Entering DFU via GPREGET, secure bootloader serial example not feeding WDT in SDKv15
Hello!
I have a custom nRF52832 board with an FTDI usb/serial part running my app successfully.
I generally program the board with a JLINK and SWD, but I am working to add DFU over usb/serial using the secure bootloader serial example.
I can set GPREGET in my app and soft reset to enter DFU in the bootloader.
I am successfully able to use nrfutil to perform a DFU of my application over serial. Also, if I set GPREGET in my app and soft reset to enter the DFU, but do not initiate the DFU update using nrfutil, eventually, the bootloader times out for inactivity after 10 seconds or so and resets back into my application.
So far so good!
However, when I enable a WDT in my app, the trouble starts.
1. If I make my WDT very long (say 20 seconds), when soft resetting into the bootloader, the ~10s inactivity timer no longer works. If I simply disable the WDT, the ~10s inactivity timer works again. If I wait out the 20 second WDT timer when in the bootloader, the WDT does its thing and resets back to my app.
2. If I make my WDT short (say 4 seconds) while leaving the inactivity timer at ~10s, the WDT is clearly not being fed by the bootloader because a soft reset back to my app happens after 4 seconds.
3. If I leave my WDT short (say 4 seconds), and I add an nrf_delay_ms of 2 seconds at the start of the bootloader, followed by manually feeding the WDT with a nrf_wdt_reload_request_set(NRF_WDT_RR0), I can see that the feeding works, as the bootloader soft resets back to my app after 6 seconds. If I leave the nrf_delay_ms of 2 seconds without the manual feeding, the bootloader soft resets back to the app after 4 seconds.
So my questions are:
1. Why does the Nordic code in the SDKv15 secure bootloader not feed my WDT? Inspecting the code, it seems like it should be feeding the WDT in both the event scheduling loop and possibly by an app timer. I can't seem to get the bootloader code to feed my WDT either "out of the box" or by hacking in an application timer.
2. Why when I enable the WDT (for example 20 seconds), does my 10s inactivity timer stop working? The inactivity timer appears to just be a simple one shot app timer performing a system reset. I don't understand how the presence of the WDT would interfere with the 10s inactivity timer.
Thanks!
Jeremy
  • Strange that app_timerv2 didn't work for you.
    Attached is the nrf_bootloader.c file I modified to start a WDT that timeout in 7 seconds and then change the nrf_bootloader_dfu_inactivity_timer_restart() to blink an LED after 10 seconds, I didn't see the WDT triggered any reset. ( I commented out the feeding in the main loop).
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_bootloader.h"
    #include "nrf_bootloader_dfu_timers.h"
    #include "compiler_abstraction.h"
    #include "nrf.h"
    #include "boards.h"
    #include "sdk_config.h"
    #include "nrf_power.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_dfu.h"
    #include "nrf_error.h"
    #include "nrf_dfu_settings.h"
    #include "nrf_dfu_utils.h"
    #include "nrf_bootloader_wdt.h"
    #include "nrf_bootloader_info.h"
    #include "nrf_bootloader_app_start.h"
    #include "nrf_bootloader_fw_activation.h"
    #include "app_scheduler.h"
    #include "app_timer.h"
    static nrf_dfu_observer_t m_user_observer; //<! Observer callback set by the user.
    #define SCHED_QUEUE_SIZE      32          /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE MAX(NRF_DFU_SCHED_EVENT_DATA_SIZE, APP_TIMER_SCHED_EVENT_DATA_SIZE) /**< Maximum app_scheduler event size. */
    #if !(defined(NRF_BL_DFU_ENTER_METHOD_BUTTON)    && \
          defined(NRF_BL_DFU_ENTER_METHOD_PINRESET)  && \
          defined(NRF_BL_DFU_ENTER_METHOD_GPREGRET)  && \
          defined(NRF_BL_DFU_ENTER_METHOD_BUTTONLESS))
        #error Configuration file is missing flags. Update sdk_config.h.
