SAADC Calibration Lock Up
I am trying to implement a periodic calibration routine that is transparent to upper layers of my application.
I have the SAADC set up to continuously sample one channel (oversample X4) and I am dual buffering into two 512-byte buffers. I call calibration every 5 seconds using a Ticker provided by mbed.
My calibration routine, executed in the interrupt context, used to look like this:
void calibrate_saadc(void) {
nrf_drv_saadc_abort();
while(nrf_drv_saadc_calibrate_offset() != NRF_SUCCESS);
What I found was that it would hang on the while() loop since the ADC would stay busy... not sure why.
So then I tried changing it to trigger calibration in the SAADC driver callback (which should get executed when nrf_drv_saadc_abort() is called, it will report a smaller buffer than expected). If the buffer was smaller than expected (meaning it was aborted for calibration), I then execute the while(nrf_drv_saadc_calibrate_offset() != NRF_SUCCESS) line...
However, this line never ends up getting called and my application just halts since there are no more SAADC events to drive execution.
Could someone explain the events the SAADC driver/HAL should see for calibration to be carried out properly?
EDIT: I have viewed the examples in the github repository found here: https://github.com/NordicPlayground/nRF52-ADC-examples/blob/master/saadc_low_power/main.c
They flag the calibration event and execute it in the thread context. I am writing a low level driver that doesn't currently have a convenient way to defer processing to a thread with the current structure. How is the nrf_drv_saadc_calibrate_offset() function supposed to be used?
