BLE RELAY EXAMPLE
hello support  team
nRF52 DK , Mesh 2.01
I am trying Experimental BLE RELAY example.
1. In first trial I am using 1 RELAY DK  all works well.
2.In second Trial I am using 3 RELAY DK  nothing happens at collector side
Any check list how can debug or check . nRF connect showing no services.
    In the BLE Relay Example, "collector" refers to any device implementing the Collector role for the Heart Rate Profile. That profile is specified by the Bluetooth SIG.
    For instance, you can use our BLE Heart Rate Collector Example. That example only connects to one peripheral. To see how to connect to multiple peripherals you can have a look at our BLE Multi-link Example.
    Terje
  • Hi Terje,
    Thanks for your prompt reply again. Noted there is a spec on Collector role. i will look into it.
    Let me try to be more specific here, at least for the other parts of my question.
    My first question is whether a "relay" node able to carry its own senor data while he perform the role as a "relay". From this diagram, it seem there are two nodes each has its own sensor. To put it simpler, we say, there is only one sensor, HR, on each node.
    My second question is whether this "collector" node in BLE Relay Example able to receive sensor data from both peripheral and relay. Please note there are two set of data going to collector but only one connection. If this is possible, can you briefly explain how?
    i suppose my third questions arise when you provide me the idea of a multi-link collector. Can i have a few more "relay", not just more peripherals, to be connected to a collector?
    Appreciate your kind advice soon, pls.
    From what I understand, the device should only provide one data set through one service. That means if it should both generate data itself and relay data from a different device it should provide that as two separate services.
    Then in question 2 it becomes a new question if the collector is getting two sets of data from the relay, or if it is connected to two different peripherals at the same time, getting one set of data from each. Both alternatives should be possible.
    I am not quite sure what you mean in question 3. Can you elaborate?
    Terje
  • From the diagram we can see there are three devices and each played a different role.
    Understand a peripheral device provides its sensor data, and it is pass to relay. Can the relay device generate (connected with same kind of sensor) its own data, and then pass packet 1 (eg HR 110bpm) from peripheral, and packet 2 (HR 70bpm) of itself, to the collector? Can a collector collects these two packets?
    Let me elaborate Q3 (same coin different side). For example, we have 6 devices, and each is connected to same kind of HR sensor. We will like to program 3 of these devices to measure HR as peripherals and it is connected to a relay_A. And another 2 devices is also programmed to measure HR as peripherals but these two pass data to relay_B. The last device is used to collect two 5 sets of data, 3 sets from relay_A and 2 sets from relay_B. Is this possible as we used our multi-peripheral, multi-link, and relay combine?
    According to the Heart Rate Profile (found in list of GATT Specifications from bluetooth.com), "The Heart Rate Sensor shall instantiate one and only one Heart Rate Service" This means the peripheral and the relay can only provide one instance of the Heart Rate Service, and so you cannot relay measurements in one service and provide measurements from the relay in another service.
    There are no such limitations on the Collector Role, so you could rewrite the collector to connect to and collect data from all 6 Heart Rate Sensors directly.
    Another alternative could be to use a custom service for the relay, for sending heart rate measurements from multiple devices. You can do that if you control the relay and the collector, so that you can make a vendor specific service for that.
    Terje
