DFU with sd_power_system_off
Is it possible for an app after having gone to sd_power_system_off to reset by button without triggering DFU?
The app seems to need CONFIG_GPIO_AS_PINRESET to be set so that button p0.21 can get the app to advertise again, but when DFU is loaded, the advertise becomes DfuTarg. I was looking at invoking DfuTarg only when button p0.21 is pressed as power is being applied.
For DFU I tried enter_method_button 1 with enter_method_button_pin 21 (the app after system_off, button pressed goes to DfuTarg) , and separately enter_method_pinreset 0 (the app after system_off, no response with button pressed, but advertises app after power toggle but then no DFU).
-thank-you.
  • Hi Simon,
    Can you upload the code you have in the bootloader for deciding whether to enter DFU mode or not? I assume it is in nrf_bootloader.c, but it would be good to see the modifications you have done to the bootloader (including any libraries it uses).
  • Yes of course, the most important file. I had been using this sdk for the libraries nRF5_SDK_15_52810_bootloader_iar_keil_ses_gcc.zip. found at this case 32918.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_bootloader.h"
    #include "compiler_abstraction.h"
    #include "nrf.h"
    #include "boards.h"
    #include "sdk_config.h"
    #include "nrf_power.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_dfu.h"
    #include "nrf_error.h"
    #include "nrf_dfu_settings.h"
    #include "nrf_dfu_utils.h"
    #include "nrf_bootloader_wdt.h"
    #include "nrf_bootloader_info.h"
    #include "nrf_bootloader_app_start.h"
    #include "nrf_bootloader_fw_activation.h"
    #include "nrf_bootloader_dfu_timers.h"
    #include "app_scheduler.h"
    #include "app_timer.h"
    #include "nrf_soc.h"
    static nrf_dfu_observer_t m_user_observer; //<! Observer callback set by the user.
    #define SCHED_QUEUE_SIZE      32          /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE MAX(NRF_DFU_SCHED_EVENT_DATA_SIZE, APP_TIMER_SCHED_EVENT_DATA_SIZE) /**< Maximum app_scheduler event size. */
    #if !(defined(NRF_BL_DFU_ENTER_METHOD_BUTTON)    && \
          defined(NRF_BL_DFU_ENTER_METHOD_PINRESET)  && \
          defined(NRF_BL_DFU_ENTER_METHOD_GPREGRET)  && \
          defined(NRF_BL_DFU_ENTER_METHOD_BUTTONLESS))
        #error Configuration file is missing flags. Update sdk_config.h.
    STATIC_ASSERT((NRF_BL_DFU_INACTIVITY_TIMEOUT_MS >= 100) || (NRF_BL_DFU_INACTIVITY_TIMEOUT_MS == 0),
                 "NRF_BL_DFU_INACTIVITY_TIMEOUT_MS must be 100 ms or more, or 0 to indicate that it is disabled.");
    #if defined(NRF_LOG_BACKEND_FLASH_START_PAGE)
    STATIC_ASSERT(NRF_LOG_BACKEND_FLASH_START_PAGE != 0,
        "If nrf_log flash backend is used it cannot use space after code because it would collide with settings page.");
    /**@brief Weak implemenation of nrf_dfu_init
     * @note   This function will be overridden if nrf_dfu.c is
     *         compiled and linked with the project
     #if (__LINT__ != 1)
    __WEAK uint32_t nrf_dfu_init(nrf_dfu_observer_t observer)
        NRF_LOG_DEBUG("in weak nrf_dfu_init");
        return NRF_SUCCESS;
    /**@brief Weak implementation of nrf_dfu_init
     * @note    This function must be overridden in application if
     *          user-specific initialization is needed.
    __WEAK uint32_t nrf_dfu_init_user(void)
        NRF_LOG_DEBUG("in weak nrf_dfu_init_user");
        return NRF_SUCCESS;
    static void bootloader_reset(void)
        NRF_LOG_DEBUG("Resetting bootloader.");
        NRF_LOG_FINAL_FLUSH();
    #if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
        // To allow the buffer to be flushed by the host.
        nrf_delay_ms(100);
        NVIC_SystemReset();
    static void inactivity_timeout(void)
        NRF_LOG_INFO("Inactivity timeout.");
        bootloader_reset();
    /**@brief Function for handling DFU events.
    static void dfu_observer(nrf_dfu_evt_type_t evt_type)
        switch (evt_type)
            case NRF_DFU_EVT_DFU_STARTED:
            case NRF_DFU_EVT_OBJECT_RECEIVED:
                nrf_bootloader_dfu_inactivity_timer_restart(NRF_BL_DFU_INACTIVITY_TIMEOUT_MS, inactivity_timeout);
            case NRF_DFU_EVT_DFU_COMPLETED:
            case NRF_DFU_EVT_DFU_ABORTED:
                bootloader_reset();
        if (m_user_observer)
            m_user_observer(evt_type);
    /**@brief Function for initializing the event scheduler.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    /**@brief Suspend the CPU until an interrupt occurs.
    static void wait_for_event(void)
    #ifdef BLE_STACK_SUPPORT_REQD
        (void)sd_app_evt_wait();
    #else
        // Wait for an event.
