Thread SDK hardcodes UART pins
From what I can tell, the SDK for Thread provided from Nordic uses a precompiled Openthread library that hardcodes the UART pin configuration. This means that users of this SDK must modify and recompile the library manually if they want to use the Thread SDK on their own boards with different pin configurations. The Openthread library is meant to compile as a platform independent binary, and the Nordic supplied SDK should include the specific lower layer code separately. This along with an application/board specific sdk-config.h file would allow the required flexibility.
Are there any plans to support this?
Thanks!
    The UART0 is configured in the OpenThread library. It is set up as default, with pins P0.06 and P0.08. Only UART0 is used, so you can set up and use the other instances of the UART as you like. If you want to change the UART0, however, you need to rebuild the OpenThread library.
    See the section "Building the latest OpenThread libraries" section in our Thread documentation.
    If you build the latest version of the OpenThread library, the examples from the SDK will probably not work out of the box anymore. If you build with the same version used to build the library as the SDK uses, you shouldn't need to change anything in the description.
    In the 2.0.0 version of the Thread SDK, it is mentioned in the nRF5_SDK_for_Thread_and_zigbee_2.2.0_29775ac\external\openthread\project\readme.txt what commit that is used:
    "OpenThread libraries projects are based on the following commit of OpenThread: 704511c96e0d093139e4b80ef0739ed2d701afb1"
    So if you want to change the UART0 instance used in the OpenThread library you need to modify and rebuild the OpenThread library.
    Edvin
  • Thanks for the reply, Edvin! I think I changed my mind about recompiling openthread for the moment. I tried to enable UARTE1 and use it, but I got another error: "multiple definition of `UARTE0_UART0_IRQHandler'" although I disabled all UART0 and UARTE0 flags in the sdk_config.h. The reason seems "#define NRFX_PRS_BOX_4_ENABLED 1" in the sdk_config.h. when I disable it, the code compiles but I am not sure about the result, I will test it again.
    I don't know what example you started with, but I see that e.g. the light_control\light_switch has NRFX_PRS_BOX_4_ENABLED = 1, and this uses UARTE0_UART0_IRQHandler.
    However, this compiles. I am not sure exactly what the OpenThread uses UART0 for, but it is probably related to this.
    Have you added another UARTE0_UART0_IRQHandler in your project? You should probably change it to UARTE1_UART1_IRQHandler if you are trying to use UARTE1.
    BR,
    Edvin
