I followed the instructions for importing the Thing:52 firmware into SES and managed to get the firmware compiled and loading, and the code reaches the main function without any apparent problem. When it gets to the application though I get an error in m_ble_flash_init. The problem is in the structure returned by FS_SECTION_ITEM_GET(i) within fs_init (called within m_ble_init->m_ble_flash_init->fsd_init) - particularly in these lines (fstorage.c:363) : -
p_config_i = FS_SECTION_ITEM_GET(max_index);
p_config_i->p_end_addr = p_current_end;
p_config_i->p_start_addr = p_current_end - (p_config_i->num_pages * FS_PAGE_SIZE_WORDS);
The write of p_current_end to p_config_i>p_end_addr doesn't happen and the value remains 0. The same is true for p_config_i->p_start_addr.
p_current_end is 0x00080000, i.e. the end of the flash section - as expected. The p_config pointer is pointing to 0x5beac.
Of course what then happens is that p_current_end gets update to 0x0: -
p_current_end = p_config_i->p_start_addr;
This causes problems later on.
There are earlier warnings which Iooked into. The first on happens because all the structure values are 0, so the drv_ext_light_off driver tries to setup a timer with timeout_ticks = 0, so this generated an NRF_ERROR_INVALID_PARAM error.
It seems these errors could all be down to the same root cause - the inability to write to these structures.
Any idea what I am doing wrong?
Thanks in advance for any help.
Phil.
p.s. If it is useful - here is the trace from the debug console.
main :INFO:===== Thingy started! =====
drv_ext_light :WARNING:Err code returned in file: /Users/derrick/work/third-party/Nordic-Thingy52-FW/source/drivers/drv_ext_light.c, line: 754, code 7
drv_ext_light :WARNING:Err code returned in file: /Users/derrick/work/third-party/Nordic-Thingy52-FW/source/drivers/drv_ext_light.c, line: 858, code 7
m_env :INFO:Init:
m_motion :INFO:Init
m_sound :INFO:Sound_init
m_ble :WARNING:Too few random bytes available. Trying again
m_ble :INFO:Available random bytes: 16
m_ble :INFO:Random value (hex): 2x2x2x2x
m_ble_flash :INFO:Initialization
m_ble_flash :WARNING:Err code returned in file: /Users/derrick/work/third-party/Nordic-Thingy52-FW/source/modules/m_ble_flash.c, line: 197, code 11
m_ble :ERROR: m_ble_flash_init failed - 11
main :ERROR: id = 16385, pc = 0, file = /Users/derrick/work/third-party/Nordic-Thingy52-FW/project/pca20020_s132/main.c, line number: 304, error code = 11 = NRF_ERROR_INVALID_DATA