        __WFE();
        // Clear the internal event register.
        __SEV();
        __WFE();
    /**@brief Continually sleep and process tasks whenever woken.
    static void loop_forever(void)
        while (true)
            //feed the watchdog if enabled.
            nrf_bootloader_wdt_feed();
            app_sched_execute();
            if (!NRF_LOG_PROCESS())
                wait_for_event();
    /**@brief Function for initializing button used to enter DFU mode.
    static void dfu_enter_button_init(void)
        nrf_gpio_cfg_sense_input(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN,
                                 BUTTON_PULL,
                                 NRF_GPIO_PIN_SENSE_LOW);
    static bool crc_on_valid_app_required(void)
        bool ret = true;
        if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET &&
            (nrf_power_resetreas_get() & NRF_POWER_RESETREAS_OFF_MASK))
            nrf_power_resetreas_clear(NRF_POWER_RESETREAS_OFF_MASK);
            ret = false;
        else if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2 &&
                (nrf_power_gpregret2_get() & BOOTLOADER_DFU_SKIP_CRC))
            nrf_power_gpregret2_set(nrf_power_gpregret2_get() & ~BOOTLOADER_DFU_SKIP_CRC);
            ret = false;
        return ret;
    /**@brief Function for clearing all DFU enter flags that
     *        preserve state during reset.
     * @details This is used to make sure that each of these flags
     *          is checked only once after reset.
    static void dfu_enter_flags_clear(void)
        if (NRF_BL_DFU_ENTER_METHOD_PINRESET &&
           (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk))
            // Clear RESETPIN flag.
            NRF_POWER->RESETREAS |= POWER_RESETREAS_RESETPIN_Msk;
        if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
            // Clear DFU mark in GPREGRET register.
            nrf_power_gpregret_set(nrf_power_gpregret_get() & ~BOOTLOADER_DFU_START);
        if (NRF_BL_DFU_ENTER_METHOD_BUTTONLESS &&
           (s_dfu_settings.enter_buttonless_dfu == 1))
            // Clear DFU flag in flash settings.
            s_dfu_settings.enter_buttonless_dfu = 0;
            APP_ERROR_CHECK(nrf_dfu_settings_write(NULL));
    /**@brief Function for checking whether to enter DFU mode or not.
    static bool dfu_enter_check(void)
    	/* Configure wakeup pin */
    	nrf_gpio_cfg_sense_input(BSP_BUTTON_0, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    	if (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk)
    			NRF_POWER->RESETREAS = ~POWER_RESETREAS_RESETPIN_Msk;
    	if (!nrf_dfu_app_is_valid(crc_on_valid_app_required()))
    //        NRF_LOG_DEBUG("DFU mode because app is not valid.");
    //        return true;
    //		if (NRF_BL_DFU_ENTER_METHOD_BUTTON &&
    //       (nrf_gpio_pin_read(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN) == 0))
    //        NRF_LOG_DEBUG("DFU mode requested via button.");
    //        return true;
    ////		if ((nrf_gpio_pin_read(21) == 0))
    ////        NRF_LOG_DEBUG("DFU mode requested via button.");
    ////        return true;
    //				uint32_t reset_reason;
    //				sd_power_reset_reason_get(&reset_reason);
    //				sd_power_reset_reason_clr(~0);
    //				if (reset_reason > 0)
    //						NRF_LOG_DEBUG("Ignoring DFU button as device is not powered cycled.");
    //				else
    //						NRF_LOG_DEBUG("DFU mode requested via button after power on reset.");
    //						return true;
    //				/* Configure wakeup pin */
    //				nrf_gpio_cfg_sense_input(BSP_BUTTON_0, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    //				if (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk)
    //						NRF_POWER->RESETREAS = ~POWER_RESETREAS_RESETPIN_Msk;
    //				if(NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk)
    ////				else if (NRF_POWER->RESETREAS == 0)
    ////						// Check if wake-up button is also pressed (even if we woke up due to power on reset)
    ////						if(nrf_gpio_pin_read(BSP_BUTTON_0) == 0)
    ////								// Wake up from power on reset *AND* wakeup button is pushed. This is where we enter DFU mode!
