEAK]
                    EXPORT   CCM_AAR_IRQHandler [WEAK]
                    EXPORT   WDT_IRQHandler [WEAK]
                    EXPORT   RTC1_IRQHandler [WEAK]
                    EXPORT   QDEC_IRQHandler [WEAK]
                    EXPORT   COMP_IRQHandler [WEAK]
                    EXPORT   SWI0_EGU0_IRQHandler [WEAK]
                    EXPORT   SWI1_EGU1_IRQHandler [WEAK]
                    EXPORT   SWI2_IRQHandler [WEAK]
                    EXPORT   SWI3_IRQHandler [WEAK]
                    EXPORT   SWI4_IRQHandler [WEAK]
                    EXPORT   SWI5_IRQHandler [WEAK]
                    EXPORT   PWM0_IRQHandler [WEAK]
                    EXPORT   PDM_IRQHandler [WEAK]
    RADIO_IRQHandler
    UARTE0_IRQHandler
    GPIOTE_IRQHandler
    SAADC_IRQHandler
    TIMER0_IRQHandler
    TIMER1_IRQHandler
    TIMER2_IRQHandler
    RTC0_IRQHandler
    TEMP_IRQHandler
    RNG_IRQHandler
    ECB_IRQHandler
    CCM_AAR_IRQHandler
    WDT_IRQHandler
    RTC1_IRQHandler
    QDEC_IRQHandler
    COMP_IRQHandler
    SWI2_IRQHandler
    SWI3_IRQHandler
    SWI4_IRQHandler
    SWI5_IRQHandler
    PWM0_IRQHandler
    PDM_IRQHandler
                    B .
                    ENDP
                    ALIGN
    ; User Initial Stack & Heap
                    IF      :DEF:__MICROLIB
                    EXPORT  __initial_sp
                    EXPORT  __heap_base
                    EXPORT  __heap_limit
                    ELSE
                    IMPORT  __use_two_region_memory
                    EXPORT  __user_initial_stackheap
    __user_initial_stackheap PROC
                    LDR     R0, = Heap_Mem
                    LDR     R1, = (Stack_Mem + Stack_Size)
                    LDR     R2, = (Heap_Mem + Heap_Size)
                    LDR     R3, = Stack_Mem
                    BX      LR
                    ENDP
                    ALIGN
                    ENDIF
                    END
    Thanks.
    Best regards.
    It's ok now, there is some errors in my code after replace the spi0_handler.
    Thanks.
    Best regards.
