oscillation at the embed analog front end circuits of SAADC in nRF52832
I found the strange phenomena on nRF52832.
By using the SAADC, I have some noise on ADC Data only at a certain temperature range.
Temperature range is depend on individual IC.
I might be the circuit oscillation at analog front end of SAADC, I think.
(internal reference voltage or op amp etc,)
I tried to switch DCDC on/off, but there's no difference on phenomena.
Anyone can resolve it?
I attach the files of real data and measurement condition.
Kiyoshi Iwai
3426.SAADC_noise_devzone.zip
  • Hi Kiyoshi,
    The test lab have tested 2 boards, however they are not able to recreate your symptoms yet. They will continue testing more boards to check.
    However, I believe I have made some progress by using the code and hardware description you sent.
    I have modified your software to write all data to the UART, so I could see the data while I was testing. I was able to trigger noise like shown below, I believe this is the same as you see.
    However I am only able to see noise if using CR2032 batteries, if I instead use 2x AAA batteries for supply and analog input, then I don't see such noise. I think part of the problem here may be that the CR2032 have problems feeding enough current during spikes, for instance when the radio and adc are operating at the same time. This may cause significant drop in supply voltage from the CR2032. I think part of the problem may be that the ESD protection diodes on the analog input somehow carry current if the power supply has quick drop in voltage, the 2x AAA batteries can handle this better.
    Using 2x AAA batteries with short wires seem to work here for the power supply, the analog input must have it's own 2x AAA batteries (or CR2032) for test.
    It would be interesting if you could try with 2x AAA on your end and compare.
    Kenneth
  • Hello Kenneth,
    Thank you for information.
    At what temperature did you do this experiment?
    At All temperatures you have this result in the case of CR2032?
    This data is not same our phenomenon, I think.
    Our case occurs only at a certain temperature range.(not all temperatures)
    And when i tried using the VDD/4 as reference voltage instead of internal 0.6V,
    I supplied power to the boards by normal power-supply (3.0V).
    But I still had this issue by using normal power-supply, not CR2032.
    According to your explanation, the internal resistance of CR2032 may affect to this issue.
    But the internal resistance of CR2032 is several ohms at max., so the voltage drop will be dozens mV when TX/RX.
    I don't think this drop may be a dominant.
    By the way, could you tell me what  does the test lab team check now concretely?
    Do they check by changing temperature?
    Kiyoshi Iwai
    Some results from the lab:
    Here is for instance the variation at 40degree C (manual measurement):
    The peak to peak deviation is about 35 LSB.
    If we plot the deviation as function of temperature (sweep -25 to +65C with 2C steps) the result (automatic test):
    As you can see the peak to peak deviation is pretty stable around 30-40 LSB peak to peak deviation. They are not able to see any significant noise peaks.
    Kenneth
    If you have long wires for the power supply, I would expect you could see the same. So I want to ask nicely that you try:
    Use 2x AAA for supply (with short wires) and 2x AAA for analog input (or a single AAA is likely easier). Make sure power supply is connected directly to VDD without any diode in reverse direction.
    Another questions:
    - If you test the same board multiple times, does it always happen on the identical temperature?
    - Can you share boards you know is failing with us?
    Kenneth
    How long did you stay at one temperature step on automatic test?
    (How many  AD samples in one step?)
    And is this data  on the oversampling mode? (14bit output)
    Thanks
    Kiyoshi Iwai