    ////								return true;
    //								return true;
    //				if (NRF_POWER->RESETREAS == 0 && nrf_gpio_pin_read(BSP_BUTTON_0) == 0)
    //					if (NRF_POWER->RESETREAS & !POWER_RESETREAS_OFF_Msk)
    //						return false;
    //					else
    //						return true;
            // Light LED 1 to indicate pin reset
    //        bsp_board_led_on(0);
    			    return false;
            // Light LED 2 to indicate power on or brown out reset
    //        bsp_board_led_on(1);
                // Wake up from power on reset *AND* wakeup button is pushed. This is were we enter DFU mdoe!
                // Light LED 3 as well to indicate GPIO pin is pressed.
    //            bsp_board_led_on(2);
    											return true;
    					return false;
        else if (NRF_POWER->RESETREAS & POWER_RESETREAS_OFF_Msk)
            // Light LED 3 to indicate wakeup from GPIO (without power cycle)
    			    return false;
            // Light LED 4 to indicate other wakeup reason
    //        bsp_board_led_on(3);
        return false;
    //    if (NRF_BL_DFU_ENTER_METHOD_PINRESET &&
    //       (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk))
    //        NRF_LOG_DEBUG("DFU mode requested via pin-reset.");
    //        return true;
    //    if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
    //       (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
    //        NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
    //        return true;
    //    if (NRF_BL_DFU_ENTER_METHOD_BUTTONLESS &&
    //       (s_dfu_settings.enter_buttonless_dfu == 1))
    //        NRF_LOG_DEBUG("DFU mode requested via bootloader settings.");
    //        return true;
        return false;
    ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
        NRF_LOG_DEBUG("In nrf_bootloader_init");
        uint32_t                              ret_val;
        nrf_bootloader_fw_activation_result_t activation_result;
        uint32_t                              initial_timeout;
        bool                                  dfu_enter = false;
        m_user_observer = observer;
        if (NRF_BL_DFU_ENTER_METHOD_BUTTON)
            dfu_enter_button_init();
        ret_val = nrf_dfu_settings_init(false);
        if (ret_val != NRF_SUCCESS)
            return NRF_ERROR_INTERNAL;
        // Check if an update needs to be activated and activate it.
        activation_result = nrf_bootloader_fw_activate();
        switch (activation_result)
            case ACTIVATION_NONE:
                initial_timeout = NRF_BL_DFU_INACTIVITY_TIMEOUT_MS;
                dfu_enter       = dfu_enter_check();
            case ACTIVATION_SUCCESS_EXPECT_ADDITIONAL_UPDATE:
                initial_timeout = NRF_BL_DFU_CONTINUATION_TIMEOUT_MS;
                dfu_enter       = true;
            case ACTIVATION_SUCCESS:
                bootloader_reset();
                NRF_LOG_ERROR("Should never come here: After bootloader_reset()");
                return NRF_ERROR_INTERNAL; // Should not reach this.
            case ACTIVATION_ERROR:
        if (dfu_enter)
            nrf_bootloader_wdt_init();
            scheduler_init();
            // Clear all DFU stop flags.
            dfu_enter_flags_clear();
            // Call user-defined init function if implemented
            ret_val = nrf_dfu_init_user();
            nrf_bootloader_dfu_inactivity_timer_restart(initial_timeout, inactivity_timeout);
            ret_val = nrf_dfu_init(dfu_observer);
            NRF_LOG_DEBUG("Enter main loop");
            loop_forever(); // This function will never return.
            NRF_LOG_ERROR("Should never come here: After looping forever.");
            // Erase additional data like peer data or advertisement name
            ret_val = nrf_dfu_settings_additional_erase();
            nrf_bootloader_app_start();
            NRF_LOG_ERROR("Should never come here: After nrf_bootloader_app_start()");
        // Should not be reached.
  • With this code, NRF_POWER->RESETREAS must be 0 in order to enter DFU mode (in addition to the button press), and the only situations where it should be all zero are:
    • Power on reset
    • Brownout reset
    • NRF_POWER->RESETREAS has been cleared before it is read (after reset)
    The crc_on_valid_app_required() is called before you do the other check, and this will clear the RESETREAS in some cases. Can you move this check to the end of the dfu_enter_check function? Then you should also remove all the "return false" statements, and only return false in the end of the function if no of the "positive" cases are hit.