    STATIC_ASSERT((NRF_BL_DFU_INACTIVITY_TIMEOUT_MS >= 100) || (NRF_BL_DFU_INACTIVITY_TIMEOUT_MS == 0),
                 "NRF_BL_DFU_INACTIVITY_TIMEOUT_MS must be 100 ms or more, or 0 to indicate that it is disabled.");
    #if defined(NRF_LOG_BACKEND_FLASH_START_PAGE)
    STATIC_ASSERT(NRF_LOG_BACKEND_FLASH_START_PAGE != 0,
        "If nrf_log flash backend is used it cannot use space after code because it would collide with settings page.");
    /**@brief Weak implemenation of nrf_dfu_init
     * @note   This function will be overridden if nrf_dfu.c is
     *         compiled and linked with the project
     #if (__LINT__ != 1)
    __WEAK uint32_t nrf_dfu_init(nrf_dfu_observer_t observer)
        NRF_LOG_DEBUG("in weak nrf_dfu_init");
        return NRF_SUCCESS;
    /**@brief Weak implementation of nrf_dfu_init
     * @note    This function must be overridden in application if
     *          user-specific initialization is needed.
    __WEAK uint32_t nrf_dfu_init_user(void)
        NRF_LOG_DEBUG("in weak nrf_dfu_init_user");
        return NRF_SUCCESS;
    static void bootloader_reset(void)
        NRF_LOG_DEBUG("Resetting bootloader.");
        NRF_LOG_FINAL_FLUSH();
    #if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
        // To allow the buffer to be flushed by the host.
        nrf_delay_ms(100);
        NVIC_SystemReset();
    static void inactivity_timeout(void)
        NRF_LOG_INFO("Inactivity timeout.");
        bootloader_reset();
    /**@brief Function for handling DFU events.
    static void dfu_observer(nrf_dfu_evt_type_t evt_type)
        switch (evt_type)
            case NRF_DFU_EVT_DFU_STARTED:
            case NRF_DFU_EVT_OBJECT_RECEIVED:
                nrf_bootloader_dfu_inactivity_timer_restart(NRF_BL_DFU_INACTIVITY_TIMEOUT_MS, inactivity_timeout);
            case NRF_DFU_EVT_DFU_COMPLETED:
            case NRF_DFU_EVT_DFU_ABORTED:
                bootloader_reset();
        if (m_user_observer)
            m_user_observer(evt_type);
    /**@brief Function for initializing the event scheduler.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    /**@brief Suspend the CPU until an interrupt occurs.
    static void wait_for_event(void)
    #ifdef BLE_STACK_SUPPORT_REQD
        (void)sd_app_evt_wait();
    #else
        // Wait for an event.
        __WFE();
        // Clear the internal event register.
        __SEV();
        __WFE();
    /**@brief Continually sleep and process tasks whenever woken.
    static void loop_forever(void)
        while (true)
            //feed the watchdog if enabled.
       //     nrf_bootloader_wdt_feed();
            app_sched_execute();
            if (!NRF_LOG_PROCESS())
    //            wait_for_event();
    /**@brief Function for initializing button used to enter DFU mode.
    static void dfu_enter_button_init(void)
        nrf_gpio_cfg_sense_input(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN,
                                 BUTTON_PULL,
                                 NRF_GPIO_PIN_SENSE_LOW);
    static bool crc_on_valid_app_required(void)
        bool ret = true;
        if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET &&
            (nrf_power_resetreas_get() & NRF_POWER_RESETREAS_OFF_MASK))
            nrf_power_resetreas_clear(NRF_POWER_RESETREAS_OFF_MASK);
            ret = false;
        else if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2 &&
                (nrf_power_gpregret2_get() & BOOTLOADER_DFU_SKIP_CRC))
            nrf_power_gpregret2_set(nrf_power_gpregret2_get() & ~BOOTLOADER_DFU_SKIP_CRC);
            ret = false;
        return ret;
    /**@brief Function for clearing all DFU enter flags that
     *        preserve state during reset.
     * @details This is used to make sure that each of these flags
     *          is checked only once after reset.
    static void dfu_enter_flags_clear(void)
        if (NRF_BL_DFU_ENTER_METHOD_PINRESET &&
           (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk))
            // Clear RESETPIN flag.
            NRF_POWER->RESETREAS |= POWER_RESETREAS_RESETPIN_Msk;
        if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
            // Clear DFU mark in GPREGRET register.
            nrf_power_gpregret_set(nrf_power_gpregret_get() & ~BOOTLOADER_DFU_START);
        if (NRF_BL_DFU_ENTER_METHOD_BUTTONLESS &&
           (s_dfu_settings.enter_buttonless_dfu == 1))
            // Clear DFU flag in flash settings.
            s_dfu_settings.enter_buttonless_dfu = 0;
            APP_ERROR_CHECK(nrf_dfu_settings_write(NULL));
    /**@brief Function for checking whether to enter DFU mode or not.
