How can I change characteristic(service,Rx,Tx) UUID ?
Hi, Nordic!
I wanna know how change characteristic(service,Rx,Tx) UUIDs .
For example,
Proximity UUID :  01020304-0506-0708-0910-111213141516
Service UUID :  01020304-0506-0708-0910-AABBCCDDEEFF
Rx Characteristc UUID :  01020305-0506-0708-0910-AABBCCDDEEFF
Tx Characteristc UUID :  01020306-0506-0708-0910-AABBCCDDEEFF
I succeeded in changing the 0305,0306,0307 part. However, I did not change the AABBCCDDEEFF part.
Please ask for help on this issue.
Thank you.
Below is the code I modified.
static uint32_t rx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
/**@snippet [Adding proprietary characteristic to S110 SoftDevice] */
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&cccd_md, 0, sizeof(cccd_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.notify = 1;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = &cccd_md;
char_md.p_sccd_md = NULL;
ble_uuid.type = p_nus->uuid_type;
ble_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 1;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = BLE_NUS_MAX_RX_CHAR_LEN;
ble_uuid_t char_uuid;
ble_uuid128_t base_uuid = NUS_BASE_UUID;
BLE_UUID_BLE_ASSIGN(char_uuid, 0xda40);
base_uuid.uuid128[0]=0x17;
base_uuid.uuid128[1]=0x53;
base_uuid.uuid128[2]=0x08;
base_uuid.uuid128[3]=0x19;
base_uuid.uuid128[4]=0xfc;
base_uuid.uuid128[5]=0x1a;
char_uuid.type = p_nus->uuid_type;
//ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
char_uuid.uuid = 0xda40;
uint32_t err_code;
err_code =sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
app_uart_put(err_code);
return sd_ble_gatts_characteristic_add(p_nus->service_handle,
&char_md,
&attr_char_value,
&p_nus->rx_handles);
  • Sorry, sdk_config.h did not include stack configurations in earlier SDK versions, believe it was introduced in SDK 13.
    You can set the UUID count in ble_stack_init():
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(NRF_BLE_CENTRAL_LINK_COUNT,
                                                        NRF_BLE_PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        ble_enable_params.common_enable_params.vs_uuid_count = //Allocate buffer space for 128-bit base UUIDs
    Note: this will increase the softdevice's RAM usage which may require you to increase the APP ram start address in your linker configuration. See debug log for details.
  • static void ble_stack_init(void)
        uint32_t err_code;
        // Initialize SoftDevice.
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
        ble_enable_params.common_enable_params.vs_uuid_count = 2;//Allocate buffer space for 128-bit base UUIDs
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
    #if (NRF_SD_BLE_API_VERSION == 3)
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    As a result of modifying the above code, it will not advertise.
    Which part am I doing wrong?
  • Do you have debug logging enabled? It should print out the lowest RAM address you can use with current configuration. Alternatively, just increase the RAM start address by ~20 bytes or more, enough to store the new base UUID. Just let me know what toolchain/IDE you use if you are unsure on how you can do this.
  • I use Keil (uVision5).
    I found RAM start address (0x20000000). I changed this value, but it was not resolved.
  • RAM_START_ADDRESS should not be changed, it's used to calculate the total RAM area. Configuration of the application RAM address is done in "options for target":