    static bool dfu_enter_check(void)
        if (!nrf_dfu_app_is_valid(crc_on_valid_app_required()))
            NRF_LOG_DEBUG("DFU mode because app is not valid.");
            return true;
        if (NRF_BL_DFU_ENTER_METHOD_BUTTON &&
           (nrf_gpio_pin_read(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN) == 0))
            NRF_LOG_DEBUG("DFU mode requested via button.");
            return true;
            NRF_LOG_DEBUG("DFU mode requested via pin-reset.");
            return true;
            NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
            return true;
            NRF_LOG_DEBUG("DFU mode requested via bootloader settings.");
            return true;
        return false;
    static void LED_1_handler(void)
        nrf_gpio_pin_toggle(20);
    static void LED_2_handler(void)
        nrf_gpio_pin_toggle(19);
    //    wdt_feed();
    void WatchDogInit(uint8_t time_s)
    	NRF_WDT->CONFIG =  	(WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
    	NRF_WDT->CRV = (32768 * time_s)-1;
    	NRF_WDT->RREN = WDT_RREN_RR0_Msk;
        NRF_WDT->INTENSET=WDT_INTENSET_TIMEOUT_Msk;
                                    sd_nvic_ClearPendingIRQ(WDT_IRQn);
    	sd_nvic_SetPriority				(WDT_IRQn, APP_IRQ_PRIORITY_HIGH);
    	sd_nvic_EnableIRQ	 (WDT_IRQn);
    	NRF_WDT->TASKS_START = 1; // Watchdog start
    ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
        NRF_LOG_DEBUG("In nrf_bootloader_init");
        uint32_t                              ret_val;
        nrf_bootloader_fw_activation_result_t activation_result;
        uint32_t                              initial_timeout;
        bool                                  dfu_enter = false;
        m_user_observer = observer;
        if (NRF_BL_DFU_ENTER_METHOD_BUTTON)
            dfu_enter_button_init();
        ret_val = nrf_dfu_settings_init(false);
        if (ret_val != NRF_SUCCESS)
            return NRF_ERROR_INTERNAL;
        // Check if an update needs to be activated and activate it.
        activation_result = nrf_bootloader_fw_activate();
        switch (activation_result)
            case ACTIVATION_NONE:
                initial_timeout = NRF_BL_DFU_INACTIVITY_TIMEOUT_MS;
                dfu_enter       = dfu_enter_check();
            case ACTIVATION_SUCCESS_EXPECT_ADDITIONAL_UPDATE:
                initial_timeout = NRF_BL_DFU_CONTINUATION_TIMEOUT_MS;
                dfu_enter       = true;
            case ACTIVATION_SUCCESS:
                bootloader_reset();
                NRF_LOG_ERROR("Should never come here: After bootloader_reset()");
                return NRF_ERROR_INTERNAL; // Should not reach this.
            case ACTIVATION_ERROR:
        if (dfu_enter)
            WatchDogInit(7);
            nrf_bootloader_wdt_init();
            scheduler_init();
            // Clear all DFU stop flags.
            dfu_enter_flags_clear();
            // Call user-defined init function if implemented
            ret_val = nrf_dfu_init_user();
            nrf_bootloader_dfu_inactivity_timer_restart(10000, LED_1_handler);
            ret_val = nrf_dfu_init(dfu_observer);
            NRF_LOG_DEBUG("Enter main loop");
            loop_forever(); // This function will never return.
            NRF_LOG_ERROR("Should never come here: After looping forever.");
            // Erase additional data like peer data or advertisement name
            ret_val = nrf_dfu_settings_additional_erase();
            nrf_bootloader_app_start();
            NRF_LOG_ERROR("Should never come here: After nrf_bootloader_app_start()");
        // Should not be reached.
  • Hmm, yeah, not sure what's up. I will try out your changed nrf_bootloader.c on my hardware, with my config, with my version of gcc, etc.
    For now, I'm happy with my solution to use nrf_drv_timer in main.c, as it co-exists side by side with the existing code in the bootloader library (which fails to work for me), so if it ends up being a config issue, or compiler issue, or bug in my custom hardware, it would be easy to remove.
  • I have the same problem: Serial bootloader, and when the watchdog is enabled in my app the timers fail in the same way (it seems like all timers in the bootloader are never triggered) and the WDT is not fed. Unfortunately your workaround doesn't work for me either...
    Did you use the SoftDevice or MBR?
  • Ok sorry my mistake... the workaround works, after setting NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY right...
